Question about Husqvarna Zero Turn Mower Z5426
My zero turn husqvarna ran great last week. Know it wont start. I turn the key..nothing. I checked the fuses, all good. Brake is on , steering arms are in neutral..battery charged. I has to be something simple but I can't figure it out. Any suggestions
  • dave
    dave Oct 13, 2013
    I disconnected the cable to the starter at the solenoid. I put a test light on that terminal and turn the switch on and the test light did not go on. I did test the terminal on the other side of the solenoid which has the power cable attached from the positive side from the battery and that is hot. I check all visible safety switches and they are all connected and look good. All fuses are good. Still scratching my head trying to figure this out.
    Novelist:
  • 157 Answers
Check and see if your getting battery voltage at the starter terminal when trying to start engine. This may take two people, one to sit on seat while turning the key to start and one to check to see if there is any voltage to starter when trying to crank. If there is battery voltage at the starter when being cranked, you have a bad starter. If you don't have voltage at starter when being cranked, check and see if there is a starter signal going to the starter solenoid. I'm not sure where it is exactly located on this peticular model but it is not that far from the battery. The main positive lead which is red in color goes to the starter solenoid first. Then there is another lead with the same thickness that goes to the starter from the starter solenoid. There should be a small wire between 14-16 gauge going to the starter from the ignition switch. Disconnect that small wire and check and see if your getting battery voltage when trying to crank engine. If you are getting battery voltage to the solenoid, the starter solenoid is bad. If your not getting battery voltage to the starter solenoid when cranking, check all safety switches that would cause the circuit to be interrupted, not allowing the starter solenoid to be energized. Hope this works out.
Posted on Oct 14, 2013
  • CM Down
    CM Down Apr 05, 2016
    Well, Husky has a problematic blade clutch switch that causes the ignition switch not to work properly. R&R'd the ignition switch but, service tech said if experiencing the same problem to push & pull the blade switch to see if it will start. Got home with the mower & it would not start so I could get it off the trailer; pushed & pulled the blade engage switch a few times & it started!!!
    Why no service bulletin or recall to the customers, but that's a question for my attorney.
5 Suggested Answers
  • 109 Answers
SOURCE: Husqvarna zero turn mower won't start
Usually if all you hear is a clicking noise, it is the solenoid itself that has gone bad...if you can jump the solenoid and the mower turns over, it is the solenoid.
Posted on May 03, 2009
  • 3 Answers
SOURCE: Husqvarna riding mower. Wont start.
check your switch for your blades take it off(shut it off)
Posted on Sep 09, 2009
  • 202 Answers
SOURCE: Engine will not turn over
Those boxes are probably relays. Sounds as tho one of your safety switches is not working correctly. Make sure you have the machines brake on, blade off, and any other safety measures are applied, such as the operator is sitting in the seat. Check the wiring connections at all the connections where the safety features are installed. Probably just a connection that is not letting the system know that all systems are indeed applied.
Posted on Nov 15, 2009
SOURCE: My husqvarna tractor won't start.
have you checked the fuse? there is a 20amp yellow fuse under the hood just below the solenoid same side as the blade engagement switch.also be sure all your lock out switches are working or by passed.
Posted on Mar 18, 2011
My Husqvarna zero turn right arm steering arm isn't working
Make sure the free wheel lever is pushed in, you have one on each side for each transmission. Have you changed tires? Make sure the key is on the axle shaft. Then check the linkage under the seat.
Apr 05, 2017 | Husqvarna Garden
Just purchased a toro zero turn mower at garage sale. Ran very well first couple weeks. I was running it the other day, shut it down, jumped back on 10 mins later, mower does not start.
You'll need to check all the safety switches. Probably one in the seat, one for the mower engaged, one for clutch/parking brake engaged, possibly one for reverse gear selected, and possibly for position of the steering arms.
Nov 15, 2016 | Cars & Trucks
Car wont start cant move shift out of park new battery and plugs
nothing happens means the starter is Silent?
yes silence happens. ?
after all nothing is zero , how can zero happen,??? LOL.
the operators guide covers this.
how to crank in neutral, read that yet.
you must have what.?
1: fuses good.
2: charged battery. is it, ???? 12.6vdc rested?
3: brake fuse and working brake lamps. are theY?
this is called park lock out feature.
id dont have liberty books. zero.
nothing happens when i look for this book, LOL
on older jeeps there was a magic bypass device, for emergencies, but the dam(n) gov , made that ILLEGAL, like most things now.
I get lost here
I cant shift to neutral, or can
and if can shift to neutral, does the starter make noise.
that, GGGRRRRRHHHHAAAAA sound....
makes the crank shaft turn. even seen to turn....you can...
Dec 27, 2015 | 2005 Jeep Liberty
What can I try next? My husqvarna RZ4623 wont start. Nothing when the key is turned.
Is the small wire, coming from the Ignition Key, Getting 12V to the Relay when you turn the Key? Were Mice chewing on your wires?
Jun 25, 2014 | Snapper Husqvarna RZ4623 46" 23HP Kohler...
Truck will start for two weeks then wont. put a new starter in it ran for two weeks then wont start again. old starter tested bad so replaced it. put a new one in and coil pack ran for few weeks then won't...
check alternator output at the alt and at battery also put a test light on the starter solenoid at the little wire on solenoid see if it lights up when turn key ? possible positive or negative cables have good ohm checks but not carrying enough current ?
Jun 01, 2010 | 1998 Chevrolet S-10 Pickup
Murray 17.5 HP mower - no noise when turning key? Maybe ignition?
Look near the starter solenoid for a fuse. It is probably under the hood near the steering column. If fuse is good, problem is likely a safety switch.
May 19, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Zero turn deck problem
Is this a sewing machine problem ??
You may be in the wrong forum, or I may not be fully understanding the question.
Jun 11, 2008 | Husqvarna Sewing Machines
Husqvarna Zero Turn Mower Z5426 Logo
333 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
