Question about Garden
John Deere Ride on lawnmower Model LTR 180. The mover starts fine but when I press the drive pedal there is no pressure and the mower will not move either forward or backwords. What could the issue be?
    Master:
  • 969 Answers
Check the spring for the clutch.
Posted on May 28, 2014
  • 708 Answers
SOURCE: john deere model 14sb lawn mower repair
Check for bad bearing in clutch immediately, Remove belt, try and turn the clutch pulley if it is hard to turn or feels rough, replace the bearing in the clutch. If you do not replace bearing immediately you will be buying a $300.00 clutch very soon. I know from experience. You possibly have been hearing a loud unusual roar from engine area for awhile and wondered where it was coming from. As these bearing will usually squall a cry for awhile before they die.
Posted on Mar 28, 2009
  • 246 Answers
SOURCE: John Deere 14SB mower with Kawasaki FC150V series - Throttle adj.
Hello rfbarrett:
From your Description it Sounds like the Plate that is Attached to the Carburetor (that the Throttle cable Attaches to) Thru Shaft (holds and Moves the Throttle Valve) has Loosened and is Simply Turning on the Thru Shaft and Not Moving the Thru Shaft and Throttle Valve at All.
>>You can View a Breakdown/IPL of the Engine and Mower at this Site Addy, http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt and Enter the Model Numbers 14SB and Click Find. Then Select your Model from the Search Results Area. Then Select the Sectional File. Then Select the Section of the Mower you Wish to View Online. *You can Drag the View Windows for Better Viewing.*
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 14, 2009
  • 15190 Answers
SOURCE: John Deere LT155 Lawn Tractor has trouble going uphill
u can change belt yourself need belt size and have to remove cutting deck but check belt tension first if loose with brake off belt stretched out and slipping needs replacement
Posted on Sep 29, 2009
  • 78 Answers
SOURCE: blade belt diagram for John Deere LX178 Riding
Remember the belt rule, V of the belt goes in V pulleys.Flat pulleys that are stationary or move get the back of the belt. You can figure it out. Its not rocket science. Remember at some point there has to be a tensioner,usually gets the back of the belt if its a flat pulley. U may have to remove the spring and then reattach the spring after the belt is routed.
Posted on Oct 29, 2009
nova2nv
  • 197 Answers
SOURCE: how do we service the blade / brake clutch
No serviceable parts,you can only buy complete clutch.To replace you remove blade and blade adapter.Use a very large vise-grip to remove spring and then you can remove bolt holding clutch arm.Disconnect cable from top side of machine.Remove engine mounting bolts,have another person pull engine away from frame while you slide clutch off.Going back together you may have a tuff time getting large spring back on hook under deck.I've been working on these for some time and have yet found an easy way to get large spring back on.
Posted on Nov 15, 2009
Belt routing diagram for a LTR 180 John Deere
Ian, John Deere LTR 180 Belt routing diagram. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
https://jdparts.deere.com/partsmkt/document/english/featbene/fb_MaintSheet_LTR180_42RearDischargedeckLawnTractor.pdf
https://groundscare.custhelp.com/app/answers/detail/a_id/264/~/mower-drive-belt-routing---170,-175,-180,-and-185
John Deere LTR 180 Belt routing diagram Google Search
Aug 14, 2016 | John Deere Garden
180 john deere riding lawn mower
Here is a link for the service manual for that tractor...
http://www.scribd.com/doc/105853489/John-Deere-Ltr155-Ltr166-Ltr-180-Lawn-Tractor-Service-Manual
Aug 16, 2014 | Garden
John Deere L130
I have not worked on these lawn mowers but there is plenty of posts on different lawn mower sites on how to rebuild the John Deere L1xx series transmissions. I would suggest have a read of this site. It also mentions the parts required and the cost. I understand these lawn movers use the K46 transmission system.
TuffTorq K46 Repair Guide with Pictures
Aug 15, 2014 | Garden
Why wont my john deere d140 move when I ngage the double foot pedal
The drive belt may be broken, or it may have slipped off a pulley.
Aug 03, 2014 | John Deere Garden
Hello. My x300 john deere ride on mower starts but will not move. The lever at the back is pushed in where it is supposed to be. can you plese help?
There is an adjustment that tightens the drive belt. This is the drive tensioner pulley. If you need a schematic or instructions on how this is done, go to John Deere dot com and they will have repair manuals and parts schematics.
May 10, 2014 | John Deere Garden
Please could you tell me where i can get an owners manual for my john deere ltr 180 mower
http://www.deere.com/servlet/com.deere.u90785.productcatalog.view.servlets.PublicationsSearchServlet?userAction=publicationsSearchResults&entryPoint=other&orderBy=pubType&
tM=FR&searchCriteria=ltr+180&language=english&submit=Search
Sep 12, 2010 | THQ The Lawnmower Man
Hand break on the John Deere LTR 180 is stuck and
To temporarily fix you need to remove brake linkage to trans.If this works you need to get it to the dealer to replace park brake rod.
Mar 28, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
91 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
