Upa comtrend 902 status light red - Computers & Internet
5 Suggested Answers
damonumber5
  • 340 Answers
SOURCE: i have 2 comtrend dh-10pf
To start you need to factory reset both adapters,
plug them both into a wall socket next to each other, press the config/f reset button, hold in until ap light goes off, repeat on the other one.
Now you should have a red status light on both.
Press the config/f reset button on one for about 5 seconds, wait until ap light stays on, this one is now your access point (ap) that should be plugged in to your router when you have finished config.
Now press the ap adapter config button again for about 5 seconds until ap light flashes, then press the config button on the other adapter until ap light flashes, wait until they both stop flashing, wait a few seconds, the status light on both adapters should be green, and one adapter should have an amber ap light.
Hope this helps.
Posted on Mar 09, 2009
SOURCE: comtrend powerline ethernet adapter : power cuts
nope mines the same
Posted on Oct 22, 2010
SOURCE: Can not turn my comtrend powerline adapter of standby
i have the same problem,and i'm working on it,most probably a faulty capacitor in the power supply,i will let you know.
Posted on Dec 28, 2010
multilinkent
  • 739 Answers
SOURCE: Comtrend 9020 connection problem Unable to
Hi..
look at the problem you describe. Internet activity is most likely normal, but can not send a good Powerline Standard or High Definition (HD) movies
I said like that because the red led error is when the connection is less than 4Mbps, normal Internet activity Powerline possible but can not send good films Standard or High Definition (HD) movie
see in the picture below
try to do reset to default again
ways to do factory reset
Download manual guide for your reference
CLICK HERE TO DOWNLOAD
regards
hope this will help you
Posted on Apr 02, 2011
How do I ix my adsl2 comtrend modem when the internet light will not come on
If internet light is off, its not connected to the net. Check all connections. If OK try pressing and holding the rest button for 30 seconds.
Jan 25, 2015 | Comtrend Adsl2 Ethernet Router Model:...
ADSlflashing light
Usually means adsl is active if green ... if red ... maybe not
just reboot if there is a problem
Nov 11, 2013 | Comtrend CT-520 Router
I HAVE BT INFINITY BROADBAND - WORKING OK - I AM USING IT NOW VIA ETHERNET CABLE TO LAPTOP. HAD COMTREND POWERLINE 902 NETWORK SET UP AND WORKING. WAS ABLE TO ADD 2 MORE ADAPTERS - OK. BOUGHT 2 MORE AND...
The modem is probably still looking for the MAC address of your laptop at this point.
You need to unplug the modem AND the 902.
Power up the modem first and give it a minute to let the lights settle then power up the 902
Once the 902 is powered up and it's lights have settled down, start powering up devices that connect to the 902.
You may be surprised that this is all it takes!
Mar 12, 2011 | Comtrend Computers & Internet
Telephone company installed Comtrend CT-301 modem. Recently having connection issues with computer and noticed RED alert light coming on frequently on modem. What is causing these problems?
I've seen bulging capacitors inside this modem causing me problems. Changed the caps and everything was OK for a couple of years after that. Started to have more problems with this modem recently, called phone company and sent me an new modem. Problem solved.
Also, it seems this old modem does not like the newer routers (D-Link DIR-615). It connected for a while, (30 seconds) then lost connection completely until power was cycled on model. The modem worked OK with older D-Link Router.
Mar 13, 2010 | Comtrend Computers & Internet
Feb 18, 2010 | Computers & Internet
The code to programm my philip universal remote with my toshiba television
code and instructions can be found type phillips remote codes into search bar and choose a website
or press and hold code search button till red light stays on then enter each 3 diget code untill the tv functions codes for toshiba 112 313 413 506 510
512 613 902 after correct entry red light goes off
try channel up down volume after each code good luck ron
Dec 10, 2009 | Philips Universal PH301S Remote Control
Power light on& status light on
The power red led indicates that your device is "power on" , but the status led still red and turn to green if the device ( video input )received video signal ( from DVD player, Laptop etc. ) .
Apr 29, 2009 | Computers & Internet
I have 2 comtrend dh-10pf powerline adapters. one of the adapters status is a red flashing light and the AP light and the Ethernet light are blank. the second powerline adapter has a solid red status...
Hope this helps.
Jan 28, 2009 | Computers & Internet
Computers & Internet Logo
106 people viewed this question
David Payne
David Payne
