Question about Video Game Consoles & Games
Ps3 cechg04 cannot eject the disc....tried the restart method by holding the eject button and power on...NOT working..pls help...thanks and regards
  • aca717
    aca717 Oct 12, 2013
    the disc is still inside...i dont know how to open up the console.
  • aca717
    aca717 Oct 12, 2013
    my ps3 is hardly used...i mean may be once in 4 or 5 months its usrd..
    Problem Solver:
  • 17 Answers
I had the same issue, the only thing I was able to do if the eject method didn't work was disassembling the disc drive.
Posted on Oct 13, 2013
  • aca717
    aca717 Oct 13, 2013
    thanx eric...i'm working on it.. :-)
SOURCE: disc stuck in the drive of my ps3,,,i've tried
no. just turn on the game n pick up the system.tilt it completely over 2 where the part where u insert thte disc is facing the ground.then,hold down the eject button.simple. no number.no repairing.
Posted on Aug 26, 2009
  • 10 Answers
SOURCE: xbox 360
you need to send it off to get repaired
Posted on Aug 26, 2008
cursealoud
  • 42 Answers
SOURCE: disc is stuck in ps3 drive
trying sticking something thin and firm in there gently.. try to feel for the bottom side of the disc. Press the eject button and press up a few times. This may take awhile. But Be sure to be very Very gentle while doing this.
Posted on Aug 29, 2008
SOURCE: ps3 not accepting/'sucking in' discs
I have the same problem. Sony told me that it is a piece of the track gets stuck on the motor shaft and then the motor cant turn to "**** in" discs or spit them out.
Posted on Aug 31, 2010
  • 30 Answers
SOURCE: We put a bluray disc
switch off power at the back. hold down eject button, keep holding, turn power button at the back to on. console fan will spin very fast ( at this time take your finger off the eject) then goes back to normal. try now to hold eject button for more than 9 sec; it will then eject your disc. if this dont help check this site: http://www.edepot.com/playstation3.html#PS3_Model_Differences
PS: most likely, you already have a problem with your Blu Ray laser (life span expired) or hopefully you will need to just re-allign your CD drive mechanics. dont open your console if you still covered with sony waranty. otherwise; give it a try; many youtube videos will show you how to do that.
Good luck
Posted on Oct 10, 2010
Ps3 freezing and disc wont read and skips
You can try the steps below. Its from PlayStation Forum:
1. Turn off Playstation®3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION®3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION®3 System
If the above steps still does not solve the problem, then I think will have to update your Ps3.
Update your PS3 (in the settings menu the 1st option).
Go on the internet browser on the PS3 then go on the menu press triangle then on one of them there are delete cookies and the delete the others as
well as cookies.
You could also try this as well: put the PS3 on then press the eject button (with no disc in) then hold it and switch the PS3 off at the back with your finger on the eject button still holding it, then put it back on and the fan test should be working this may cool it down. It might be over heating.
But if your problem is not still solved, then maybe you should call sony for further assistance.
The most common reason for the PS3 not reading discs is a bad drive. The following website sells the drives and does installs:
store.richspsxparts.com/wiiredvddr
This drive should fix any reading issues you are having with your games, or issues inserting your games or ejecting them (or lack thereof). This is the entire DVD drive assembly mechanism replacement for your PS3 including a new laser. If your discs are not ejecting, or you cannot insert a disc -- or you can insert a disc but it will not load, this is what you need to get your PS3 going again!
Hope this will help...
Take care.
I wish you good luck
Aug 05, 2011 | Sony Playstation 3 (PS3) Console
Ps3 will not eject
The only way to force eject your ps3 disc is to hold down the eject button for up to 30 seconds.
You could try ejecting from within the PS3 menu,
You could try resetting your console by turning it off and then holding the power button down for 30 seconds.
Lots of PS3 owners have reported this issue, and the only common solution is to send it in to sony as your disc drive is broken.
May 09, 2011 | Sony Playstation 3 (PS3) Console
There is a disc in my ps3 however it won't eject. It flashes red light when I try to remove. I have tried to hold down eject for 10 secs however this step is not working for me. Any ideas? I would...
Please try the following to remove your disc :
Turn the PS3 off completely
Hold the eject button.
While holding the eject button turn the PS3 on at the back.
This method should make the PS3 force eject the disc. Don't worry about the fan going really fast, this is normal.
Hope this helps and thank you for using FixYa
Dec 18, 2010 | Sony Playstation 3 (PS3) Console
A disc is stuck in the PS3 and doesn't come out, but I am able to play that game. How do I fix it?
hold eject flip power switch in the back while still holding the eject button then turn power back on it will force the disk out but this method is for emergancies only
Nov 29, 2010 | Sony Playstation 3 (PS3) Console
We put a bluray disc in the PS3 and the disc is stuck and the console will not eject the disc and will not stay on. We have tried holding down the power button, holding down the eject button and nothing...
Good luck
Oct 10, 2010 | Sony Playstation 3 (PS3) Console
Disk won't eject
Ok, please try the following. Turn your PS3 off at the back so no lights on at all. While holding the eject button turn your PS3 on. It should now force eject the disc. Dont worry if your fan starts spinning super fast, this is normal when you do this.
You will need to turn your PS3 off at the back again as usually the front button becomes unresponsive after this method.
Sep 09, 2010 | Sony Playstation 3 (PS3) Console
The game cd cannot be ejected from the PS3. When the eject button is pressed the red light keeps blinking.
Try the following solution.
Turn the PS3 off with the main switch on the back.
Turn the PS3 back on into standby (red light on)
While holding the eject button press the power button on the front of the PS3. This should initialize a forced disc eject.
Aug 19, 2010 | Sony Playstation 3 (PS3) Console
The eject button is not working and the system wont recognize the disc so i cant eject it any ideas
Hi, i'm assuming you have a 40GB phatty PS3. Let's try this: - turn off the ps3 with the main switch, behind the console - press the EJECT touch-key on the front, HOLD on it while you turn on the console with the main switch... keep holding the eject key, if it'll work you'll get your disc out. If it won't work just try a couple of times more then if you don't succeed please advise me with more information about your PS3 model and I'll try to bring you other solutions :) Regards, Peter
Aug 05, 2010 | Sony Playstation 3 (PS3) Console
I had a disc that would not eject. Held the eject button for ten seconds and it did finally eject but it will not accept discs now. I restored everything to default settings and im still having the issue.
• Rebuild Database2_bing.gif: Rebuilds the OS for the PLAYSTATION®3.
If the above steps still does not solve the problem, then I think will have to update your Ps32_bing.gif.
well as cookies.
I wish you good luck.
Apr 12, 2010 | Sony Playstation 3 (PS3) Console
Ps3 jammed disc
Unfortunately their is no step by step or guaranteed method to fix this. Here are a few things you could try: turning it off and on, press/hold the eject button, resetting while holding the eject button, shaking or tapping it a little while trying to eject it, holding it different ways ex. face disc opening down towards floor while gently tapping and pressing the eject button. Essentially do whatever you can to get the disc to jar loose, >but whatever you do, don't for any reason stick anything in the slot or try to open the case <Doing this will void the warranty for sure! If none of these work your last resort would be to return it for a new one (providing you still have your receipt and it's less than a year old) or take it to a costly repair guy.
Jan 26, 2008 | Sony Playstation 3 (PS3) Console
Video Game Consoles & Games Logo
146 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
