Question about Fantom Vacums FM744H Vacuum
Motor on my Fantom Vacumm will not work - Fantom Vacums FM744H Vacuum
2 Suggested Answers
awa13
  • 78 Answers
SOURCE: i'm looking to buy the
I have one for sale if you are still interested, and other parts for this vacuum. :)
Posted on Nov 16, 2011
I have a Fantom Thunder TH469KA and it shuts off after 5-10 min of running How do I fix this?
on all vacuum cleaners the air flow cools the motor. If the filter is sufficiently clogged there would not have enough air flow to cool the motor and trips out from over heat. Clean out the filter thoroughly and try again.
Jan 01, 2015 | Fantom Vacums Vacuums
My fantom vacuum sweeper has got very loud when using
sounds like motor fan has gone u need new motor ...have it tested.
Feb 27, 2011 | Fantom Vacums Vacuums
I'm looking to buy the powerhead and hose for the fantom canister vacumm.
Nov 01, 2010 | Fantom Vacums Lighting Canister Vacuum
My Fantom Lightning canister vacuum won't turn on at all, worked fine last time I used it.
You need to turn over and remove the case to get to the motor.When you get to the motor you will see a white wire going to the motor from the switch,it has a white cover over the wire,pull this cover back and there is a small fuse that is probably blown.You can check this with a electrical tester.If this is not blown the heat sink that is connected to the fuse may be bad.These parts can be found at Radio Shack.
Jan 12, 2010 | Fantom Vacums Lighting Canister Vacuum
Hi I have an electrolux vacumm cleaner, super J model. My problem is that the powerhead only works if the switch is in the off position. vacumm motor works in the on position, opposite of each other. Can...
Looks like there's an interchanged wires in your vacuum. Both the motor and the powerhead must go together. Check it up. Leave the
motor wiring connection intact. Just tinker and check the powerhead
wiring connection .
Sep 25, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Same issue...need replacement wand for fantom lightning
I have the power head, wand & hose, exrra belt, 4 heps filters ans a spare main vacuum motor for Fantom Lightning. My main motor burned out. Found a used motor on Ebay. Went to change it and part of wiring was burned, so I decided not to rosk reairs with bad wiring. Power head was not attached at the time, so it is fine. I'll sell all together for a decent price, it you're interested
Aug 09, 2009 | Fantom Vacums Lighting Canister Vacuum
Need new powerhead for Fantom Lightning Style PH1A - Where can I buy it and how much?
I have the power head, wand & hose, exrra belt, 4 heps filters ans a spare main vacuum motor for Fantom Lightning. My main motor burned out. Found a used motor on Ebay. Went to change it and part of wiring was burned, so I decided not to rosk reairs with bad wiring. Power head was not attached at the time, so it is fine. I'll sell all together for a decent price, it you're interested.
Jul 15, 2009 | Fantom Vacums Lighting Canister Vacuum
Fantom Cyclone XT Vacuum Cleaner
Here is the owners manual which goes over some troubleshooting problems.
http://www.fantom.com/fantom/manuals/Cyclone.pdf
At first I would think it was the thermal overload, which is covered in the manual. But I would guess that you have let it sit for 30 minutes to cool down and tried again and the vacuum still didn't work.
I would think you may have one of four problems.
1. Your thermal overload was tripped and is stuck and will need replaced.
2. You have a clog in your vacuum lines or the brush roller is froze, which keeps causing the thermal overload to trip.
3. Your power cord has a short, which would need replaced.
4. Your power switch is bad, which would need replaced.
Out of these 4 possible problems I would say the only one you could fix on your own would be problem #2. Make sure the vacuum is unplugged and take the brush roller off and clean it, make sure it moves free. Check your vacuum lines to make sure you do not have a clog, other wise the motor does not get air flow to cool it down causing the thermal overload to trip. As for problem 1, 3, and 4 I would suggest taking it to a repair shop.
Hope this helps, post back.
Jul 11, 2008 | Fantom Vacums XT450K Upright Vacuum
Fantom Vacuum powder head Parts
In Canada I don't know. Parts for the older Fathoms are getting scarce. There is a wholesaler here in the US that has parts, but you have to be a repair shop to buy from them and I don't know if they are in Canada. Call your local repair shops to see if they can get you that circuit board, the co. name here is Essco, or Electric Sweeper Service Co. Wish I could help more.
Apr 24, 2008 | Fantom Vacums Lighting Canister Vacuum
Vacuums Logo
18 people viewed this question
Top Fantom Vacums Vacuums Experts
Richard Agent
Charles T Nevin
Charles T Nevin
Are you a Fantom Vacums Vacuum Expert? Answer questions, earn points and help others
