Question about Cub Cadet Street Sign- tractor lawn riding mower parts
Pto keeps shutting off after several feet
Cub cadet LT1042
    Sergeant:
  • 224 Answers
This is either the clutch relay, or the clutch is out of adjustment
Posted on Oct 17, 2013
5 Suggested Answers
SOURCE: I own a cub cadet LT1042. I started mowing tonight
Replace your drive belt
Posted on Jun 30, 2009
  • 110 Answers
SOURCE: Cub Cadet LT1042 PTO won't disengage
If its an electric PTO then the switch on the dash is bad, Its a lever type ungagement then the little break shoes that rub on the blade spindles are either worn out or mis adjusted.If it started when you changed the blade drive belt its possibly the wrong belt??
Posted on Nov 01, 2009
agent91
  • 2100 Answers
SOURCE: I have a cub cadet LT1042 and it is 3 years
You have to have something rubbing under there that isn't supposed to be, crawl under the tractor and watch the belt go around by hand, if you can turn it. Maybe see what is frozen up, in the wrong place, Gotta be a belt guide is rubbing or a pulley is not spinning. The PTO should last 20 years, all i can think is they got it too tight to start, .010" min, that is tight, and you must be in Florida picking up a lot of sand? If it was under any kind of warranty, I would raise a big stink about it. Those PTO's are not cheap. And the belt has got to be $20. I wouldn't go to a dealer for the belt, unless it is really special, just match it up at the auto parts store, for half the price of dealer. Hope this helps.
Posted on Jun 18, 2010
  • 6468 Answers
you only need to remove the center bolt but make sure you see where the pins that keep it from spinning go this will help put it back togeather
Posted on Jun 04, 2012
Cub Cadet LT1042 PTO keeps shutting off after mowing several feet, will turn right back on but keeps shutting off
I have a Cub Cadet 1605 and it does the same exact thing. Try the PTO switch on the dash. I replaced mine and it works fine. Hope this helps.
Oct 12, 2013 | Cub Cadet Street Sign- tractor lawn riding...
PTO engages, but, keeps becoming disengaged on LT1042.
Cub Cadets have one of two types of PTOs. The most common is gear driven. The gear teeth of the PTO shaft are very small and thin. If the PTO is engaged without proper clutch action, the gear teeth grind together, trying to engage. A little wear on these gears will cause the surface of the gears to become beveled, and when the PTO comes under load, the beveled surfaces of the gear teeth force the gear lock to disengage. The only option is to replace the worn gears...
The second type of PTO drive is electric clutch. This is a disc type clutch that is engaged by energizing an electromagnet built into the clutch pack... any disruption of electrical power to the clutch pack while under load will cause the clutch to disengage and then possibly try to engage while under load and casues the clutch pack to slip and will overheat almost instantly...
Sep 08, 2012 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
PTO will not engage onLt 1046
check the safety switches start with the one on the seat
Jun 04, 2012 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
Jun 01, 2012 | Cub Cadet Street Sign- tractor lawn riding...
Hi...I have a 2005 Cub Cadet 2042. With the switch in ''normal'' and the PTO engaged, when going forward cutting the grass the PTO will disengage for no apparent reason. You have to push the PTO knob in...
In the cub cadet, the PTO power is maintained via a latching circuit that includes a reverse switch and a reverse relay. Locate the reverse switch that senses whether the tractor is in reverse -- either it's come loose, become misadjusted, or it's failed, or the wiring and connections are loose. You could bypass the switch to confirm this as the problem.
Jul 10, 2010 | Cub Cadet Garden
PTO WHEN PULLED DOES NOT ENGAGE....BLADES DO NOT START...
Check your mower deck spindles and belt. If belt is slipping at all the PTO will not engage.
May 10, 2010 | Cub Cadet Lawn Mower Blade Drive Belt CUB...
My cub cadet mower LT1042 will not start. It acts like it wants to, and you can really smell gas too. Has a new battery, starter, and spark plug.
Just had the same problem with our LT1042 and it was the fuel shut off soloniod. Could not buy just that piece so we took it off and cut off the piece that went up on the carborator and put it back on. Started right up. Now it back-fires when we shut it off but it runs.
Mar 31, 2010 | Oregon Scientific Electric PTO Clutch for...
Oct 25, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
112 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
