Question about HP Photosmart 2575 All-In-One Printer, Scanner, Copier
Help section says i can print without a color cartridge in "backup mode"....how?
Want to print in "backup mode" with hp 2575... no color cartridge
  • john19dx Apr 24, 2009
    thanks...but... i guess my question is....does the color cartridge need to be in there or can i remove it and print with black cart only? by "carts", you mean cartridge...right? thank you for your time
  • Anonymous Mar 18, 2014
    print in backup mode
    Champion:
  • 214 Answers
You can but you still need to have functioning colour carts
Posted on Apr 24, 2009
  • inkypete Apr 24, 2009
    No, colour cartridge needs to be in machine to print black
SOURCE:
I get different ink cartridge numbers for my hp2575, which one will work?
HP 98 black cartridge, HP 95 Colored cartridge are the standard ink for Hp 2575.
press the helpful button
Jan 05, 2016 | HP Photosmart 2575 All-In-One Printer,...
I have a hp 2575 printer, i need to know how to print with out color cartridge. I keep getting error code to remove color cartridge
that's not the right way too remove color. in your printing. put back all the colored cartridge you remove. go to printer properties. > settings > color management or details > then find the button that indicates that will like to print in a black and white scale. do not remove the colored cartridge.
Jul 13, 2011 | HP OfficeJet 6210 All-In-One InkJet...
Can it (HP deskjet F380 all in one) still print with only color cartridge or only black cartridge ? Or Should two cartridges remain together to print even one is empty ? Thanks
the answer to your question is yes,it can still print with only one cartridge installed.
If you do not have a replacement cartridge, and the quality of your printouts is not a concern, you can still print in ink-backup mode. Consider the following guidelines before printing in ink-backup mode:
  • If you remove the tri-color cartridge, printouts will be in grayscale.
  • If you remove the black or photo cartridge, the product will print more slowly and the colors in the printouts will vary.
    press OK button to clear the error message like cartridge missing after removing one cartridge.
Jun 20, 2011 | HP DeskJet F380 All-In-One Printer
The color ink cartridge '97' is being rejected by
hi,
this problem may be due to the senser in socket where you are insert the cartridge. so pls clean the socket with cotton using cleanin g liquid eg petrol , spirit or even nail polish remover
Aug 17, 2009 | HP Photosmart 2575 All-In-One InkJet...
Unable to print with new ink carts
Usually, that message means that your cartridge is dead. Try removing it, clean the electric contacts on it and the ones on the cartridge carrier. Put it back in. If that doesn't help, you will need to buy a new color cartridge.
If you do not have a replacement cartridge, you can still print in, what HP calls "ink backup mode". Simply remove the problem cartridge, and print with the remaining one, in this case, the black one.
Dec 23, 2008 | HP Deskjet D4160 InkJet Photo Printer
Printer will only print color pictures in black and cyan
Hi, this printer color cartridge contains all colors in one. So if you can print with one color means that the whole cartrige is ok but one or more colors ended. And you should had a low ink message on screen if it was genuine HP. Best thing to do is to go and buy a new one cartridge and see how it will go. This cartridge is green color.
Sep 05, 2017 | HP Photosmart 2575 All-In-One Printer,...
Color Ink Cartridge Problem
Unplug the printer, and leave it unplugged for 5-10 minutes. Then if the printer is still complaining about the color cartridge when you turn it back on, then replace the print cartridge.
David
Dec 04, 2008 | HP Photosmart 2575 All-In-One InkJet...
Color ink cartridge
Backup mode means printing with one cartridge. If the printer tells you "cartridge failed", it probably doesn't recognize it. You can try removing it from the printer and gently wipe the electric contacts on the cartridge with a dry cloth. Turn the printer off, turn it back on and reinsert the cartridge. If the message is still there, I suggest you buy a new color cartridge. You can also go to the store where you refilled your cartridges and ask for their opinion, they may be able to help too.
Oct 14, 2008 | HP Photosmart 8050 InkJet Printer
HP Deskjet D4160
hi,
Ink-backup mode lets you continue printing with one print
cartridge when the other print cartridge has run out of ink.
Ink-backup mode allows the printer to operate using only one print cartridge. It is initiated
when a print cartridge is removed from the cradle.
Exiting Ink Backup mode
Install two print cartridges in the printer to exit ink-backup mode.
Cheers !!!!
Feb 15, 2008 | HP 83 3-ink Black UV Cartridge Multipack...
HP Photosmart 2575 All-In-One Printer, Scanner, Copier Logo
689 people viewed this question
Clive
Clive
Thomas F. Schneider
