Question about Echo 15660152130 Coil-Ignition
How to adjust coil on hc 1500 - Echo 15660152130 Coil-Ignition
2 Suggested Answers
  • 203 Answers
SOURCE: I need coil and spark plug gap settings for echo
0.026 inch, or 6-8 mm is the plug gap.
The ignition coil air gap range is 0.012 - .016"" or .3 - .4 mm. This is the gap between the flywheel and the ignition coil.
An easy way to gap your coil is use a normal business card between the coil and flywheel, tighten the screws and remove the card.
Posted on Oct 23, 2009
Have no spark on my Echo HC-1500 hedge trimmer. Have replaced coil with new but still no spark. Have also by passed kill switch still no spark. What else can I try
Hi, have you tried a new sparkplug? Also did you set the coil to magnet airgap at 8 thou? Also when you say you by passed the kill switch did you do this by leaving the wire off the coil? Because if you did it at the switch end the wire from the coil may be chafed somewhere and earthing the coil. Hope this helps, regards Phil.
Jul 27, 2011 | ECHO, Inc. 20 In. Double Sided Hedge...
HIGH HYDRO CARBON EDELBROCK 1406 PERFORM 1500 MAN TRAN FAILD EMISS HIGH RPM ONLY
High HC counts are due to a rich mixture, too much fuel. How does the truck run normally? To adjust the fuel mixture at the carburetor, make sure the truck is at operating temperature. Turn the idle mixture screw clockwise until the engine starts to lag then turn the screw back just until it runs smooth. Also make sure you have fresh oil as this could cause high HC's as well since fuel gets into the oil and make sure your PCV valve is operating correctly. If you can't get it adjusted correctly, you may have to pay a shop to hook it up to the emissions machine to get the mixture correct, unfortunately.
Hope this helps. Good luck!
Apr 09, 2011 | 1985 GMC C1500
How can i test the ign. coil on a echo HC-1500 and also check the flywheel i have no spark and i have unplug the kill switch
pull the spark plug and ground it to engine. pull rope, and you should be able to see a spark across the plug. If no spark, replace the coil. There really is no effective way to check a coil without a very expensive coil checker.
Sep 23, 2010 | ECHO, Inc. 20 In. Double Sided Hedge...
Just failed smog with slightly high HC. the item that looks like a dstributor has a large rang of adjustment and looks like it can be adjusted. Keep in mind this is a 1996 jag xj6 with a crank trigger ign....
the car you have is the jag x300 series the main probs with this car are the lambda sensors and/ or the catalysts and you will get high emissions. to help sort this out you need someone with ids or wds software to help to check the fault codes or monitor the live data the ign timing is controlled by the ecu lower rh A post! its not adjustable
Nov 20, 2017 | 1995 Jaguar XJ6
The clipper blade adjustment on my Remington Hair Clipper, model HC-8017 (a black plastic adjustment arm) broke. Is it possible to get a replacement part?
The part that you require is not available for budget models like the HC-8017. You will need to purchase a new clipper or find an old one (ebay?) that you can buy cheaply for parts.
If you decide to replace your HC-8017 clipper, you will find them for sale at shaveroutlet.com
Jan 25, 2010 | Remington Precision HC-8017 Hair Trimmer
Looking to buy another Clairion Convection Heater - HC-1500 here in Florida 34429 whats the closetes store location or web site to buy one
Where in the Toronto,Ontario area or N.Falls/Buffalo NY can I purchase the HC-1500 Clairion Convection Heater?
Thankyou in advance for your attention.
M.A.Mike
Dec 18, 2009 | Clairion Convection Heater - HC-1500
I need coil and spark plug gap settings for echo hc 1500 type E2 hedge trimmer.
Oct 23, 2009 | Echo Garden
I have a HC-1500 hedge trimmer tested the kill swithch and it tested good, thought it was a bad coil so put a new coil on, still has no spark, should I put on a new flywheel? One magnet on flywheel seems...
take it to local small engine shop and get a free estament from them
they will tell you whats wrong with the unit
also have you tried to hold the coil wire and have a friend pull it over ??
if you get zapped then try replacing the spark plug
Aug 04, 2009 | ECHO, Inc. 20 In. Double Sided Hedge...
Looking for owners Manual for Echo HC 1500 Hedge Trimmer.
Go to this web site http://www.echo-usa.com/ and on the right hand side of the page click "TECHNICAL DOCUMENTS"
Then when the next page comes up type "HC-1500" and click search.
Now this is important: You have to keep track of your serial number, your model number and
your engine type.
Even when your looking for parts such as the ignition coil keep track of your serial number.
When you pull the side bar down you'll find the different manuals you can copy. I hope this helped.
Apr 02, 2009 | ECHO, Inc. 20 In. Double Sided Hedge...
Open Questions:
Echo 15660152130 Coil-Ignition Logo
48 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
colesmowers
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
