Question about GE GSHS9NGYSS (291 cu ft) Side by Side Refrigerator
GE Frig DSHS9NGYACSS. Brand: GE Age: 1-5 years
GE Frig DSHS9NGYACSS. Brand: GE Age: 1-5 years The refrigerator only cools to 48F even though I have set the temperature to 34F
4 Suggested Answers
huuum
  • 750 Answers
SOURCE: GE Side by Side Refrigerator pss26sgpass - Not cooling
Hello Villaruel,
Welcome to fixya.com
I'll give you some tasks that I hope will solve your problem.
Try turning off the fridge, and unplugging it or throw off the breaker, for 5minutes!
then plug it in and turn it back on. We are trying to reset the system like when you reboot your computer. Let me know that it worked!!
Huuum,
Please do not forget to rate us before you sign off!
Thank You
Posted on Sep 20, 2008
  • 531 Answers
SOURCE: Ge model PSC25MSTASS digital refrigerator setting
check for frost in the freezer back wall
Posted on Apr 01, 2009
SOURCE: GE Side by Side Temperature Problem
why does my icemaker freeze my ice cubs together
Posted on Apr 08, 2009
I have a ge GSH25JFXB WW side by side frig that was hit by a power surge. now, it does not cool like it use to. both the freezer and frig and warmer than before even when you turn it on full blast. they...
Start by checking the compressor. If it is running,you should tell by it being warm and a slight vibration/hum....it will start and should run until thermostat stops it. Since it's not cooling, it should be running all the time. There are 2 copper or stainless tubes entering the compressor. One should be hot;the other cold. If both are same temp,or the compressor not running,or is hot to the touch, your compressor is done for(some have a removable connector with contacts that are replaceable) Compressors aren't cheap.
Nov 04, 2013 | GE Profile PSW26P Stainless Steel Side by...
Refrigertor lights are on but not cooling
Can you tell me the brand and age of your frig?
Oct 03, 2011 | Kenmore Side by Side Refrigerator
We have a GE GTS 222C top freezer refrigerator, approx. 8 years old. The freezer works fine but the frig doesn't cool and is at the highest setting. We had to turn the electricity off for some wiring...
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 23, 2010 | GE Refrigerators
GE Frig clicking/not cooling at all
Good day,
Your problem could be in the circuit board or could be acting up because the compressor is failing.
The compressor is under full factory warranty and on some models the board has a recall.
Because of the fact 50% of your problem could be under factory warranty, and 50% not, I would not run a service call on it but refer you to GE factory service.
This may or may not be pricey to you, but based on the age and the issues this machine has had, it should be your long term best solution.
Dec 12, 2009 | Refrigerators
Burnt plastic smell coming from bottom of frig
This is a sign of a short and should be looked at immediately. A smell like that is a sign of something burning. I could be the start relay and start capacitor with overload. But I would not sleep with the possibility of a fire. I will look over your model and see if I can find what this could be, Sea Breeze
Aug 28, 2009 | GE Refrigerators
Side by Side GE Frig not cooling
Check the superheating of the evaporator.
Mar 22, 2009 | GE Refrigerators
Frig side is not cooling.
Check if there is frost on the back wall of the freezer, if so it is not defrosting. Many GE fridges need a new defrost heater every couple of years. If it's not defrosting, you can get by for a while by unplugging the fridge and leaving the freezer door open for 24 hrs, then plugging back in.
Jun 30, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Frig side not cooling
There is a regulator on the upper left side of the fresh food compartment. It is where the cold air produced by the evaporator in the freezer is released into the refrigerator. They used to be manual, but are now mostly computer controlled. If you can, manually manipulate it a bit to see if it is just sticking (unplug the fridge first, though).
Apr 14, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE ADORA Refrgerator :
The water line from the house to the frig works, however the water in the frig just stop working one day. Any suggestions?
Feb 09, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE PSW26M Artica Cooling and Ice Maker Problems
on the back of the frig is a small rectangle panel. inside that panel is the motherboard that controls the whole refrigerator. thoughs boards have been nothing but trouble. one of the problems it causes when it goes bad is the problem your having. replace the board to fix it
Nov 29, 2007 | GE Profile PSW26P Stainless Steel Side by...
GE GSHS9NGYSS (291 cu ft) Side by Side Refrigerator Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
