Panasonic sa pm12 diagram
Every time I press the Clock/timer button, it turns off my system. I can't turn off the demo. What should I do?
devocap
  • 201 Answers
SOURCE: speaker wiring diagram
Hey there retgrunt, the information is at this location to download. the actual number on the guide is not the model you indicate, but the setup I believe is the same. I hope this helps Good luck!http://www.usersmanualguide.com/panasonic/dvd_home_theater_sound_system/saht70
Posted on Jan 28, 2008
SOURCE: Panasonic SA-HT740
Think I got it. Check your fan. Power it on and see if the fan spins for a few seconds and then stops. This is why mine kept giving me the F61 code and powering down. Remove the cover and use an air duster on the fan. This may not be enough so if you must, remove the fan (two screws + 2 clips) and pop it out of its housing. Dust the blades off and gently pull the fan away from its center as if you were trying to separate the two. There should be about a 2 or 3 mm gap there now. Dust that out and I even sprayed some lube (WD40) in for good measure. Put it all back together and make sure the fan spins and is quiet when you power up your system.
So far it's working for me. Good luck!
Posted on Nov 02, 2008
SOURCE: How do I stop my sterio from turning itself back
To kurtandloret. I have a SC-DV290 set up and according to the manual to turn the DEMO off I quote......While the unit is on: Press and hold [-DEMO] until "NO DEMO" is displayed.
I hope that this helps.
steve.m
Posted on Oct 15, 2009
Testimonial: "Awesome. Worked well. Thankyou "
  • 189 Answers
SOURCE: Error F61 on Panasonic Stereo System SA-AK80
HELLO
As far as I can know, F61 means your output IC is dead. Contact a service centre in your locality for repair!
Posted on May 12, 2010
dunnbiker
  • 8546 Answers
SOURCE: My LG system was in a demo mode and i tryed a
That might be another function for which a control is operated that you haven't noticed. Get the manual for the unspecified LG system and study the indicators, considering how they might cause silence. Keep the volume low-medium because the aha moment might result in sudden speaker-damaging sound.
Posted on Jul 07, 2011
How do I get my panasonic inverter microwave out of function key?
  1. Demo mode is designed for retail store display. In this mode, the oven can be demonstrated with no power in the oven. ...
  2. Depending on the model if the [Timer/Clock] button are one then press this 3 - 5 times. If they are separate then press the [Clock] button 3 - 5 times.
  3. If successful, the display panel will go blank.
Dec 01, 2016 | Panasonic Car Audio & Video
How do I turn off the Demo mode
Press the timer/clock button 4 times. That should disable demo mode.
Oct 20, 2014 | Panasonic Genius Prestige Inverter...
Got a Panasonic CD stereo system SA-AK410 When I turn it off after a few seconds it turns back on. Is this normal?
That's because you haven't set the clock on the system. I jumps to DEMO mode once you turn it off without the clock set. Clock can be set through your remote. Hope this helps. Cheers.
Oct 04, 2013 | Panasonic Remote Control Eur7710020...
I need owners manual for Panasonic CD Stereo system SA-PM12
The Panasonic website might have a free PDF of it.
Feb 02, 2012 | Audio Players & Recorders
I have a panasonic cd stereo system model number sa-ak29 every time that I turn it off 1 second later it come back on.
your system isn't turning back on it is a demo screen. find the button that says something about a demo and press it while the system is off. if that doesnt work press and hold the button while the system is off. if that doesn't work refer to your manual on how to shut off the demo
Jan 05, 2011 | Car Audio & Video
How do I get my Panasonic Inverter microwave out of demo mode? I think my toddler might have hit something to put it in demo!
Hello Two options to try: a) Press the Clock / Timer button 3 times b) Unplug, wait a few seconds, then re-plug to power up with the factory settings. You will need to reset your clock and any favourite settings.
This should work with all Panasonic Microwave models.
Good luck
Aug 10, 2010 | Panasonic NN-H275 Microwave Oven
I CANNOT SWITCH OFF THE EQUIPMENT ,AS SOON AS I GET TO SWITCH OFF THE HI FI IN A FEW SECONDS THE EQUIPMENT SWITCH ON AGAIN AND I CAN SEE THE WORD DEMO ON THE SCREEN
RTFM: Page 13:
"A demonstration of the display is shown if you have not set the
clock. You can reduce the power consumed in standby mode by turning the demonstration off.
Press and hold [–DEMO] until “NO DEMO” is
displayed.
Each time you press and hold the button:
NO DEMO (off) DEMO (on)
This is a 24-hour clock.
The example shows how to set the clock for 16:25 (4:25 p.m.).
1 Press [0/I] to turn the unit on.
Press [CLOCK/TIMER] to display “CLOCK”.
Each time you press the button:
CLOCK>>PLAY>>REC>>Original display
Within 5 seconds
Press [SET].
Press [TUNING (Up or Down)] to set the time.
The time display can be changed in one minute units by tapping
the buttons, and quickly by holding down the buttons.
Press [SET].
The time is set and the original display is restored."
Or under Troubleshooting Page 38:
"The display starts up even after the unit is turned off.
The demonstration feature (–DEMO) is on. Turn it off if it is not required."
If you need the manual go to
http://audio.manualsonline.com
register and get it for free.
Mar 25, 2010 | Technics SC-EH780 CD Shelf System
Cant get it off demo mode lost the instructions technics sa-eh 760
1 Press [ê/I] to turn the unit on.
2 1 Press [CLOCK/TIMER, -DEMO] to
display "CLOCK".
CLOCK>FPLAY>FREC>Original display
2 Within 7 seconds
Press [SET].
3 1 Press [TUNING (X or W)] to set the
time.
tapping the buttons, and quickly by holding down the buttons.
2 Press [SET].
Jun 15, 2009 | Audio Players & Recorders
How do I take it off demo
timer button 4 time on demo mode
time button 4 taps more off demo mode
see page 11 of your manual
please rate me for this
Jun 23, 2008 | Panasonic NN-SD997S Microwave Oven
Microwave oven (nn-sd997s) stuck in DEMO mode
Pressing "timer/clock" button 4 times turns on and off demo mode.
Apr 26, 2008 | Microwave Ovens
 Grubhead
Grubhead
