Question about Rival Seal-A-Meal VS106 Vacuum Food Sealer
The seal a meal will vaccume but it will not seal. It just keeps running the vaccum process. Do I need to replace my appliance? Or is this a fixable problem
    New Friend:
It may be that the gaskets are faulty. Vacuum will keep running trying to draw air out before sealing. If that is your problem I've been told you can order replacement gaskets from Rival, about $6/set 1-800-557-4825 and $8 shipping, so may want to stock up (prices were quoted from 2012). this part is not listed in the seal-a-meal website, only available by calling.
Posted on Mar 03, 2015
  • Lynn Marie Kutz
    Lynn Marie Kutz Aug 20, 2016
    If they no longer sell them, insyead of the soapy water soak commenter said company suggested, I wonder if the alcohol and wintergreen soak in this video might work to renew the rubber...
  • 2,113 Answers
You can fix it yourself for $3 or so if you look for the thermal cutoff (a resister looking device) You can get this at a quality electronics supply. If you just cross the cutoff it will work but could be a fire hazard.
Posted on Oct 20, 2013
After hands-free red light for sealing turns on, why does it take a long time to start sealing?
Seal-a-Meal FSSMSL0160-000 Vacuum Sealer - > ... > Vacuum Sealers, Inc.Handy indicator lights for "Hands-Free" and "Sealing", plus Open/Cancel button. Keep your busy kitchen running smoothly with help from this easy-to-use Seal-a-Meal ... With its sleek, straightforward design, the compact appliance effectively ... After completing the vacuum sealing cycle, both the motor and the "Sealing" ...Missing: red Rival Vacuum Sealer: Kitchen & Dining > ... > Vacuum Sealers, Inc.
Rating: 3.6 - ‎233 reviews
Online Shopping for Kitchen Small Appliances from a great selection of ... Rival FSFGSL0150-015 3 Step Vacuum Sealer w/ Bag Starter Kit ... You push down....wait for Hands-Free light & Sealing light to go on....let go....wait for lights to turn off. ...After a couple of bags were done, I started having an issue in which the unit did ...Missing: red FoodSaver FSFRSH0051 FreshSaver ...
Dec 25, 2015 | Kitchen Appliances - Others
Can you make yoghurt using a thermos flask?
it may sound hard to believe but yes, you can make yoghurt but
putting it into a vaccum sealed thermos flask. The vaccume keeps the
milk temperature consistent for hours.Once it sets you can move it to
a different container.
Nov 21, 2013 | Kitchen Appliances - Others
Need upper and lower sealing gaskets for Rival Seal-A-Meal VS107
Sep 02, 2011 | Rival VS107 Seal A Meal Vacuum Food Sealer
I hear a clunking noise in the front of the car and my wife says it sounds like it bottoms out
she is right. replace the vaccum hoses and all rubber connectors that have a vaccum suction to the throttle body and the grommet gasket seals to your intake. should be 4 elbows and three vaccum plugs, and two gromet gaskets (Intake Air sensor & Intake Vaccum). Remember a small crack can cause it to bottom out and stall and probably have poor milage.
Mar 09, 2011 | 2004 Chevrolet Aveo
The small white clip that keeps the nozzle cage dowmn is broken. Can i get it replaced?
Mine broke too.. I contacted Seal-a-meal, and for my machine, they don't make replacement parts anymore. BUT, here's what I did and it works great. I place a chopstick across the length of the lock and seal nozzle...I use a little scotch-tape to hold it in place.. When you shut the lid, it applies enough pressure to the nozzle, to start pulling air out of the bags. I do have to lean or push down hard on the lid, to get it to lock into place, before sealing, but the chopstick works wonderful...I am not going to buy a whole new seal-a-meal when this works so terrific. In fact, I just seal-a-mealed 8 bags of beans this afternoon. Try it before you go out and buy another machine.
Nov 30, 2010 | Rival VS230 Seal A Meal Vacuum Food Sealer
On accel a/c goes from vents to defrost mode engine gets to speed blows thru dash
there is a check valve in the engine compartment area it may not be sealing when there is low vaccum from engine, you will need to repl vaccum check valve. it may be on the vaccum tank.
Aug 03, 2009 | 1998 Ford F150 Regular Cab
What is a heat seal I see one on ebay but say it needs heat seal what are they talking about were can i get one or some for thev3825 foodsaver
the function that seals the bag after the vaccum process (melts the plastic to itself) Hope this helps
Jul 13, 2009 | Tilia FoodSaver V2240
Freezer vaccum seal not working
check the gasket and make sure that it it not pinched and letting in air whe the door closes. primaryly around where the hinges are.;
Dec 27, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
Fridge problems
ngfam1 At your service!
Sounds like a Thermostat problem!
How old is the appliance?
If the appliance is 10 years old or more you may not be advisable to put good money into bad! New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
You need a hands on tech for this repair!
Below I referred you to a great service nation wide!
If none of these tasks remedy the heat problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
Aug 19, 2008 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
I own 2 of the vs220 seal-a-meal units one of which worked ok with the bags that came in it and the second is a hit and miss unit. Both were purchased at walmart. I have tried to use the last one that i...
I too bought my seal a meal at Walmart. I have gotten it to work twice. The main problem is it won't seal. I really think it has to do with the black seals....If I pull them up it sometimes will work. It is really frustrating. I would take it back but have mislaid my recept:(
Apr 12, 2008 | Refrigerators
Rival Seal-A-Meal VS106 Vacuum Food Sealer Logo
1,464 people viewed this question
Top Rival Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Ric Shull
Ric Shull
Level 1 Expert
Craig Butler
Craig Butler
Are you a Rival Kitchen Appliances - Other Expert? Answer questions, earn points and help others
