Question about Lego Media Lego Mindstorms
Port motor One of my motors will not work. It is free spinning without power and "locked" with power. Can it be repaired?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 43 Answers
Best bet is to replace the motor. Sounds like your having wiring issues inside the motor windings.
Posted on Oct 12, 2013
2 Suggested Answers
  • 3 Answers
SOURCE: Port A does not seem to power the motor - the
Hi have just posted this to another same problem post......it worked for me
http://www.robotic-lab.com/en/2009/08/05/small-correction-for-the-nxt-2-0-user-guide/
Posted on Dec 26, 2009
Inside unit working but no cold air. It's room temp. air. Outside unit is humming very lightly but not spinning. I had this same problem last year but a relay was burned out..
Stop. Do not run the A/C without the fan. The compressor could fail. The answer is exterior fan motor lubrication. With power off, the motor may be checked. Look for oil "ports" on an unsealed electric motor. Open & fill w/ ELECTRIC motor oil. The fan may be manually spun to free it up. The other "relay" problem is usually the contactor, and this would fail "on" always or "off" always. If the contactor is stuck "on" the system will freeze up, if "off" it will not run. You still may need to have coolant added to the system, but it's worth it to check this out first. If the motor has no oil ports, you can still try to free it up, but it will need to be replaced, or it will eventually fail.
May 25, 2011 | Heating & Cooling
Error reading LE. How can I fix this without calling repair guy. Washer spins but once the water is inthe machine it will not spin.
Hi
Error code LE indicates that either the motor is not turning or has locked up for some reason. It can also be due to Hall sensor which monitors direction and speed of the motor. If the sensor is faulty then also this error appears. Motor lock can be caused by several things from a loose connector, to a bad motor. To make sure it's not a locked motor, try turning the drum with your hand. And, if there is any resistance while turning the drum or the drum doesn't move freely then the motor is locked and you'll need to get it replaced. If the motor seems to be fine then you would need to replace the Hall Sensor. To replace the hall sensor, take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Hope this helps...
Daniel
Jan 26, 2011 | LG WM1814CW Front Load Washer
Power Windows and locks
If it does not work at all check the fuse first (check fuse and relay in any case).
If fuse is ok, test the wirings, from switch to fuse box, and from fuse box to motor.
If there is no power from switch to fusebox, replace switch.
If there is no power from switch to motor, check wirings and fuse, and eventually replace them.
If there is power to motor, check that the glass is not stuck , byu removing door panel, if the motor is not working replace it.
Regards.
Oct 10, 2008 | 1994 Lincoln Town Car
usually the regulator assy which is cable driven is broken if you hear the motor working but the glass doesn't move also if the lock runs or buzzes the lock actuator is bad
GE washing machine, wont spin
Same problem (but without any smell). You should try to reset the two computer boards in the washer. You do this by 1) unplugging machine and wait for 30 secs; 2) plug in machine; and 3) open and fully close the lid at least 5 times. This resets computer boards, which can get messed up by power surges, etc.
Mar 24, 2008 | Washing Machines
Won't spin
you need part number 12002039. its a motor/ motorcontrol kit. there have been alot of problems with this motor so maytag redisigened it
Nov 26, 2007 | Maytag Neptune MAH5500B Front Load Washer
Error code Lr
i am a appliance repair man and this is a normal problem and you need to replace your motor and motor control board sold as one unit these are 3 phases motors and one of the phases is bad. dont forget to put a surge protector on these machines because a little power surge can damage the boards maytag just figured this out because they are sending one with the new machines
Oct 11, 2007 | Maytag Neptune MAH5500B Front Load Washer
Washer won't spin
Sounds like an intermittant timer, A slipping belt if it uses one or a clutch on the drum. I looked for this make and Model and its not in my data? Sorry I cant assist more.
May 12, 2006 | Creda W120VW Front Load Washer
Lego Media Lego Mindstorms Logo
55 people viewed this question
Top Lego Media Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Lego Media Toy Expert? Answer questions, earn points and help others
