How to reset Maintenance message, Kyocera FSC8100
I've recently fitted maintenance kit A on a Kyocera FSC8100, but don't know how to clear the message (MK) on the control panel, any help would be greatly appreciated.
5 Suggested Answers
  • 58 Answers
SOURCE: Kyocera FS-9100DN
Go to the menu on the printer and then scroll down to other in the menu then to service then down to maintenance and press enter. when you install the maintenace kit you have to activate developer in the service menu, then turn off the printer and then back on to run the developer unit up.
Print menumap from the printer and follow through to the service area on the display.
Any question ask me.
Posted on May 11, 2008
  • 58 Answers
SOURCE: New maintenance kit
Hi Did you run up the developer unit? Menu button down to Other then to Service and press enter on developer and switch off and turn on will run for a while. In the service menu after you run up the dev unit you may have a option in there to press enter on the MK Symbol.
Cheers
Posted on Jun 27, 2008
Solvedude
  • 7 Answers
SOURCE: NEED SEEVICE MODE PROCEEDURE FOR KYOCERA FS 9120
asfasfa
Posted on Jun 10, 2009
  • 95 Answers
SOURCE: kYOCERA fs-1920 Has the message instal
It means the page count has triggered this message.
You _should_ get a maintenance kit.
But if you simply can't take the time/money, you'll find a new menu item in the menus after service. the new item is 'maintenance', get to there and press enter. (May need to press enter twice), the menu item, flashing light, and install MK message will all disappear.
Posted on Sep 08, 2010
How do I get rid of 'Install MK' message?
Missed something, Part of the maintenance kit is the developer and also the drum unit, you will need to change the 1/8th amp fuse in the developer assembly, and also the chip inside the drum unit.
Farnell stock both, the fuses are p/n: 446-816 and the serial eeprom chip is p/n: 690-650
This isnt the exact chip that kyocera use as they use a 93LC56B, but the ones that i have fitted before are 93C46 -these seem to work just the same.
Hope this helps.
Jun 02, 2015 | Kyocera FS-1135MFP
Resetting for replaced MK kyocera fs 1135
press numeric keys 1087 1087 , then 251
Checking/clearing the maintenance count Description Displays, clears and changes the maintenance count. Purpose To check the maintenance count. Also to clear the count during maintenance service (replacing the maintenance kit). Method 1. Press the start key. The maintenance count is displayed. Setting 1. Select [M.CNT A] using the cursor up/down keys. 2. Change the setting using the cursor left/right keys or numeric keys. 3. Press the start key. The count is set. Clearing 1. Select [CLEAR] using the cursor up/down keys. 2. Press the start key. The count is cleared. Completion Press the stop key. The screen for selecting a maintenance item No. is displayed. Item No. Description Description Setting range Initial setting Maintenance count 0 to 9999999 0
May 26, 2015 | Kyocera Office Equipment & Supplies
Time for maintenance C Kyocera 4501ci what is the solution
you need to replace maintenance kit c
MK-8505C (Maintenance Kit) 1702LC0UN2 300K $400.00 0.00133
May 20, 2015 | Kyocera Office Equipment & Supplies
We've replaced the maint kit in our printer however we cant get the message to replace to clear Kyocera T-362
Hi there, not sure what model you have, but on most Kyocera it is as follows, on the keypad press 10871087, now press 251 and enter/start, set value to a "0" and press enter/start button, if it asks if you are sure then press yes and enter/start, maintenance counter will now be cleared.
Jan 16, 2015 | Kyocera Office Equipment & Supplies
How to reset hp laserjet m5035 maintenance kit problem
When page count approaches 200,000 pages printed, the device alerts to order a maintenance kit. The message can be temporarily cleared by using the Clear Maintenance Message item on the Resets submenu under Administration. When the page count reaches 200,000, the message can no longer be cleared and the maintenance kit must be installed. To check the number of pages that the device has printed since new maintenance-kit components were installed, print either a configuration page or a supplies-status page. The print-engine maintenance kit includes the following items:
  • Fuser
  • Rollers (transfer, feed and separation)
  • Separation pads
  • Installation instructions
Mar 02, 2011 | Office Equipment & Supplies
Kyocera FS-4000DN is showing install MK; Can the problem be fix without buying a Maintence Kit for $532?
> without buying a Maintenance Kit ?
Either you buy the kit, or you sell the printer "as is" on eBay, after buying a new printer.
Jan 19, 2011 | Kyocera FS-4000DN Laser Printer
Where is the maintenance kit on hplaserjet 4345mfp
After printing 215,000 pages, the MFP alerts you to order a maintenance kit. The message can be
temporarily cleared for approximately 10,000 pages by using the CLEAR MAINTENANCE
MESSAGE
item on the RESETS submenu. When the page count reaches 225,000, you can no
longer clear the message and you must install the maintenance kit. To check the number of pages
that the MFP has printed since new maintenance-kit components were installed, print either a
the maintenance kit is Fusing element , pickup rolls for all trays, and transfer corona
To reset the maintenance-kit counter
Turn the MFP off and then on.
2 When the memory count appears on the control-panel display, press and hold 6 until all three
LEDs flash once and then stay on. (This might take up to 20 seconds.)
3 Release 6 and then press 3.
4 Press 6 to select NEW MAINTENANCE KIT.
5 The MFP completes its initialization sequence. The maintenance-kit counter is automatically reset.
Mar 24, 2010 | HP LaserJet 4345mfp Printer
Ricoh ap4510 - Maintenance Kit Issue
For the message to be cleared you should enter the service menu and reset the replaced elements
Jul 28, 2008 | Ricoh Aficio AP4510 Laser Printer
Kyo 3900 printer
menu button scroll down to other than down to service than down to maintenance press enter after you fit the maintenance kit and the developer up.
Jun 25, 2008 | Kyocera FS-3900DN Laser Printer
New maintenance kit
Cheers
Jun 12, 2008 | Kyocera FS-3900DN Laser Printer
664 people viewed this question
k24674
