If you have old thermostat and it worked when you switched to scheduler, try reinstalling it to see if problem persists. depending how it was wired, shut off sensor may disable furnance controller (not air handler). odd thing is handler runs nonstop w/o heat which is either thermostat, control wire or controller. if old thermostat is not available, turn power off and disconnect scheduler thermostat. with wires unconnected, turn power back on. if air handler starts running, you have eliminated the thermostat as the problem.
at this point you may want to check the control wire from the thermostat to the furnace for shorts or breaks. you can temporarily run a new control wire from thermostat to furnace. turn power off and run wire as you would an extension cord along the floor up through access hole to furnace controller board. be sure to label wire colors, typically 4 wire. turn power back on. if handler starts up, you have eliminated control wire.
only thing left is control board. I would leave repairs to factory trained tech as most have limit adjustments that need to be checked in addition to solid state components which require special handling.
