Question about Sharp The Sharper Image USB 2.0 Digital Photo Keychain
Plugged into computer for "Updating"has been sitting for hours? How long do I wait to start dowloading photo's on it? Did I do something wrong?
I am having the same problem. I plugged the device into my computer, set it to Updating mode, clicked on the software and it says to plug device into the computer and make sure it is in Updating mode. It is charging, but my computer does not recognize it as being plugged in. I've tried 2 different USB ports.
Posted on Jan 01, 2015
  • 3 Answers
Photo keychain has an installation CD.It won't run without the drivers.
Posted on Feb 24, 2014
My phone keeps flashing with "please wait" and a white screen
What is your phone model ?
let it sit in that way for 2-3 hours and keep the charger plugged in all the time and see whether the "wait" signal passes on.
Nothing happened in the previous procedure, remove the battery and let it stay for 10-15 mins and re insert the battery and see
If that didn't helped either, you can try updating, re installing the system software or hand it over to a technician.
Jun 08, 2017 | Cell Phones
Not sure if player is charging
QUESTION ONE:
Can you see it in "My Computer"? It will show under "Removable Drive/Storage"
QUESTION TWO:
Double click the removable drive to open the folders. Can you see your music, photo and movie folders?
QUESTION THREE:
Can you see the player in Coby Manager - under the "DEVICE" tab?
QUESTION FOUR:
When disconnected from the computer, how long can you listen to the Coby player before it goes off?
If not present in My Computer or in Coby Manager/Device Tab, then it is not plugged in correctly.
a. Disconnect the player from the computer.
b. Wait for it to cycle through "Please Wait" and "Updating Library" screens.
c. Make sure the player is TURNED OFF
d. With player TURNED OFF, reconnect wire to the player then to the computer.
e. You will see a USB connector icon on the player screen and the player charging.
It will appear to be charging all the while it is connected to the computer.
After it has been plugged into the computer for an hour, it should be well charged unless the battery is completely run down. In that case, you need to do an initial 8 hour charge - with the coby player OFF - through the computer. (This one got me when I first got my player!)
f. Use the Coby Manager to disconnect the player (Found HERE CobyMedia Manager fix for MP822 (Windows XP/2000/Vista)
1. Open Coby Manager
2. Go to the DEVICE TAB
3. CLICK on EJECT Button in lower right hand corner.
4. It will have a pop-up screen to ask "Do you want to eject?" Click YES.
5. The second pop-up screen will tell you "The device can now be safely removed from the system."
6. Disconnect the player from the computer.
7. The Coby will now show "Please Wait..."
8. It will take the Coby about 10 minutes on the "Please Wait" screen and then on the "UPDATE the Library" screen - Be PATIENT
You should now have enough battery power to use it. To check the battery level,
1. Turn on the player
2. The battery icon is in the upper right hand corner of the screen - it is ALWAYS RED until it starts to go down... I've not had mine down very far, but believe the red line gets shorter as the battery is wearing down.
Hope this helps.
Apr 07, 2010 | Coby MP-610 MP3 Player
My Coby mp3 player won't connect to my computer
QUESTION ONE:
QUESTION TWO:
Double click the removable drive to open the folders. Can you see your music, photo and photo folders?
QUESTION THREE:
QUESTION FOUR:
If not present in My Computer or in Coby Manager, then it is not plugged in correctly.
c. Make sure the player is TURNED OFF ! ! !
e. You will see a USB connector icon on the player screen and the player battery charging.
It will appear to be charging all the while it is connected to the computer. After it has been plugged into the computer for an hour, it should be well charged unless the battery is completely run down. In that case, you need to do an initial 8-16 hour charge with the player turned OFF connected to the computer.
IT WILL NOT CHARGE WITH A COMPUTER UNLESS IT IS TURNED OFF WHEN YOU CONNECT IT.
(Found HERE if you have had to format the player)
1. Go to the DEVICE TAB
2. CLICK on EJECT Button in lower right hand corner.
3. It will have a pop-up screen to ask "Do you want to eject?" Click YES.
4. The second pop-up screen will tell you "The device can now be safely removed from the system."
5. The Coby will now show "Please Wait..."
6. It will take the Coby about 10 minutes on the "Please Wait" screen and then on the "UPDATE the Library" screen - Be PATIENT
Hope this helps
Apr 05, 2010 | Coby MP-610 MP3 Player
I have a coby mp-610 and I just took it out of the box and plugged it in to my computer. Nothing comes on, nothing. I've hit the reset button. I've turned it off and on. It doesn't even show it's charging....
COBY PLAYER MUST BE TURNED OFF WHEN BEING ATTACHED TO A COMPUTER...
QUESTION ONE:
QUESTION TWO:
QUESTION THREE:
e. Let your computer recognize it.
f. You will see a USB connector icon on the player screen and the player charging.
It will appear to be charging all the while it is connected to the computer. After it has been plugged into the computer for an hour, it should be well charged unless the battery is completely run down. In that case, you need to do an initial 8-16 hour charge with the PLAYER OFF the COMPUTER ON.
f. Use the Coby Manager to disconnect the player (Found HERE If you've lost your copy on the player)
2. The battery icon is in the upper right hand corner of the screen - it is ALWAYS RED until it starts to go down... I've not had mine down very far, but believe the red line gets shorter horizontally as the battery is wearing down.
Hope this helps
Phone stuck "Updating Media Finder"
Pull the battary while phone is on. Wait a few seconds and replace battary. Do not try to turn phone on. It will take a few minutes to reboot. This updates everything.
Dec 24, 2009 | Motorola Mobility Karma QA1 Cell Phone
Waiting for DS code on AR
Yes. Your DS is now updating. It takes a few hours.
Jul 21, 2009 | Datel Ultimate Codes: God of War II
Digital photo keychain
Have done that, reset the unit, tried all combination of re-installing software, starting program 1st, plugging in unit 1st. pressing power button, resetting unit while USB is plugged in adn not plugged in, holdig doen power button and reset, holding pwr button while plugging in, and about 20 more combination. The screen says "UPDATING", the little light is"GREEN", the battery meter shows "FULL", when you unplug unit screen goes black and "NOTHING"... "0", "NADA", piece of **** !
**** SOLUTION -- RETURN PIECE OF **** TO STORE FOR REFUND !!! *****
Dec 08, 2007 | Alera Technologies Digital Photo Copy...
Can run photoviewer program for photo keychain
Your computer will certainly have its own program for viewing photos. For example, if you are using Windows XP, you just right click on a photo file and choose "preview". It can be difficult to find the photos on your computer if you have been using one of the silly organizers that come with cameras. You can search for a photo if you know its filename or for *.jpg to find all the photos on your hard drive.
Sep 11, 2007 | Sony Cyber-shot DSC-W55 Digital Camera
Sharp The Sharper Image USB 2.0 Digital Photo Keychain Logo
286 people viewed this question
Top Sharp Photography Experts
Tony
Are you a Sharp Photography Expert? Answer questions, earn points and help others
