Question about Cell Phones
A manual alarm for emergencies for seniors with heat problems.
My 2000 Saturn SL2 is a 5 speed manual. I use the emergency brake every time I park. Now I am having problems with the emergency brake alarm going off when I am driving. If I wiggle the emergency brake...
that's a valve guide problem bring your car to a shop that who knows how to chance valve guide and also check the piston rings..that will help you solve burning oil
Jun 09, 2017 | 2000 Saturn SL
My thermostat has both auxillary and emergency light on,both are green,what does that mean?
Aux light; This turns on when the auxiliary (second stage) heating is in operation
It turns on 1-6 F below first stage and is user adjustable
Emergency light; This light turns on whenever the emergency heat is manually selected
(Mode switch is in the EMER position)
While in the emergency Heat mode, the heat pump compressor is off,
and the emergency heat (same as the auxiliary heat) maintains the
set point temperature
Jan 22, 2014 | Computers & Internet
An emergency personal alarm for seniors with high risk heart problems?
There are several on the market from a audible alarm to the more sofisticated models that ring an emergency number when activated. They can be found at shops that cater for this equipment or at chemist shops that will give directions as to get them .
Oct 12, 2013 | Cars & Trucks
Can't hear caller
Possible that the earpiece is not working, can be that the speaker is faulty or there is a fault connection. need to remove to confirm using a multimeter.
The emergency switch can be faulty and so is not contacting.
Nov 11, 2011 | Cell Phones
Product: Radio Shack personal emergency dialer,
are those recharbale batteries?
if they are, its probably the problem
when a rechargeable batt goes old it holds less
Dec 29, 2009 | Lands Phones
I only have two settings. Which is which and how so?
I think you probably have a heat pump. Aux heat is electrical resistance heat coils that produce heat when the heat pump can not produce enough to keep the temperature up (caused by low outside temperature or a problem with the refrigerant system). This resistance heat can be switched on by the emerg. heat button. It also can come on automaticlly (sp) and will be indicated by the aux being shown on the thermostat. Sometime if you set the heat up several degrees by thermostat the aux will come on to help the system catch up to the desired temperature setting. The emerg. heat is a way to turn on the AUX manually. If you do not have a heat pump system then it is possible that you have a heat pump thermostat installed on a non heat pump system. Emergency heat and Aux are both the secondary.
Hope this makes sense1
Bob
Oct 17, 2009 | Ruud Central System Air Conditioner
EM HEAT.... does it stand for ECONOMY HEAT or EMERGENCY HEAT? They both conflict. Someone's misinformed.
It stands for Emergency Heat. (Back up heat) . Normally you will find it on heat pumps. It's used manually when the compressor goes out on a heat pump. It's used automatically by the unit when it's so cold outside the heat pump can't keep up. This happens when there is not enough heat in the air to draw heat from. This happens at around 23 degrees. I hope this explains what emergency heat is and what it's used for.
Oct 16, 2009 | Ruud Central System Air Conditioner
Instrument Cluster lights do not go on, emergency lights steady- Sable 2002
Has anyone figured this problem out? Our 2002 Sable just started this as well...instrument cluster lights out, turn/hazard lights on when the headlight switch is turned on. This has the auto on/off switch with fog lights. This is happening in the auto and manual on mode. Any solutions would be appreciated.<br />
Oct 23, 2008 | 2001 Mercury Sable
Cell Phones Logo
13 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
