Question about Luggage & Travel
Eminent luggage lock
I've lost the cod of my bag.how can i change the code? the bag is open
SOURCE: FORGOT THE CODE
Try from 000 to 999
Posted on Aug 22, 2008
SOURCE: Set luggage lock
the lock is currently set to 000. To set your own combination and with the lock in the 000 position, open the case and on the inside of the lock mechanism you will see a red tab. slide this tab to the left and then move the digits on the front to your desired code. ie 123. then move the red tab back to lock in this new setting as your own personal combination. close the case and then move the digits away from our setting of 123 and this locks the case. only if the digitrs are 123 in this example will the lock now open.
Posted on Jan 03, 2009
  • 4 Answers
SOURCE: I lost my keys to
file an old key with a small 'L' tip or do the same with a hacksaw blade. The tip should be appx 1/2" x 1/8" with the 'L' on the tip. Try several tip sizes. Spray some oil inside first.
Posted on Jan 21, 2009
SOURCE: my samsonite hardcase luggage's centre no.lock not able to close
problem sloved
Posted on Oct 21, 2009
  • 52086 Answers
SOURCE: Hi,i forgot my luggage bag combination which comes with a tsa 002 lock.Please help me to unlock it.Thank You
sorry no we can not but perhaps the luggage manufacturer can .
Posted on Nov 26, 2015
How to Reset t tsa lock on a Mia toro luggage
How do I set a Mia Toro luggage lock? - Fixya
www.fixya.com/support/t26581106-set_mia_toro_luggage_lock
Apr 30, 2017 - Release the reset button after you set the numbers to the new combination. ... If you still can't open the lock, contact Samsonite Customer Service at .... TSA lock on Eminent Osmosis Luggage, three digit TSA lock (HOW to ...
Amazon.com: Questions And Answers: How do you set the luggage ...
https://www.amazon.com/forum/-/Tx1WRFLRQIYMJR0/ref=ask_ql_ql_al_hza?asin... Jun 20, 2016 - Mia Toro Metallo Composite Hardside 26 Inch Spinner, Blue, One Size ... The factory setting is 000 make sure lock is set to this press the reset ...
How to Set A Luggage Lock / LuggageFactory.com - The Travel ...
https://www.luggagefactory.com > ... > How to Set A Luggage Lock Sep 10, 2014 - TUMI: TSA Combination Padlock: Make sure the combination is set back to (0-0-0), the factory setting if new, or the existing combination if it has been used already. Make sure the mechanism is unlocked. Press and hold the button on the side of the lock. Select a new combination.
how to Reset tsa lock on Mia toro luggage Google Search
Jul 26, 2017 | Locks & Locksmithing
How to change the 3 digit code of my samsonite ?
Luggage manufacturer Samsonite offers a variety of business, personal, travel products and accessories. Many Samsonite pieces such as attaches and other bags include a three-digit, built-in combination lock. When purchased, the locks are set on a factory default combination that you can change as often as you wish.
STEP 1
Turn the number dials to the previously set combination, or to "0-0-0", the factory default combination for Samsonite luggage.
STEP 2
Locate the reset button, usually placed to the side of the combination dials.
STEP 3
Press the reset button and hold it while rotating the number dials to the desired combination. Set this to a sequence easy for you to remember but hard for others to figure out.
STEP 4
STEP 5
Test the combination by turning the dials to the new code to open the lock. If the combination does not open the lock, repeat Steps 1 through 4 and test the lock again. If you still can't open the lock, contact Samsonite Customer Service at 800-765-2247.
Aug 28, 2016 | Luggage & Travel
TSA opened our lock on our Delsey luggage, I now am unable to lock the suitcase. How can you reset the lock on the Delsey luggage after unlocked by TSA?
1. Look for a small recessed button below (on the bottom side) the TSA key access.
2. Push in the button with a paper clip or pen.
3. While the button is pushed, change the combination to the desired numbers.
4. Then release the button and the combination has been reset.
I also found this, but it needs to be open/
http://www.ehow.com/how_6927475_reset-tsa-lock.html
Dec 08, 2015 | Delsey Helium Shadow - 25 Trolley Luggage...
Samsonite luggage
That keyhole is so that TSA can open that lock and take it off. They only time they would do that is if your are flying on a plane and the bag is in checked luggage and it needs to be searched.
May 01, 2014 | Samsonite Large Dial Travel Sentry Combo...
TSA lock on Eminent Osmosis Luggage, three digit TSA lock (HOW to change it to YOUR personal number)
Put the code numbers to '000'
Take the lock levers OFF the lock
Push the round opening button UPWARDS.
IMPORTANT :
KEEP holding the button UP until you have changed the numbers
Change the TSA code numbers to what YOU want
Release the round opening button
Now your case combo lock numbers have been changed.
To lock the case put the two lock levers into the holes, spin the numbers and your case will be locked.
To UNLOCK the TSA code spin the numbers to YOUR lock code, push the lock button UP and, hey presto, your case will open.
If you forget your NEW lock number you will NEED to go through ALL the numbers, starting at '000' to '999', to be able to open the lock/case.
REMEMBER to PUSH the ROUND OPENING button UPWARDS on EVERY number change.
Only THEN, when it finds YOUR correct three digit number, will it eventually open the suitcase/luggage/baggage.
Good luck
Aug 31, 2013 | Luggage & Travel
Number lock is forgotten on tolly luggage bag
Jun 07, 2013 | Cell Phones
Travel lock
From the Samsonite site themselves:
How do I set the code on my lock? Because there are many styles of locks used on our luggage and travel bags, we ask that you please contact us with the product # of your bag and we will be happy to assist you. You can e-mail canada.sas@samsonite.com or call 1-800-265-4933 x 220 (English) or x 237 (French) Mon-Fri 8:30 a.m. - 4:30 p.m. EST.
Dec 29, 2012 | Samsonite Large Dial Travel Sentry Combo...
I HAVE FORGOTEN THE CODE COMBINATION OF vip LUGAGE TROLLEY BAG SO PLEASE HELP
Please check out this page: http://www.vipbags.com/support/luggage-care-faqs
VIP provides assistance if you forgot your combination code. If this is not an option, first try all the combination, 000, 001 etc. Birth dates, last/first three digits of your phone number, car number etc. If this is not an option either, take it to the luggage seller, they can break the lock. If everything else fails, then you need to cut it open.
Oct 29, 2012 | Cell Phones
Reset lock on samsonite oyser luggage
i hope you can help me!
i went to change the combination on my locked Samsonite bag and when i closed it it would not open on that number.
i have tried the past number as well as the new one and it still doesn't open. thank you if you can help please it would be appriciated.
Carolyn
Jun 09, 2010 | Locks & Locksmithing
Set luggage lock
Dec 24, 2008 | Locks & Locksmithing
Luggage & Travel Logo
21 people viewed this question
Top Luggage & Travel Experts
ray gallant
Tom Chichester
Dave braun
Dave braun
Are you a Luggage and Travel Expert? Answer questions, earn points and help others
