Question about Philips Magnavox 42MF521D/37 Television
Sat signal magnavox tv
Had tv repaired, when I reconnected sat cable, can't get a signal...all other tv's in house are getting one.
Make sure you have it in proper a/v or cable mode
Posted on Sep 25, 2007
SOURCE:
My digital tv is saying no singal whats the problem and how do I fix it? we have a huge antenna on our roof
1 – Is the NO SIGNAL issue happening on just one TV?
CORRECT INPUT or SOURCE
If it is just one TV that is showing the NO SIGNAL…
-Be sure your TV is on the correct source or input as your CABLE or SAT BOX.
-Press the TV button on TV remote control to turn your TV ON.
-Press the INPUT button on your TV remote control.
-Cycle through all the inputs on your TV.
-Do this until you are on the INPUT your CABLE or SAT BOX is plugged into.
-You should then see the CABLE or SAT programming show on your TV.
HINT: Your TV will most likely list the TV INPUTS as: HDMI 1, HDMI 2, HDMI 3, VGA, Component 1, Component 2, and so on.
If you still see NO SIGNAL on your TV screen, see the next step below…
2 – If you have your TV on the correct INPUT or SOURCE and you still see NO SIGNAL…
CABLE OR SAT BOX NEEDS RESET
-Remove or unplug the power cable from the Cable TV or SAT set top box.
-Keep it unplugged for 2 to 3 minutes.
-Plug the power cable back into your Cable or SAT set top box.
-Give it some time for the Cable or SAT box to power up, get the signal, and initialize.
3 – If you have reset the Cable or SAT box and still have the NO SIGNAL…
UNPLUG THE CABLE GOING FROM THE TV TO YOUR CABLE OR SAT BOX
-Remove the HDMI cable or other cables from your Cable TV or SAT set top box.
-Keep the cable unplugged for 2 to 3 minutes.
-Plug the HDMI cable or other cables back in.
-Give it some time for the Cable or SAT box to get the signal and initialize.
HINT: Make sure all the cables that are connected to your Cable or SAT box and your TV are tight, undamaged, and secured.
4 – If all of your TVs are affected with the NO SIGNAL screen…
BE SURE THE COAX CABLES OR ETHERNET CABLES ARE SECURE or CABLE OR SAT IS DOWN TEMPORARILY
-Be sure to check the ones where the CABLE or SAT come into your home.
-Be sure ALL Ethernet and Coax cables are secure.
-Call your CABLE or SAT provider to see if there is an outage.
-Realign your Dish if you have SATELLITE.
May 10, 2017 | Televison & Video
Picture but no sound magnavox HD tv
check to see in audio menu for set and sat or cable box if SAP is engaged as this will (Spanish) cause no sound on certain channels.
The problem or setting exists in the set and most boxes providing signal to the set.
Mar 12, 2012 | Magnavox Televison & Video
I have color on all but 1 TV station. That staion has color on other TV's in my house. Any sugestions?
Ur tvs in ur house it is getting a paid tvs incomming broadcasting tv signals like a cables or a satalites dishes companies?Yes,than that incomming broadcasting wire that plug into ur tv Ant. input port hole might have some kind of signals interference at that channel frequencies,call ur cables tvs or satalites tvs companies providers for an answers and get their field Tech. to come out and check it out.If all ur tvs in the house are analoge tvs and u are using a DTV signal through a DTV converter box to getting a Free over the air DTV air to recieving tv broadcasting tv channels stations only than tries it with another antenna signals sources like a better antenna design like a portable digital antena or good roof antenna should solved this problems.
Oct 03, 2011 | Philips Magnavox 20MS3442 20" TV
Need to get other stations on my philips magnavox can get standard ones but have cable and need to program in other stations need to know how, other tv in house have many stations and I just put this tv in...
Get into the menu and find the type of signal you want...cable or over the air. Set for cable and hit auto program! Be sure have a connection to the RF connector.
Dec 05, 2009 | Philips Magnavox 27MS343S 27" TV
Audio but no video cable/sat input or patch cables from DVD playe
Make sure the yellow [video] cable is in its proper home on the tv and sat box. You should be working with 3 cables and be sure to press the correct input with the remote or on the tv itself.
Sep 12, 2009 | Philips Magnavox 9P6034C 60" Rear...
HDTV Converter hookup with sat. and antenna
Hi there Phil...... this switch from analog to digital has lots of folks scratching their heads. Fortunately I have some great news for you. The signal coming from the Dish network does not need a converter as it is already digital.
May 29, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
No video output from Magnavox VCR (MDV560VR)
You need to tune a chanel on your tv to the vcr signal, using an RF cable (aerial cable between vcr and tv). That is if your tv has an analogue tuner.
May 09, 2009 | Philips Magnavox DVD/VCR Dual Player
No Cable Picture
Call the cable co. If your getting the cable setup screen from the tv...Its getting that signal from the box...The tv is fine.
Sep 14, 2008 | Philips Magnavox 52MF437S/37 52 in. LCD TV
Magnavox television
Basic TS - Turn tv off and unplug from wall outlet for 30 seconds. Make sure cable or sat box mute is off. Turn back on. If still no sound, just make sure that a dvd player, vcr or anything else connected to TV has no sound. Check antenna as well as cable or sat channels. If nothing has sound, call a serviceman to check out.
May 09, 2008 | Philips Magnavox 51MP392H Rear Projection...
Connecting
In general, you want to run red, yellow, white (composite or a/v) cables from the out of your sat box to the in of the Magnavox. Then run a 2nd set of r,y,w cables from the out of the Magnavox to the in of the TV (there may be one or several places to plug it into TV). If your sat box is an HD sat box, you probably won't get it to work with this Magnavox. This unit was jointly manufactured with Funai corp, so you will have to call 1-800-605-8610 for tech support.
Mar 26, 2008 | Philips Magnavox MWD7006 DVD Player
Philips Magnavox 42MF521D/37 Television Logo
50 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
