Question about Konica Minolta Dialta Di3010 3010f 3510 3510f Toner 2 Ctgs per Ctn 28 000 Yield Type 303A
Which side is can i find Sensor actuator in konika minolta d3510f?
5 Suggested Answers
Nicolomd
  • 84 Answers
SOURCE: I want cd for instale KONCA MINOLTA PAGEPRO 1300W (driver)
Try this driver (choose the operation system)
http://crm01.konicaminolta.eu/openmind/technic/kmpsdwl.nsf/psearch?OpenForm&ch=PRI&dist=BPE&ui=en&dg=sw&prod=PagePro%201300W&dsg=&os=&lang=&ml=0&rid=41256849005CE173&sub=Printer%20Driver&pcat=B%2FW%20Printer&pcc=1
don't forget to vote!!!
Posted on Jan 19, 2008
firecontrol7
  • 6680 Answers
SOURCE: service call 05H
Flash ROM upgrade failure. Engine firmware upgrade failure. Attemp to re-upgrade. Check for proper firmware,
Posted on Aug 08, 2009
Bizhubman
  • 108 Answers
SOURCE: Konika Minolta Copier prints half dark pages
If it is only causing an image problem when you copy and not when you print, then there is something wrong with the optics under the glass. Check and see if you have any mirrors out of place or if the scanner looks crooked. If you have the machine set up to scan try and scan to SMB or email to see if it still has the problem. If everything looks correct under the glass and scans to SMB and email look bad like the copies, you may have a bad CCD assembly, or a bad board.
Posted on May 12, 2010
Nicolomd
  • 84 Answers
SOURCE: konika minolta pagepro 1380 printer
try out the vista driver>it may be functional for win7
Posted on Jul 23, 2010
No toner in konika minolta pagepro 1580 printer
replace the cartridge and if that doesn't work, a sensor is malfunctioning.
Find the sensor and replace it.
May 01, 2015 | Konica Minolta Office Equipment & Supplies
is this a Minolta Di470?
If so try this:
Power off the machine. Then remove the toner bottle, be careful the hole might be on the bottom and the toner is going to go everywhere. Then close the toner cover and turn on the machine. Let the machine go through it normal routine. When it asks for toner install the toner bottle correctly. If THE KNUB on the side of the bottle is damage put a new one in. That KNUB is what the toner motor uses to turn the bottle, if it damaged you get a code. If that does not work, you might have a bad motor or the home sensor or actuator for the toner bottle is bad worse case the control board is bad.
Apr 28, 2014 | Konica Minolta Office Equipment & Supplies
When i copy you can not see anything, it is completely black konika minolta d3510f
does the scanning light come on? if not it probably is the lamp or the starter unit that's attached to the lamp rail(the part that moves back and forth)
Oct 09, 2013 | Konica Minolta Office Equipment & Supplies
Konika minolta pagepro 1380 printer
Jul 23, 2010 | Konica Minolta PagePro 1380 MF Laser...
May 10, 2010 | Konica Minolta Office Equipment & Supplies
Service call 05H,for konika minolta magicolor 2490MF,konika minolta printer
Aug 07, 2009 | Konica Minolta Office Equipment & Supplies
Looking for Digital Camera to use lens
Your Minolta QTsi Maxxum takes a Konika Minolta AF lens. These lenses work on these Konika Minolta DSLR cameras:
DYNAX 5D / Maxxum 5D
DYNAX 7D / Maxxum 7D
Dec 16, 2008 | Quantaray AF 70-300mm f/4.0-5.6 High Speed...
Konica Minolta Dialta Di3010 3010f 3510 3510f Toner 2 Ctgs per Ctn 28 000 Yield Type 303A Logo
21 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
