Question about Kenmore Washing Machines
My Kenmore 796.2927 shut off in the middle of a load and wont turn back on and I can not open the lid. There is power to the outlet
gittos73
  • 244 Answers
SOURCE: Kenmore Oasis - Lid Locked Shut and No Power
take your outlet pipe and place into a bucket so that it is low to the ground if water comes out then it could be that your pump is faulty when the water has all drained away the pressure switch will reset itself and the lid will now open if no water comes out un-clamp your outlet pipe from your pump if then water comes out then your pipe will be blocked m8
Posted on Aug 15, 2007
SOURCE: kenmore elite canyon capacity washer
You are in bad shape. Your sensor that supposed to close your cover might be broken or malfunction. I just had my problem last week and i very pissed. This will cost you almost the same price as you buy a new machine. $59 for sears technician to diagnose your machine, $156 ht got labor charge and $230 dollar for that bad part. The same machine cost around $660 dollar at the sear store right now. I am trying to fix it myself if I can.
Posted on Sep 06, 2007
IFIXALL
  • 868 Answers
SOURCE: Lid Lock light stays on
You are eligible for a refund. TAKE IT ! ! This should be a learning experience.Since when did the consumer have to be come the repairman WHEN ITS UNDER WARRANTY ,C,MON NOW!!!
Posted on May 26, 2008
jumptrout51
  • 3361 Answers
SOURCE: Kenmore washer will agitate but not spin
You have a bad clutch/brake assembly.
It is attached to the transmission shaft. It takes a little work, but you could replace it yourself.
Posted on May 13, 2009
  • 714 Answers
SOURCE: My Kenmore Elite wont tun on unless I open and
sounds like your lid switch is bad
Posted on Feb 15, 2010
How do I open a locked lid on Kenmore elite top load washer 796.2927 that has no power?
That washer is actually built by LG even though it has the kenmore name brand on it most all are the same for opening the lid when its stuck like that below is a video that shows how to get it open and then if you need more detailed help you can visit the link below the video.
Fixing an LG Top Load Washer DOA and Lid Stuck Locked
Appliance Repair Help With Live Chat
Mar 26, 2017 | Kenmore Washing Machines
The door of the Kenmore Elite 4.3 cu. ft. Front Load Steam Washer won't open
Ouch. Well I believe cll is child lid lock or something to that effect is engaged. You will have to find something to manually turn the locking gear or if you have a manual figure out the watts/amps and use some type of power adapter similar to that to jump the lid lock to open. Turn it off and back on and it should begin working again. But either the door lock, the door close sensor, or the main board are faulty.
Jul 01, 2014 | Kenmore 4.3 cu. ft. Front-Load HE Steam...
Kenmore elite washing machine, Just stopped, small load didn't make it to rinse cycle. Lid switch clicks when I open and close, but cannot restart. How do I take top off and do youthink it is a problem...
The lid switch is a possible problem.Annother possibility is if the machine was shaking for some reason the power cord might have gotten unplugged from the outlet.
May 07, 2009 | Kenmore 24032\24036 Top Load Washer
Washer dead
ck to see if you here a lid switch click when lid is slowly closed if not suspect lid switch may be on right sidew of opening or under left rear of lid at hinge also ck for loose lid hinge screws left side first
Sep 09, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore top loading washing machine
check the outlet to make sure that power is getting to the unit. This can easily be done by plugging in a lamp or some small appliance. If you have power at the outlet, it is most likely the lid switch.
The switch is inside the washing machine main housing near the door frame. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. Unless you are familiar with working inside the housing I would call a technician.
Mar 09, 2008 | Kenmore 22422 Top Load Washer
Washer stopped after filling, small load
I would check and make sure the lid is not bent or bowed. If the middle part of the lid is too far down when closed, the machine thinks it's open and wont run an agitate or spin. If it is bent, just bend it back for a quick fix.
Dec 03, 2007 | Amana ALW880WH Top Load Washer
Aug 14, 2007 | Kenmore Oasis HE 27082 Top Load Washer
Washing Machines Logo
37 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
