Question about Generac Guardian Electrical Supplies
Generac HSB Generator 1.7 Model 0055040
Engine cranks but will not catch. Propane tanks are full.
  • 42 Answers
SOURCE: wiring diagram for Generac engine on standby generator
here is a wiring diagram for that engine:
Posted on Mar 13, 2009
mydogisk
  • 50 Answers
SOURCE: Guardian generac 10kw model 5502 does not output correct voltage
the instructions says the voltage regulator is automatic/digital. when you check the voltage is there any load on the generator? if applying load to the generator doesn't help, you can manually change the motor speed where the governor connects to the carborator, but it may change the frequency, but the regulator may fix it
Posted on Apr 13, 2009
SOURCE: I have a Generac 15000 watt portable generator. It
I have solved the flooding problem . unfortanetly you must remove the carb to fix it. once you remove the carb you need to remove the fuel bowl. In the bottem of the fuel bowl there is a electronic seloniod that controols the amount of fule going to combustion. this aria had varnish and gunk built up around the plunger of the selonoid, long story short clean this out with carb and chook cleaner and put it back together. start her up and she will run like a champ.
Posted on Apr 27, 2009
mamicheddy
  • 79 Answers
SOURCE: I have a Generac portable generator 5000 watts, won't start!
I am assuming the generator worked fine before the oil change. Now that you have done the oil change the genset does not start. These generators have a safety switch, which is basically an oil pressure switch that keeps the engine from running when there is not enough oil in the engine. Make sure that there is enough oil and if there is, look for a wire that runs along side of the engine to a round component. disconnect that wire and try starting. If it does not start then try to ground out the wire to the engine block. If this does not work, then there is other engine problems.
Posted on May 08, 2009
  • 10 Answers
SOURCE: I have a 17kw generac generator that will run
I have the 18KW model and was told that most alarms relate to a low battery. Make sure the battery charger in the Transfer Switch is properly feeding the battery or hook up a mobil battery charger to the battery and see if the alarm goes away. Good Luck.
Posted on Oct 12, 2009
We replaced the regulator and the grill still does not have big flame always seem to be on low despite knob adjustment
Turn off propane. Disconnect propane tank from barbecue. Open burner valves for about 20 seconds. Close valves. Reattach propane tank. Slowly open propane tank valve. Turn on burner and ignite
Jul 30, 2014 | KitchenAid Superba KFRS271TSS Stainless...
My Generac HSB 17W AC Model 0055040 Generator will crank but won't catch and run. Propane tanks are full and have never been empty. What can I do?
Check for igntition at the plugs, check power is going to fuel solenoid. If power is on solenoid check LP pressures and make sure it is opening. Be carefull LPV is dangerous any spark can cause a fire. Check to make sure the throttle is opening during cranking, if it isn't it's a control issue
Oct 12, 2013 | Generac Guardian Electrical Supplies
3500 propane forced air reddy heater not putting out much heat since I changed bottles
tank is being turned on to fast and the safety valve will close and not let the full pressure go to the burner same with any new tank that has the columbine valve in it pressure sensitive
Mar 25, 2013 | Reddy Heater-30,000 BTU Propane Forced-Air...
My grill has full propane bottle but doesn't seem to be getting propane! Any help would be appreciated.
Check there is gas at the burners and that the orfices are not block or the burners are bot blocked .
Turn on burners let pressure out of line turn off tank remove gas line then reconnect to tank and turn on tank slowly see if this works
Mar 12, 2012 | Weber Baby Q Grill
I have a 2002 Chevy S-10 that will not start. Fuel pump hums, engine cranks well, just will not catch. Problem only occurs when temps fall below 30 degrees F. Iso-Heet was added to last tank of gas,...
when engine is cold to requires more fuel and spark to start. coil or spark plug wires. fuel pump is still a possibility even though pressure is in range may not be just enough
Dec 09, 2010 | 2002 Chevrolet S-10
Can't light the bbq
You make have turned the propane tank valve on too fast. Close the valve, disconnect it, reconnect it and very slowly turn the tank valve back on. That should solve your problem.
May 31, 2010 | Weber Genesis E-310 Gas Grill
Gas not coming out enough; flame not catching on to other burners
Problem: Low flames on grill, tank is full.
Cause: These newer tanks have a device inside that limits the flow of gas to prevent leaking or accidental discharge of gas from the cylinder. The leak detector mechanism inside the tank shuts off the gas whenever the valve is opened rapidly.
Solution:
Close the tank valve and remove the tank. Check the gas line for ANY object that could cause blockage. Open all valves on the grill to eliminate any pressure whatsoever. Close all valves and reattach tank. SLOWLY open the tank not over 2 turns. Check for leaks. I just open my tank a tiny bit but that is just me.
This late model gas grill service manual has more details on page 13.
Apr 28, 2010 | Weber Genesis Silver A Grill
Genesis s310 stainless grill. Does not fully light.
Regulator is not bad, as I stated before new valves are designed to reduce gas flow if valve is opened to fast. This is so if grill catches on fire, the tank will shut itself off, thus propane will stop flowing causing fire to extinguish itself.
Dec 28, 2009 | Weber Genesis E-310 Gas Grill
Gas grill conversion
It's safe, but you need to keep in mind that propane burns hotter than natural gas, so you won't need to turn the burners up as high for the same heat. Here's an article that explains some of the differences (but doesn't really answer your question): http://bbq.about.com/od/gasgrills/a/aa030505a.htm
Bottom line -- it's safe if you don't leave it cranked up to high flame. Two-thirds flame on propane should give about the same heat as full burner on natural gas.
Of course, you could change the jets. That would compensate for all the differences between NG and propane, and you could run the grill on full high heat if you wanted to.
Aug 05, 2008 | Barbeques Galore Capt'n Cook 3-Burner...
Propane will not come thru burners
Most propane problems are due to a new valve on the top of the tank. It is designed to only allow a minimal flow until the line is pressured. This prevents fire flair up from broken or leaking hoses. Always turn the bottle on and wait before trying to light a burner. If the burner is on first, the propane will never come out at full flow or if you have a leak in the system, it won't pressurize sufficiently to allow full flow out of the bottle. There is never "air" in the tank.
May 28, 2008 | Coleman Roadtrip Grill LXE 9949-750
Electrical Supplies Logo
239 people viewed this question
Top Generac Guardian Electrical Supplies Experts
jdthefixer
ken skalski
Are you a Generac Guardian Electrical Supply Expert? Answer questions, earn points and help others
