Question about Kenmore 22422 Top Load Washer
What is the part number for the lid switch. - Kenmore 22422 Top Load Washer
    New Friend:
3949238..kenmore
Posted on Nov 08, 2013
My kenmore 90 series washer will not drain i have tried playing with the lid leaver any thing else i can do ,can i replace the leaver switch?
Yes you can replace the lid switch its fairly easy to do...this tip i wrote will help ya to replace the lid switch http://www.fixya.com/support/r9939128-whirlpool_kenmore_estate_kitchen_aid
Series 90 is unfortunitly not a model number please reply with exact model number as found on a label on the rim of the tub inside of the lid and i will give you the part number for the lid switch.
GENE
Sep 12, 2011 | Kenmore 24032\24036 Top Load Washer
Kenmore washer model number 11026842691 will not go in to spin cycle
If the washer fills normally, then stops at the spin cycle and won't drain, then you need to check your lid switch and/or lid strike.
This is the most common cause of the problem you just described. Symptoms may include, filling and stopping on the intial fill cycle, stopping right after the wash cycle, not advancing to rinse or spin cycles, and a wash tub that will not drain.
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike" or "Actuator") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because It does not have a lid strike and the small hole on the right hand side of the wash tub will not be present. This switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator by bending it slightly.
NOTE: You do not have to drain or bail the water from the washer tub to perform this repair. Once a defective lid switch is replaced, the washer should drain normally.
Replacement parts (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average price of a replacement lid switch is about $20 - $30 if you perform the repair yourself. Prices will vary between sites so shop and compare. The part number for a replacement switch for the model number you listed is 3949238. The lid actuator part number is 350733.
If you have questions, or need additional assistance, please post back with your complete MODEL NUMBER and let me know. This is a very simple repair that you can easily perform without the assistance of a repairman.
If this advice does not help you enough, repairclinic.com has a Repair Manual you can order to assist you with all your repairs. The part number is 1170635 and is priced at about $20. Searspartsdirect.com also has a repair manual for about the same price. Part number 4314044L. I hope this information is helpful to you.
Jun 30, 2010 | Washing Machines
My model # kaw5700600 will not drain or spin on the rinse cycle
I could not cross reference the model number you provided to any washer model. Could you please verify your model number again (located on a nameplate along the wash tub rim under lid) and post back? The closest matching number I found was "KAWS700GQ0". Could you have looked at the characters wrong? This washer is manufactured by Whirlpool. The most common cause of the problem you are experiencing is a lid switch malfunction. Symptoms may include, filling and stopping on the intial fill cycle, a wash tub that will not drain, and stopping right after the wash cycle and not advancing to rinse or spin cycles.
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
A replacement lid switch (if required) can be purchased at any of the following web sites:
repairclinic.com
The average price is about $20 - $30 if you perform the repair yourself. Prices differ between sites so shop and compare. The part number for the model number I provided you with is 3949247. You can view an image of the switch as item 11 in the parts listing here: http://pcappliancerepair.com/model-display.php
If you have questions, or need additional assistance, please post back with your MODEL NUMBER and let me know. The lid switch is a very simple repair that you can easily perform without the assistance of a repairman.
May 13, 2010 | KitchenAid KAWS850L Top Load Washer
The peice that the lid come down on is broken, so
If you are referring to the lid switch, or the lid strike, ths is will cause symptoms that may include, filling and stopping on the intial fill cycle, a wash tub that will not drain, and stopping right after the wash cycle and not advancing to rinse or spin cycles.
If the link does not work, copy and paste to your web browser.
repairclinic.com
The average price is about $20 - $30 if you perform the repair yourself. Prices differ between sites so shop and compare. If the model number you posted this question under is correct, the part number for a replacement switch is 3949247. The lid strike part number is 358684.
If you have questions, or need additional assistance, please post back and let me know. If your model number differs from the one you listed this question under, please provide me with the correct information. The lid switch is a very simple repair that you can easily perform without the assistance of a repairman.
If you would like to purchase a Repair Manual to assist you with all your repairs, repairclinic.com has one that you can order on line for about $20. The part number is 1170635. Searspartsdirect.com also has a repair manual for about the same price. Part number 4314044L. I hope this information is helpful.
Apr 26, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer wont drain just stops when it gets to this cycle
If the washer fills, agitates, then stops at the rinse and won't drain, or if the washer does an initial fill, then stops, this is a symptom of a lid switch malfunction.
The following link explains how to access and/or replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the model number you have this listed under is correct, the part number for a replacement lid switch is 3949247. This is a very simple repair, that usually costs about $30 to repair yourself.
Appliancepartspros.com, pcappliancerepair.com and searspartsdirect.com usually have excellent exploded view diagrams of what I am referring to. Just type in your model number and look under the "Top and Cabinet Parts" section. The lid switch is listed as item 11 and the lid strike is listed as item 20.
If you have questions, or require additional assistance, please let me know. Post back with a correct model number if the model number is not correct. I hope this helps you.
