Question about Samsung Ml-2160 Mono Laser Printer
Printer fuser failure
U1-2320
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 65 Answers
Hi, you need to replace the fuser unit
Posted on Oct 18, 2013
How to fix fuse failure code 0500 phaser 6121 Xerox
0500 is a fuser failure error. Need to replace fuser.
http://www.iteminconline.com/126e02770_126e02770-xerox-6121mfp-fuser-110v-new.htm
Nov 15, 2015 | Xerox Office Equipment & Supplies
replace the fuser. Fusers have a life span based on the number of prints and not the age.
If you dont print alot on the unit, consider contacting the retail store or manufacturer
Feb 12, 2014 | Samsung Office Equipment & Supplies
SVC F5 error
I think the F5 error is a fuser failure error. Check that the fuser is seated correctly in the printer.
If the error does not come up all the time perhaps you can check the fuser is getting hot.
If available perhaps try substituting the fuser for a replacement known good fuser to fully identify the fuser as the cause of the error
Nov 10, 2013 | TallyGenicom 8008 Laser Printer
915 service motor error
The error means that the printer is detecting that there is Fuser cooling fan failure. Check if the fuser cooling fan is installed properly. If it is, check the fuser cooling fan for operation. Follow the steps below:
1. Enter Diagnostics mode.
2. Select MOTOR TESTS.
3. Select Fuser cooling fan.
Does the fuser cooling fan RPM increase? If yes, perform a print test, and if the error continue, replace the printer engine card assembly. If no, check the fuser cooling fan for proper connection.
Nov 30, 2012 | Lexmark W840 Printer
Xerox Phaser 4500 printer has a U4 fuser code.
From the Xerox Phaser 4500 Service Manual (here), the main problems could be one of:
  • Warm-up failure - Fuser warm-up not complete within 110 seconds after
  • starting.
  • Cool-down error - Cool-down process not complete within 200 seconds.
  • Low trouble temperature - The fuser temperature drops to the low trouble
  • temperature (approximately current control temperature, minus
  • approximately 25°C).
  • High trouble temperature - The fuser temperature rises to the high trouble
  • temperature (approximately current control temperature, plus
  • approximately 35°C).
  • STS circuit open
  • STS failure - The heat rod remains on for at least 10 seconds after warm-
  • up has completed
It could be that your fuser needs to be replaced, but as you can see that code relates to a couple of problems, so even replacing the Fuser might not fix the problem.
If it doesn't even do the warm up checks it is likely to be the fuser because the other components such as STS failure and cooldown won't have had a chance to run..
May 03, 2011 | Office Equipment & Supplies
I got the error 50.9 on my hp colorlaser jet 3600 and i've what it said on the screen of the printer and the error it still there. please help me, i need this, my job is in the line. what can i do to make...
Hi hope this helps
the error looks to be low temperature on the fuser
as a repairer of machine I would normally recommend a new fuser unit if you use the machine a lot don't go for a refurbished unit as they just dint last as long but they cost more
hope this helps Ian
50.X FUSER ERROR
alternates with
For help press
A fuser error has occurred.
X Description
1 - low fuser temperature
2 - fuser warmup service
3 - high fuser temperature
4 - faulty fuser
8 - low fuser temperature
(subthermistor
9 - high fuser temperature
(subthermistor)
WARNING: The fuser is HOT. Turn the
printer off and allow it to cool for
approximately 10 minutes before removing
the fuser.
50.1 error - Fuser failure (Abnormally Low
Temperature Main Thermistor), perform the
following steps:
1. The connector between the fuser and the
printer is not connected properly. Reseat
the fuser. Check the connector J5013
between the fuser and the printer. Replace
it if damaged.
2. Break in the main thermistor. Turn the
printer off and remove the fuser. Measure
the resistance between the fuser
connectors J5013LA-2 (MAINTH) and
J5013LA-1 (GND). If it is not within the rage
of 330k ohms to 50k ohms (at ambient
temperature), replace the fuser.
3. Faulty DC controller PCB. Replace the
DC controller PCB.
50.2 error - Fuser Failure (Abnormal Warmup).
Perform the following steps:
it if damaged.
3. Break in the fuser heater. Measure the
resistance between the fuser connectors
J5013L-2 (FSRH) and J5013L-1 (FSRN)
with the fuser removed. If it is not within the
rage of 12 ohms to 52 ohms (at ambient
temperature), replace the fuser film unit.
4. Faulty DC controller. PCB Replace the
DC controller PCB
Table 7-3. Numerical printer messages (continued)
338
Mar 24, 2011 | HP LaserJet 3600n Printer
Functional problem sc 541 for richo aficio 1022 photocopier
SC541 = The melting temperature measured by thermistor is less than 71 C
The problem lies in the fuser:
- Thermistor fuser defective or incorrectly installed
- Fuser Lamp failure
Solution: Replace Fuser
Jan 05, 2011 | Ricoh Aficio 2022 All-In-One Laser Printer
We are getting an error message on our printer "Fuser Failure". If we turn off the printer and turn it on again it will print. But the error keep happening. What is fuser failure
Fuser Failure, means that the fuser should be replaced.
If the problem persists, access PhaserSMART®. PhaserSMART is a powerful Internet-based diagnostic tool that automatically delivers the latest support solutions with a few mouse clicks. (English only)
http://www.office.support.xerox.com/SRVS/cgi-bin/webcgi.exe
The above is a form for ordering the fuser part for your model #.
Aug 09, 2010 | Xerox Phaser 4500 Printer
AL1610 code h4
This problem is fuser (the section that gets hot) related. It could be one or more of the following things :
Thermistor failure
Heater lamp failure
MCU PWB failure
Thermostat failure
Power supply failure
Interlock (door) switch failure
It could be that the thermistors(monitoring temperature) are just dirty and need cleaning or the thermostat has blown. THe heater lamp inside the fuser roller may have stopped working or their is a power supply issue to the fuser.
You could try pulling the fuser unit out of the copier and checking it / clean it. With these models its usually easier and cheaper to buy a whole new fuser unit.
You could try resetting the fuser error code in service mode.
To enter the service mode press the following keys
Clear (then) Density select (then) Clear (then) Density select (while in this mode do not adjust anything else as this could further damage your system)
enter "14" (with the copy quantity keys) and press copy key. Now restart the copier.
Feb 21, 2010 | Sharp Office Equipment & Supplies
PRINTER XEROX 3100MFPX FUSUR TEMP PROBLEM
Most likely you have had a fuser failure. It could possibly be the fuser and power supply board.
If the fuser rolls melted together, I would replace both, if you can remove the fuser and are able to rotate the gear, then just the fuser needs replaced.
Call 1-800-835-6100. They can take care of what you need.
Jan 05, 2010 | Xerox Phaser 3100MFP/S Laser Printer
Samsung Ml-2160 Mono Laser Printer Logo
448 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
