Question about Husqvarna Zero Turn Mower Z5426
Husqvarna ztrz5426 wont start hour meter flashing 000000
    Novelist:
  • 157 Answers
Check battery condition.
Posted on Oct 14, 2013
2 Suggested Answers
mickey813
  • 472 Answers
SOURCE: hour meter flashing hours and oil
soundslike the oil sensor is bad
Posted on Oct 15, 2009
My hour meter is at 99.9 and the mower will not start
try squirting some starting fluid in it see if it will start if it does check for water in gas or if dk rebuild carb i think carb is dirty rebiuld
Aug 26, 2014 | Husqvarna Garden
Husqvarna 223l trimmer
put a meter to the spark plug wire and see if it fires. Make sure all lines are clean.
Jul 23, 2012 | Husqvarna 28cc Gas Line Trimmer
Need a hour meter for a husqvana 18.5hp 38'deck
a napa parts store would have or get one also try sears parts online
Apr 29, 2012 | Husqvarna Garden
Husqvarna partner 750 concrete saw wont start
You need to make sure it is mechanically sound, has the piston picked up on the exhaust side? does it have enough compression? is there signe of concrete dust on the inside of the air filter and filter houseing?there are many after market carb gasket sets, some have a small hole missing from the diaphram and gasket on the metering side, this activates the compensator, this needs to be there as the metering cover has no breather hole in it.
Mar 13, 2012 | Husqvarna Saws
Low on oil ,added oil monitor won t stop blinking is there a reset button disconnected battery still blinking
The hour meter displays the total operating
time.
It will flash CHG OIL (Change Oil) at 50 hour
intervals. The flash duration is one hour
before and one hour after the interval. The
CHG OIL icon will come on and shut off
automatically. The hour meter can not be
manually reset.
Aug 09, 2011 | Husqvarna Zero Turn Mower Z5426
What does the hour meter on my mower actually tell me? It is flashing between hours of usage and chg oil. I changed oil and filter about four running hours ago. I cut grass for a few hours and then...
Hi, the meter flashes oil change when they are due(at pre-programed intervals) and will stop flashing two running hours after flashing starts. The hours that are showing are total running hours from new. Hope this helps, regards Phil.
May 31, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
My hr meter reads 8.0, is this 8hrs? If this is then my hr meter is wrong cause I know I haven't ran this for 8hrs.
that would be 8 hours. the hour meter measures engine run time. so if it is just started and setting in one spot, it will count on the meter. if you are sure the engine has not run anywhere near 8 hours then there could be a problem with your meter and you should contact your dealer for replacement.
May 14, 2011 | Husqvarna 22 hp 42" Yard Tractor YTH22V42
Trouble code ch6 oil on hour meter
Sounds like your oil low switch is either bad or maybe wire was knocked off when changed oil.
May 11, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husqvarna Ride Lawn Mower does not want to start, which theres about 1/2-tank of gas. My Husqvarna Ride Lawn Mower is only a few years old which I have done some routine maintenace. The lawnmower has set...
I've discovered that if you leave key on battery will be drained to dead. Checking battery with meter shows +12v. When key is turned to start position nothing happens. When you connect meter to battery terminals and put key to start position the meter reads about .250 VDC. Even after taking battery to Advance Auto and have it checked it still does same thing. Eventually I jumped my mower with another battery that was being used in my scooter. Bingo! all worked well with jump. You would probably be able to jump with car battery with no problem.
Mar 25, 2009 | Husqvarna Garden
Husqvarna Zero Turn Mower Z5426 Logo
64 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
