Question about HP LaserJet Black-and-White Laser Printer
Driver for hp c3917a - HP LaserJet Black-and-White Laser Printer
I want HP C3917A SETUP
have U tried downloading from HP.com ? go to drivers and downloads
Apr 17, 2014 | HP LaserJet Black-and-White Laser Printer
I need to reinstall my hp d2660 printer but i lost the cd, how do i install it without? or can i?
hi,
The drivers can be found on the web from multiple locations.
I would recommend you genuine drivers by going on the HP website only. You would be required to choose the operating system and then youcan proceed with driver download.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=3742936&lang=en&
Please let me know if the provided information has been helpful.
Please rate me if the information provided was able to help you.
Jan 06, 2010 | HP Deskjet D2660 All-In-One InkJet Color...
Drivers
I loss the drivers of HP LaserJet 1020 printer. I need now. Please help me.
Jul 16, 2008 | HP LaserJet 1020 Printer
Laserjet 1010
where do I download a free driver ofHP LaserJet 1010 Printer
Dec 23, 2007 | HP LaserJet 1010 Printer
HP laserjet 1020 driver
You can download the appropriate driver for an HP 1020 here. Pls be reminded that drivers are OS specific.
Good luck and kind regards.
Dec 09, 2007 | HP LaserJet 1020 Printer
Proper Manual cleaning
Hi Gidget,
I typically use "Chux" wipes and a shop-vac to start with. The wipes wipe up and REALLY HOLD the toner & paper particles, holds 'em tighter than a Hobo does a ham sandwich...
(I'll concede to the 'by-the-book' crowd that a specific (read EXPEN$IVE) type of vacuum cleaner is recommended by HP & most other service org's. I've used my shop-vac for 12+ years and have serviced thousands of HP LJ's, CLJ's, AiO's, MFM's, DJ's, OJ's, etc. I have never lost a single printer because I didn't use the 'right' type of vacuum...)
The Chux wipes are available from PartsNow, LLC; www.partsnow.com/.
They also carry maint kits for almost every HP printer made as well as Lexmark, Canon, Xerox, etc.
I use Cooper's Platen Cleaner (PartsNow) to clean the rollers using 2" x 2" gauze squares and nitrile gloves. Fedron works well too. HP's website mentions isopropyl alcohol and water as their recommended solvents. Use waht works best for you.
Having some 6-inch long cotton tipped applicators (wooden handled single ended Q-Tips...) helps tremendously.
In conjunction with the correct service manual, (in your case,  Combined Service Manual for HP LaserJet 4L / ML & 4P / MPHP Publication Number C2005-90988, August 1993), a thorough cleaning is very easy for almost anyone to perform.
PartsNow and several other websites have HP Svc Man's online for free, Google around.
A legacy utility from HP that I've not yet tried can print and cycle cleaning sheets to clean mainly the fuser, but also claims to clean rollers as well. HP printer specialists will recognize 'cleaning sheets' from HP's newer models, built in to the menu structure. The utility will allow you to do the same for older (LJ 4, 5, & 6) printers. Find it at:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=125&prodSeriesId=25484&prodTypeId=18972&prodSeriesId=25484&objectID=bpl03846
Another Combined Svc Man is available as well that covers:
HP LaserJet 4 / 4M
(C2001A / C2021A)
HP LaserJet 4 Plus / 4M Plus
(C2037A / C2039A)
HP LaserJet 5 / 5M / 5N
(C3916A / C3917A / C3952A)
HP Publication Number C3916-90984 (March 1996).
As far as Scheduled cleaning, the cleverly formatted (LOL) table below lists HP's recommended service intervals. Over the years, I've found that adhering to the schedule has reduced unplanned downtime by almost 80%!!
DESCRIPTION / QTY / EST. LIFE (pages) / REMARKS
1.  Toner Cartridge / 1 / 6800 (note 1) / When print becomes faint, shake cartridge to distribute remaining toner.
2.  MP (Tray 1) Pickup Roller Assembly / 1 / 200,000 / Replace roller and separation pad together.
3.  PC (Tray 2) Pickup Roller / 1 / 200,000 / Look for glazing and cracks.
4.  Separation Pad / 1 / 200,000 / Look for glazing and grooves. Replace together with Pickup Rollers.
5.  Transfer Charging Roller / 1 / 200,000 / May affect print quality and/or paper jams.
6.  Fuser Assembly (115 V, 50/60 Hz) / 1 / 200,000 / May affect print quality and/or paper jams. Look for marks on rollers.
6a. Fuser Assembly (220 V, 50 Hz) / 1 / 200,000
7.  LC (Tray 3) Pickup Roller / 1 / 200,000 / Look for glazing and grooves. Replace the Separation Pad.
8.  Exhaust Fan / 1 / 25,000 hrs. (I've only had to replace one in 12 yrs...)
Note 1: The estimated Toner Cartridge life is based on A4 or letter size prints with an average of 5% toner coverage, and with the density setting at 3.
Best of luck,
Foxfur
Oct 16, 2007 | HP LaserJet 4 plus Printer
Driver for hp psc 1210
i need hp psc 1210 driver for windows vista (64 bits)
Oct 01, 2007 | HP PSC 1210 All-In-One InkJet Printer
HP LaserJet Black-and-White Laser Printer Logo
138 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
