Question about Cub Cadet Street Sign- tractor lawn riding mower parts
Cub Cadet LT1042 PTO keeps shutting off after mowing several feet, will turn right back on but keeps shutting off
    Problem Solver:
  • 8 Answers
I have a Cub Cadet 1605 and it does the same exact thing. Try the PTO switch on the dash. I replaced mine and it works fine. Hope this helps.
Posted on Oct 21, 2013
4 Suggested Answers
SOURCE: the pto on my cub cadet 1515 cuts off. It will
Mine does the same thing. I've found that normally this is a heat-related problem and by removing all the clippings from the deck the blades will re-engage just fine until (unless) the clippings mount up again. Hope this helps; I make sure the deck is clean top and bottom before I mow.
Posted on Sep 23, 2009
  • 110 Answers
SOURCE: Cub Cadet LT1042 PTO won't disengage
If its an electric PTO then the switch on the dash is bad, Its a lever type ungagement then the little break shoes that rub on the blade spindles are either worn out or mis adjusted.If it started when you changed the blade drive belt its possibly the wrong belt??
Posted on Nov 01, 2009
SOURCE: I own a cub cadet LT1042. I started mowing tonight
Replace your drive belt
Posted on Jun 30, 2009
Rider will not turn over more than once no matter how many times I try.
I sounds like there's significant resistance to the engine turning over. I experienced this when the electric PTO/clutch seized - and the mower was trying to turn over the engine AND the mower blades because the PTO wasn't disengaging. Try taking the mower belt off the PTO and see how the engine turns over. If it's still slow, the problem is in the engine. If it spins normally, replace the PTO clutch. BTW - when my clutch seized, it also burned out the PTO switch. The switch is pretty inexpensive, so if you're replacing the PTO/clutch (I found one online for about $175.00 - MUCH more expensive at the dealership) - you should probably replace the switch as well.
Jun 28, 2014 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
Pto keeps shutting off after several feet
This is either the clutch relay, or the clutch is out of adjustment
Oct 12, 2013 | Cub Cadet Street Sign- tractor lawn riding...
you only need to remove the center bolt but make sure you see where the pins that keep it from spinning go this will help put it back togeather
Jun 01, 2012 | Cub Cadet Street Sign- tractor lawn riding...
Pto shuts off durning mowing
hook up a test light so you can see if it looses power when it shuts off
May 14, 2012 | Cub Cadet Lawn Mower Electric PTO Clutch...
I have an old Cub Cadet lawn tractor model 2155, where the PTO clutch stops working after about 15 minutes of mowing. It will re-engage after it stops, but will only mow for a couple hunder feet before it...
I have a Cub Cadet 2155 lawn tractor that mows great, purchase in 1999, however it started heating up about an hour into mowing and then I have to shut it down until cools. I have replaced the air filter & that did not work ?
Help.......Thanks
Aug 10, 2010 | Cub Cadet Street Sign- tractor lawn riding...
1872 cub cadet. Pto keeps turning off. Will mow a few minutes then blades shut off
Check your battery posts and terminals, they may be corroded, or your battery may be dying.
Jul 15, 2010 | Cub Cadet Street Sign- tractor lawn riding...
PTO WHEN PULLED DOES NOT ENGAGE....BLADES DO NOT START...
Check your mower deck spindles and belt. If belt is slipping at all the PTO will not engage.
May 10, 2010 | Cub Cadet Lawn Mower Blade Drive Belt CUB...
My cub cadet mower LT1042 will not start. It acts like it wants to, and you can really smell gas too. Has a new battery, starter, and spark plug.
Just had the same problem with our LT1042 and it was the fuel shut off soloniod. Could not buy just that piece so we took it off and cut off the piece that went up on the carborator and put it back on. Started right up. Now it back-fires when we shut it off but it runs.
Mar 31, 2010 | Oregon Scientific Electric PTO Clutch for...
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
378 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
