Question about Electrolux Centralux Vacuum
Can I change the 10 or 15 amp breaker on the board or do i have to change out the whole circuit board. the amp is 10 to 20 dollars vs the board is 89 dollars i would like to spend less money if possible but i dont know if just the breaker could be changed or if the whole thing needs swapped out help please
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 125 Answers
Jesse if you are talking about a electrical panel then you can change them but you have to use the same brand and amperage.
Posted on Oct 13, 2013
Electrolux Epic 6500 SR - power/cord light not lit, doesn't start & blows house circuit breaker
If your vacuum has had 20 years of service it may be simply too old to repair.
Apr 15, 2017 | Electrolux Vacuums
Kenmore canister - trips 15 amp circuit breaker
Check specs on unit and amperage. If it is less than 15 then the upstairs breaker is kicking off prematurely - Not uncommon event. If unit is drawing more power than specs there is excessive friction in motor bearings. Also check out brushes for good contact since they wear.
Sep 11, 2017 | Kenmore 25512/ 25513 Progressive Canister...
Circuit breaker trips with shark steam mop
figure out how many amps your circuit breaker is
then figure out what appliances are running from that circuit
if you are under...then your mop is faulty
May 25, 2012 | Euro-Pro Shark Steam Mop - Gray/ Purple...
On a Faema Due expresso machine: Viewing the circuit board from the component side, with the two 0.1 uf caps on the left. The two pins on the left of the eight pin connector are completely burned from the...
The descripion you have send is only for the board. We need to know also how is the machine.
Is the machine working good up today and you have descover this after a fault?
If there was a fault what was that?
We need some of this information in order to get the whole picture and history of the machine.
Jul 27, 2011 | Vacuums
I want to know what amperage it is to install the right circuit breaker
Dont burn your house down just to get your vacuum to work circuit breakers protect the wire in your house 14gauge wire needs15 amp breaker 12 gauge wire need 20 amp breaker
Feb 27, 2011 | Vacuums
Vaccum was being used and suddenly stopped. checked the filter, circuit breaker, and pressed restart button. still does not come on
To test the vacuum motor and circuit card, detach low voltage wires from vacuum. Using insulated needle-nose pliers, place points of pliers in each wiring connector. This should start and run the motor as long as the pliers are in place. If it does, the problem is elsewhere, If the motor doesn't run, either the motor, circuit board, or internal wiring is bad. It needs to be taken to an authorized Aerus Electrolux store for repair/s.
If the motor runs, the problem exists in the hose and attachments. Broken wiring, switches, and worn or loose wand connections could be the problem. If you are unable to test the hose and wiring for continuity, take the whole machine to the nearest Aerus Electrolux store for a free diagnosis.
http://www.aerushome.com/storelocator/
Jan 06, 2011 | Electrolux Central Vacuum
Norelco razor 6867xl - am planning to replace battery pack. Would be easier to solder if I could remove the whole circuit board system from the hard plastic case. How do you release the metal clips?
The whole circuit board is removable, and I would recommend removing it from the whole external case to work on so nothing is damaged by your soldering iron.
Battery : 2x NiCd AA
Battery capacity : approx. 700 mAh
May 20, 2010 | Vacuums
Hoover EmPower 4600 keeps blowing circuit breaker. The number of outlets in the house that will allow me to run the vacuum is dropping quickly. It is a 4 year old house and all the circuit breakers are 20...
take it to a friends house and plug it in if it does the same thing then the problem is in the vacuum cleaner.check your cord and see if there are anny cuts in it.you can open the breaker box then plug in the vacuum and watch the breaker box.you might see a spark and narrow down the problem.
Mar 22, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
It keeps tripping the breakers or the GFI outlet.
try different outlets in another room to see if that dosent help you may have a shortin the cleaner but i think you may be overloading the breaker
Jan 17, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
Beam Central Vac Breaker Pops
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=797869
Generic problem for all Vacuums
Posted by tinateggart1 on Jul 17, 2008
The breaker on our beam model 167 central vac popped while in use. Every time I try and restart it, it immediately pops again. What's the problem? Circuit board? Motor? Overheating?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Chances are it is the relay switch on the inside of the Beam Central Vac, if it was a motor, it would not turn on @ all. If it was a circuit board, it may or may not be turned on, but if it will turn on and then pop your circuit breaker than it probably is the relay switch. Please, check with your local Beam vacuum cleaner dealer in your area or contact the Beam website or cust serv @ the phone number listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.beamvac.com/usa/ Owner Support
Customer Service 1-800-369-2326 Phone #
Email: beam.dir-support@beamvac.com
Technical Support: beam.tech-info@beasmvac.com
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 17, 2008 | Vacuums
Electrolux Centralux Vacuum Logo
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
