Question about Toshiba Camileo B10 Camcorder
My battery dies form non-use, I charged it and it worked for awhile, but now, neither the original battery, nor the replacement battery are charging ( I've been charging them on a computer, I'm trying straight dc now, but nothing as of yet. Is it a problem with the unit?
  • 69 Answers
Sometimes even a brand new battery can be bad. If it does not charge from your PC or straight from a Charger I would suspect the battery.
Posted on Oct 12, 2013
Battery won't hold a charge, car will run but lights go dim and car dies after running for awhile.
have the alternator bench rested as it is not charging correctly
check drive belt condition and tension
the problem is that everything is getting power from the battery without any charge going back in.
Aug 12, 2014 | RTO Alternator/Battery Tester
My 2009 honda civic dies out once in awhile
sounds like the beginning of an alternater going bad or a battery when it is on remove the positive cable if it is still running its charging and you will soon need a battery replacement hope this helps
Jun 30, 2012 | Honda Civic Coupe
I have a polaroid i634 that has an issue with power. Initially I put in alkaline batteries and it worked for awhile (or at least as long as my daughter used it). Then it stopped working. I was told to use...
Hello ..
I hope that really problem with charging.
However, it look like cause from battery. Whatever type of new battery that you used, that no meet the requirement as original battery that included with camera. During testing the camera, they also don't use other battery except that original battery. Maybe it seem like have same power, But it chemistry is different. However, you can try using same battery from polaroid also.
TRy look this..click here
I don't want to scare you, but is good to have new battery same like original and also from same company. As long you are using other type battery, It maybe will effect components in camera. So beware and careful.
If you think that charging is problem. THen try recharge back around 8hours. However if u are using external charger. and not using camera to charge battery.If you only can charge through camera, try recharge around 2-3 hours. Pull out battery from camera. place safely and avoid any magnectic environment . Around 2-1 hours, charge again 2-3 hours. After charge, around 10-15 minutes, try used it. It still have problem? If still face same problem. I advice to find suitable battery.
Jul 06, 2011 | Polaroid i634 Digital Camera
2003 protege5 wont start unless jumped and dies after about 30 seconds.
Need to check battery condition first. Is it the original battery? If yes chances are it needs to be replaced. May have a dead cell or 2 & will not hold a charge. When it ran before this, was the check battery/charging light on? Also verify charging system is working correctly.
Jun 22, 2010 | 2001 Mazda Protege
My battery dies yesterday, when I try to cherge it...
Hi, when a message comes up like that, it means your battery is not original and does not work with any charger. You need to replace the battery with an original battery before it will charge.
Take care.
May 21, 2010 | Sony Ericsson Walkman® W995 Cell Phone
I own a 1 year old Dell Studio 1535. Its original battery died, so I purchased a generic one online. When I turned on the laptop with the battery only (not plugged in), it said battery not recognized,but...
A generic Battery should Work fine.
Try going To my computer/Control Panel/Power options.
You should find a battery Icon, for the Battery if it,s recognised in there. select ( show on Desktop ) And refresh The Battery.
New Batteries usually require to be fully charged. Then Discharged ( no-Mains Power ) for the first 3-4 Charges. So that the Computers power Management System, Can guage the Capacity Of The battery Inserted.
Mike @ compurepair.
Nov 06, 2009 | Dell Inspiron 1525 Notebook
Replaced my stator with an upgraded version after bike died on me, Bike started find for a couple days now it is starting to act up,it seems like it is going die when starting then all of sudden it starts....
Check the condition of the battery and the tightness of the terminals. Battery may not be holding a full charge after the original charging problem.
Aug 05, 2009 | 2005 Suzuki Boulevard C90T
My Mp3/Mp4 player dies too quickly! I really dont know why! When it gets done charging it dies in literally 5 min!!!! Help!
just a guess but have u had it quit awhile? or put it to use a lot? [charged it and ran it down a LOT of times] the batterys deteriorate after awhile and depending on the make u may be able to have shop replace the battery.
May 17, 2009 | Samsung YP-K3 MP3 Player
Microtalks won't charge
I have the Cobra Microtalk 4100 FRS radios with charging base. After changing the batteries with new nimh rechargables the charge light would not illuminate and the unit would not charge. I noticed the original batteries had a metal band around one end. This band makes a small connection inside the battery compartment on the first battery. Seems to be a cheap way to ensure you dont try to recharge the unit with non-rechargable batteries installed. I rapped a small piece of tinfoil around one end of the first battery in the new set then popped it back in and now they will charge correctly again. Dont try this with non-rechargable batteries! I would recomend buying original replacement batteries.
Nov 28, 2008 | Cobra Microtalk 100 FRS Walkie Talkie...
New battery not charging
It is normal for a battery to degrade after a year since its a consumable part. It's just like any ordinary rechargeable battery. We have 2 points of failure that might be causing the problem. First the battery itself. Second the Charge board that charges and detects the battery. Given that the NON-DELL battery is working on other dell Computer, it simply tells us that it is the charge board that needs to be replaced wich is integrated to the motherboard. If your warranty is still active, call dell and tell them that you've tried a Known good battery and its still not charging. However, you might also consider that dell computers are designed for dell batteries. the charge board might have problems charging the third party battery since its not configured to do so.
hope this helps.
Demmy
Dec 10, 2007 | Dell Inspiron 6400 Notebook
Toshiba Camileo B10 Camcorder Logo
110 people viewed this question
Top Toshiba Video Cameras Experts
Voros101
Tom Chichester
Are you a Toshiba Video Camera Expert? Answer questions, earn points and help others