Oct 02, 2009 | Roper RAB2121KW Top Load Washer
Fill up with water then stops
Check your lid switch. If the washer fills and agitates, but stops at the rinse cycle, or, if the washer fills, then stops, this is a common symptom of a lid switch malfunction. The following link explains how to access and/or replace one:
If the switch is not activated by a lid strike, it will activated by a hinge actuator located next to either the left or right lid hinge. You will need to remove the operator console in order to access this type of switch.
NOTE: On this type of lid switch the lid hinge has a small rod that is used as an acutator to toggle the switch. In many cases, you can adjust the rod by bending it if the switch is not making contact.
If the model number you have this listed under is correct, the part number for a replacement lid switch is 8318084. The lid switch on this model is located under the washer casing along the left lid hinge. This is a very simple repair, that usually costs about $15 to $20 to repair yourself. Appliancepartspros.com has an excellent exploded view diagram of what I am referring to. Just type in your model number and look under the "Top and Cabinet Parts" section. The lid switch is listed as item 11 and the actuator is listed as item 15. If you can access the switch an make it toggle, you may only need to do is bend the actuator slightly to get it working properly.
If you determine the switch to be defective, a replacement can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. All these sites offer competitive pricing, so shop all of them for the best price.
Sep 30, 2009 | Whirlpool LSR5132PQ Top Load Washer
Washer goes through wash cycle and stops
Check your lid switch. If the washer fills and agitates, but stops at the rinse cycle, this is a common symptom of a lid switch malfunction. The following link explains how to access and/or replace one:
If the model number you have this listed under is correct, the part number for your lid switch is 8054980. The lid switch on this model is located under the washer casing along the right lid hinge. This is a very simple repair, that usually costs about $25 to $35 to repair yourself. If you have questions, or require additional assistance, please let me know. Post back with a correct model number if the model number is not correct. I hope this helps you. NOTE: The timer costs about $130. I would recommend checking the lid switch first.
Sep 30, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer filled with water then nothing
This is commonly caused by a lid switch malfunction. If your model number is correct, the lid switch for your washer is located under the right hand side of the washer casing along the wash tub rim. The switch is activated by a small plastic piece on the washer lid (called a "lid strike") through a small hole. The switch contacts close when you shut the lid. In many cases, the lid switch either comes loose, or the lid strike breaks off. In both cases, the washer will exhibit the symptoms you describe. Open and close the washer lid and listen for a distinctive "clicking" sound as the switch is activated. If you cannot hear the switch, make sure the lid strike is intact and the mounting screws for the lid switch (located around the wash tub opening on the casing) are tight. Sometimes, all it takes is to tighten the lid switch screws to realign it with the lid strike. If the switch is defective, or the strike is missing, parts can be ordered on line at searspartsdirect.com. Just type in your COMPLETE model number (include the "110" prefix), which can be found on a nameplate under the washer lid. The lid switch will be listed under the "Top and Cabinet" heading as item number 11. The lid strike will be listed as item number 20. Other sites that offer competitive pricing are repairclinic.com and appliancepartspros.com. If you require instructions on how to replace the switch, you may use the following link:
If you have questions, or if the diagnosis is incorrect, please let me know. I hope you find this information helpful.
Jan 11, 2009 | Kenmore 22422 Top Load Washer
Whilpool washer #LLR6233ANO
The symptoms you are describing are usually caused by a lid switch malfunction. A lid switch is a very simple and inexpensive fix. The following link explains how to replace a lid switch:
In many cases a simple inspection of the lid switch is all it takes to fix it. It could be loose or not making proper contact. Check the mounting screws that hold the switch in place, first. If the screws are loose or missing, that may be all this required to get the switch to line up correctly with the lid strike. The lid strike is a small plastic piece that is physically mounted to the washer lid. The strike activates the switch through a slot as the lid closes. If the lid strike is broken or missing, this will also cause the same symptoms.
If the model number you have this listed under is correct, you can find replacement parts at searspartsdirect.com. Just type in the the model number and you can locate what you need under the "Top and Cabinet" heading. The lid switch is item number 9 (part #285671) and the lid strike is item number 20 (part #358684).
I hope you find this information helpful. The total cost of your repair is less than $50 if you follow the instructions in the link I provided and repair it yourself. Let me know if you require additional assistance.
Sep 17, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer
The symptoms you describe are typical of a broken lid switch. The lid switch is located under the washer top on the right hand side. It is activated through a slot by a small plastic piece on the lid called a "lid strike". Make sure the lid strike is still installed and not broken. Make sure the lid switch itself is not loose, as well. There are two mounting screws along the washer tub opening that hold it in place. If the screws become loose the switch will not make contact with the lid strike when the lid is closed. If you need to replace the switch or lid strike, the parts are available at searspartsdirect.com. Just type in your model number and look under the "Washer Top and Lid" heading on the next page. The lid switch is listed as item number 22 (part #3355806) and the lid strike is listed as item number 16 (part #358684). Both parts combined will cost you about $30. If you have further questions and/or require additional assistance, please let me know. I hope this helps you.
Jul 21, 2008 | Whirlpool LTE6234D Top Load Stacked...
Kenmore 22422 Top Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
