Question about Craftmade International CQ52 Ceiling Fan
I got my craftmade ceiling fan about 10 years ago, the fan has now stopped working but the light works, I changed out the switch on the wall that was not the problem sometimes I will turn on the wall switch it will work but not all the time, could it be in the pull cord etc. Please advise
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 81 Answers
Pretty sure its the 3 speed pull chain switch.$4.50 to $6.00 at home depot or lowes or hardware/elecrtical store.
how 2 replace switch.
1.turn off breaker to fan/fan lights,probably that whole room.
may need extension cord & floor lamp from closest room with electric, so u can see.
2.need 6ft step ladder to get up to fan.look see how to get to fan speed switch. speed switch unscrews from outside but body of switch is inside fan cover.
3. need to take fan off ceiling to replace switch.
4.switch has 4 wires, power feed into switch and 3 selector
wires that go to high speed winding,medium speed winding and low speed winding.
speed selector switch has 4 settings, off, low,medium,high.
about ac circuits , black wire is 120 volts, hot.
white wires are neutral return wire. an ac voltmeter will read 120volts ac with its red and black probes between black,hot and
white,neutral.
white= neutal=ground which is green. If wired properly and polarity was observed, white and green ground wires both connect to the neutral ground buss bar in the circuit breaker panel box and are the same electrical point.
black wires,and the selector handle getting the hot juice into the fan and white returns the used juice to the circuit breaker panel box.
If polarity was observed, you can touch white and ground without getting a shock.
black will jolt or even fry you dead, so make sure the breaker to the fan is off, so that the circuit is de-energized before you touch it.
PLEASE NOTE--- make drawing on paper of what color wires from the fan motor go to what color wires on the selector switch.
If the switch has 4 black wires, you need to put different color electrical tape as a marker, on each wire. or ,to be cheap, you can use white paper,scissors to cut paper,and pencil and write 1,2,3,4 on the paper and tape to the 4 switch wires.
that is: wire # 1 from the switch goes to the black wire from the wall--ac hot
wire #2 from switch goes to yellow fan motor winding,
wire # 3 from switch goes to orange wire from fan motor
wires are specific and NOT interchangeable.
go to www.ehow.com & type into search engine box
how to replace fan motor speed selector switch.
Posted on Oct 13, 2013
    Master:
  • 996 Answers
Change click switch assembly hanging under fan
Posted on Jan 21, 2015
5 Suggested Answers
  • 79 Answers
SOURCE: reverse ceiling fan
are you sure theres not a switch on the fan body ,, up/down= summer / winter...There should be
Posted on Jul 04, 2009
SOURCE: I have a craftmade ceiling light fan which has
does it have a manual shut off switch to the lights?
Posted on Jan 20, 2010
SOURCE: I have a Craftmade Quest ceiling fan that will not turn on
looking for a manual for a craftmatic sewingmachine pretty old but hopefully there is still some out there
Posted on May 01, 2010
SOURCE: ceiling fan won't turn on with remote or wall switch
it is a new fan? If so electrician needed..
If not try replacing batteries in remote.... its happened to me...
Posted on Oct 31, 2012
My ceiling fan does not turn on, but the light works. The light switch and and fan switch are working.
If your sure it is powered from the wall switch, then your more likely to have a bad capacitor for the fan or a wire has loosened under the fan.
Jun 02, 2015 | Craftmade International Dryers
Craftmade Ceiling Fan Problems
Make sure your fan is on high with the pull chain switch. Push the remote Hi button then pull the chain until it's on the high speed, Then DO NOT use the pull chain. Same with light , Push light button on remote then pull chain until it's on then leave the chain alone. If that doesn't do the trick then you probably need a new receiver.
Jun 15, 2013 | Craftmade International CXL52 Electric...
Where is dip switch on craftmade cl52
Probably under the canopy cover at the ceiling.
May 24, 2013 | Craftmade International CL52AGSL Ceiling...
Why won't my light or ceiling fan come on? I have changed the batteries in the remote. It is twelve years old.
We are desperate to find one of these fans..I will buy it for 75 so it can match the 7 other ones I have and I will use my parts to make it work..Scott 321-228-3081 THANKS>>I just have soo many and I need my house to all match
Apr 30, 2013 | Craftmade International Televison & Video
Ceiling fan won't turn on with remote or wall switch
Oct 31, 2012 | Craftmade International Dryers
Motor just stopped working
make sure you get 230 volts at light connection or 115 if your in america. if yes check internal wiring. if all connections look good go to switch on wall where its switched on. check is there power on common side of switch. if yes then switch it on and check is there power on load side of switch. (L1). if no then switch is broke. replace switch.
Dec 29, 2009 | Hampton Bay 52 In.Carriage House II in...
Fan with remote won't work with wall switch. I
I just recently purchased a hunter ceiling fan w/light and remote. Had it installed and wall switch would not work, only remote. I contacted Hunter company directly about this problem and I was told that they redesigned their fans with remotes so that only the remote works for turning off power to fan. The person who made that made that BRILLIANT change should be fired. So to those of you who own a newer hunter an product with a remote ne your wall switch will not work tat s te reason why.
Jul 14, 2009 | Hunter Ceiling Fan Light Remote Control
Bathroom ceiling fan has stopped working
remove the switch and test it with a meter on ohms or remove the switch and disconnect the fan wires and connect the fan wires to an extention cord to test.
Phil
Jun 09, 2009 | Honeywell L4064B2236 Fan/Limit Control...
Apr 30, 2009 | Craftmade International Craftmade Quest...
Craftmade International CQ52 Ceiling Fan Logo
287 people viewed this question
Top Craftmade International Dryers Experts
Andrew Taylor
Andrew Taylor
Jerry Kramer
Jerry Kramer
Rani wadia
Rani wadia
Are you a Craftmade International Dryer Expert? Answer questions, earn points and help others
