Question about Welbilt Vertical Gas-Powered Pressure Washer - 2.2 GPM, 2500 PSI
Wel-bilt pressure washer only run short time - Welbilt Vertical Gas-Powered Pressure Washer - 2.2 GPM, 2500 PSI
Troy bilt pressure washer not siphoning soap
clean and soak all valves if do get work do not leave solution in it over time.carb cleaner with that little straw
Oct 19, 2014 | Troy-Bilt XP 3000 PSI 2.7 GPM Gas Pressure...
All outflow stops when I start the motor on my Troy-bilt 2600 pressure washer. What's up?
Could also be crack/leak in HP pump. If it were left in cold weather without antifreeze, I'd check there first. Part + labor might warrant new washer if more than a couple years old.
Sorry.
Aug 11, 2014 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
My troy-bilt 20486 pressure washer runs but does not spray water
OK just so we are on the same page.
You did turn on the water (right?)
Jun 12, 2014 | Troy-Bilt 2700 PSI 2.3 GPM Gas Pressure...
Wel-bilt power washer stalls after it heats up to running temp
pump lacking lubricant ,some are sealed.remove pump and inspect
Aug 17, 2013 | Welbilt Vertical Gas-Powered Pressure...
My current water tank was installed 12 years ago With Bladder. 1 hp motor. 80 gals. Water Pressure is consistantly low. When reset to 40-50 lbs, it drops shortly after back to thirty lbs in the house....
If I understand you, this is a water well. For pressure to drop, water must be going somewhere. If you see no leak in the tank, that is not the problem.
Check all outlets, faucets, toilets, showers, outside faucets, etc. If you see no leaks and the pressure is still dropping, there is a check valve either before the pump or in the well and this could be leaking back. Either way, the pressure should drop to zero unless the pump comes back on.
Gary
Jan 25, 2011 | Wel - Bilt Electric Portable Air...
How do you prime a troy bilt 675 pressure washer
if you dont see a primer bulb then you must start it in choke mode after running out of fuel
May 31, 2010 | Garden
I own a Troy-Bilt pressure washer, 2550 psi w/ a 6.75 hp motor. It will not keep pressure, I checked the water supply,hoses for kinks,tips for clogs and made sure the sun wasn't in my eyes. but it holds...
Mike, water supply is important. Make shure your running a 3/4" dia. supply hose to the pressure washer. The longer the supply hose is the less the water supply pressure is so keep as short as possible. Hopefully your hose hookup is running 3/4" pipe to it. It sounds like you've been diligent in checking everything. I hope this was helpful. Jeff
Apr 03, 2010 | Water Heaters
Troy bilt pressure washer will not build or reach high pressure
check the non-return valves in the pump block. if these are damaged or dirty you pressure will be greatly reduced. they are located behind the 3 lage brass hexagonal caps.
I hope this helps
Sep 04, 2009 | Karcher 2500 PSI Pressure Washer
Oil for a troy bilt 2550 psi pressure washer pump
What fluid and how much is required in the Troy-Bilt 2550 power washer pump?
May 17, 2009 | Briggs & Stratton Garden
Welbilt Vertical Gas-Powered Pressure Washer - 2.2 GPM, 2500 PSI Logo
48 people viewed this question
Top Welbilt Garden Experts
Dennis Key
Dennis Key
john h
Are you a Welbilt Garden Expert? Answer questions, earn points and help others
