Question about Traulsen G20010 Commercial Refrigerator
My used 2008 traulsen 3 door g200010 freezer reads -6 f but when i put thermometer inside it only reads 20 degrees. why and how do I make the freezer colder?
    New Friend:
  • 39 Answers
Make sure you are not blocking the evap air outlet with product.
Posted on May 16, 2014
2 Suggested Answers
  • 1252 Answers
SOURCE: MY traulsen 20010 Microprocesor reads 34 degrees
Your temp sensor is most likely the trouble. It is reading a false temp so it keeps the unit running trying to reach set temp. I would go there first as it is much cheaper than replacing the controller.
Posted on Jun 26, 2010
Traulsen reach in 2 door refrigerator is freezing up . What could be the problem
This Traulsen 3 door was freezing up due to bad expansion valve.
Oct 04, 2014 | Traulsen Refrigerators
What should the temperature be set on for a
FREEZER /FRIDGE NOT COOLING: Optimum refrigerator temperature at or below40° F(4° C). The freezer temperature should be0° F(-18° C). Check temperatures periodically. Appliance thermometers are the best way of knowing these
Aug 30, 2014 | Kenmore Refrigerators
Traulsen G sereis 2 door freezer keeps running past set temp of "0" degrees keeps freezing all the way to -35 degrees and I have to shut it off to keep it from running? any advice??
It basically sounds like the temp sensor is not sensing the box temp that the control functions on. Other wise, the control may be stuck. Traulsen seems to have a fairly descent tech support line. Call them for steps on how to read the controller.
Feb 04, 2014 | Traulsen G-Series G22000 Solid Door...
Frozen the coil and leaking water
Turn it off, let the coil defrost completely. After the dripping has stopped completely, check to see that paper and dirt is cleared from the air inlet side of the evaporator. Put a red stick thermometer inside the cooler and don't let the temperature go below 37 degrees F. Make sure the condenser is clean, the door gaskets are good and the doors are closing properly. Last thing is its low on gas and needs a service call. Good luck hope this helps.
Oct 08, 2012 | Traulsen G30010 Commercial Refrigerator
How to set up the temp. please
Purchase an appliance thermometer that is specifically made for refrigerators and freezers. These special thermometers were made to withstand cold temperatures and provide an accurate reading when exposed to such temperatures.
2Place the appliance thermometer in a glass of water.
3Set the glass of water with the thermometer in the refrigerator on the middle shelf.
4Check the temperature on the appliance thermometer after 24 hours.
The temperature should register between 37 and 40 degrees Fahrenheit (2 and 4 degrees Celsius) in order to store food safely.
Only barely above freezing -- say 34 degrees Fahrenheit (1 degree Celsius) is even better for food storage at the cost of slightly higher electricity consumption. But check that food is not slowly freezing in any part of the refrigerator, which could make it less palatable.
5Look for the temperature control dial inside the refrigerator if you have to adjust the temperature, and make it warmer or cooler.
If you can't easily see the control dial, check the owner's manual for a diagram that shows the location.
When looking at the refrigerator temperature dial, you may see numbers rather than degrees. The majority of refrigerators use a set of numbers, with the lower numbers representing cooler temperatures and the higher numbers representing warmer temperatures.
6Move the temperature dial in the necessary direction to adjust the temperature up or down. Be sure to move the dial only one number in either direction because it probably will not take much to change the temperature in the refrigerator.
7Adjust the temperature balance control if your refrigerator has such a dial or sliding switch. This allows you to direct more or less cold air to the refrigerator section from the freezer section.
8Wait at least 24 hours, and then check the refrigerator temperature again.
9Observe the amount of frost in the freezer section of the refrigerator if you are unable to properly set the temperature.
10Defrost the freezer if the amount of frost is more than .25 inches (.64 cm) thick.
11Repeat the steps as necessary until the temperature is within the safe range.
12Use a permanent marker to draw a line on the dial after you locate the best setting on the refrigerator temperature dial. This will give you a reference point in case your dial moves and needs to be adjusted in the future.
Hope this will help out...
May 07, 2011 | Traulsen Refrigerators
I am having LG GR-B352 YC , what is the best temperature that i can keep initially and future??
Generic instructions to set temperatures in fridges:
Many manufacturers design these appliances to operate at 0 degrees F in the freezer and 34 to 36 degrees F in the fresh food compartment.
To set the temperature correctly, fill a glass with water (8 to 12 ounces) and place a thermometer capable of indicating 32 degrees and up into the glass with water (if the temperature goes below 32 degrees, the water will freeze - so no need to find a thermometer that indicates any lower). Place the glass with the thermometer in it on a shelf and wait. Putting the thermometer in a glass of water helps preserve the temperature reading while the door is open. You can skip the water and glass if you want - but you'll need to read the temperature as soon as you open the door.
The freezer will require a thermometer capable of displaying 0 degrees F. Place it on a shelf where it can be seen readily - but preferably in the rear - between items (to prevent the warm air from driving the indicator up when opening the door to read it).
It will probably be easier to set the freezer temperature first. Adjust both the freezer and fresh food thermostats to mid-points (if the fridge is empty - otherwise skip this step). Adjust the freezer thermostat up or down as needed to reach the desired 0 degree F temperature.
Once the freezer adjustments are complete, adjust the fresh food compartment thermostat as needed up or down to reach the desired temperature for it.
If you fridge is fully stocked, it may take some time for the temperature to stabilize and warm / cool the fridge's contents completely. This is further affected by how often the door(s) are opened and for how long. 24 hours is often claimed - but you might be able to sneak an 8 - 12 hour soak before reading the thermometers.
After the temperatures are set, you may find that the lower part of the fresh food area is partially freezing - simply adjust the thermometer up *slightly* as needed.
Please rate this reply if it was helpful - good luck!
Aug 11, 2010 | Refrigerators
MY traulsen 20010 Microprocesor reads 34 degrees but inside the temperature is 20 degrees .It freezes everything help please.
Oct 26, 2009 | Traulsen G20010 Commercial Refrigerator
My refrigerator is not as cold as it should be. The digital read out says it's 36 degrees but when I put a thermometer inside and leave it there it only reads 47 degrees.
I usually dont go with a thermometer temp unless it is sitting in a bottle of water. Now drawer units get the air circulating from the freezer fan. Make sure that is running at a good speed. Also make sure the light is going off when the door is closed. Just close the door and pull gasket toward you and see if a light is on. If it is then make sure the switch is working.If not check the freezer for heavy frost.If yes then you have a defrost problem. If no then you need a tech to check the sealed system.
Sep 29, 2009 | U-Line CO2075DWR
My refrigerator is too cold
sounds like you have a defective temparture sensor
Apr 07, 2009 | Samsung RF265AA Bottom Freezer French Door...
Traulsen G20010 Commercial Refrigerator Logo
82 people viewed this question
Top Traulsen Refrigerators Experts
Dennis Boxerman
Andrew Taylor
Andrew Taylor
John Tripp
John Tripp
Are you a Traulsen Refrigerator Expert? Answer questions, earn points and help others
