Question about Canon PowerShot SX110 IS Digital Camera
Why will my memory sd card not snap into place? Yes, I have it oriented correctly.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 76 Answers
There is a small retaining clip in the memory card compartment which snaps into place when the card is inserted to hold it in. Maybe this has either become stuck, is broken or is jammed into place.
If you see it, then try wiggling it a little bit to see if it goes back in to place.
Hope this helps.
Posted on Oct 25, 2013
I cannot insert my Transcend SD 2 GB memory card in the camera. Is there only 1 type of memory card that can be inserted?
Make sure there's nothing in the slot, and you've got the card oriented properly. The i1237 works with SD and SDHC cards. The Transcend 2GB SD card should work fine.
Jul 20, 2011 | Polaroid i1237 Digital Camera
Memory card error card says locked
Hi!
SD cards (or MicroSD, using an adapter) are locked using a mechanical switch on their left side.
Simply, take the SD card (or the SD adapter) and change the switch position.
Usually the UP position is the Unlocked position...
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
B
est regards,
Pelu.
Jan 04, 2011 | Canon PowerShot SD1100 IS Digital Camera
Cannot insert the memory card - push in, won't seat, springy feel
Make sure that you insert the SD card in the correct orientation. If not, it will not lock into place. The SD card is push in to insert and push again to eject.
There is a small diagram showing the correct way to insert the card just below the left hand side of the slot.
Doug
Nov 03, 2008 | Canon PowerShot A720 IS Digital Camera
SD memory cards
Has another SD Card worked? is this the first you card you tried?
Be sure you have the correct type (size) SD card, there a couple of SD card types, micro (very small, etc.). It should go in only one way, does it fit and install easily? It should SNAP into placye.
A SD card is supposed to ONLY GO IN ONE WAY, the correct way.
It should SNAP in. Try to insert it in a different way very carfully.
DAVID
Jan 28, 2008 | Jazz DV-179 Digital Camera
SD Memory Card
Yes. The SV-AV100 comes with a 512MB* SD Memory Card. The SV-AS10, SV-AV50 and SV-AV25 all come with an 8MB* SD Memory Card. *Usable capacity will be less.
Sep 01, 2005 | Panasonic SV-AV50S Digital Camera
SD Memory Card
Sep 01, 2005 | Panasonic SV-AV25 Digital Camera
SD Memory Card
Sep 01, 2005 | Panasonic SV-AV10 e-wear Digital Camera
SD Memory Card
Sep 01, 2005 | Panasonic SV-AS10D Digital Camera
SD Memory Card
Sep 01, 2005 | Panasonic SV-AS10 Digital Camera
SD Memory Card
Sep 01, 2005 | Panasonic SV-AV50 Digital Camera
Canon PowerShot SX110 IS Digital Camera Logo
21 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
