Question about Fujitsu Siemens Computers & Internet
My Fujitsu siemens laptop is going on off on off and the power,numlock,caps-lock and sometimes the sleep LED's are blinking
    New Friend:
    Problem Solver:
  • 8 Answers
Sounds like a hardware problem and that means it could be one of many components that may be malfunctioning. Look at these::
If battery power, battery may need replacing. Remove the battery
If mains power, could be a faulty a/c adapter or a break somewhere in it's cable. Try a replacement
Posted on Oct 13, 2013
sandrew
  • 2961 Answers
SOURCE: Unable to start my Laptop (Acer Ferrari 3400)
This could indicate power or motherboard failure, you are wise to e-mail the acer technical dept. http://support.acer-euro.com/request/uk/index.html
Posted on Jan 05, 2007
Exidous
  • 63 Answers
SOURCE: Fujitsu Siemens Amilo Pro V2055 laptop power on problem
Check to see if the ram is securely in place. (that will cause a pc to not boot, usually there is a beep code tho)
Posted on Oct 06, 2008
  • 73 Answers
SOURCE: fujitsu siemens amilo L1300 LAPTOP wont load up
sounds life the start up files have been corupted you may need to reinstall windows. the only thing is it will delete and data you have on the labtop. if you dont mind about that reinstall windows of the reinstalltion cd.
Posted on Mar 25, 2009
  • 31 Answers
SOURCE: laptop doesnt wake up after sleep mode activation
sound slike hard drive is going ...go into settings and turn off sleep mode and also set it to hard drive NEVER shuts off
Posted on Dec 12, 2009
SOURCE: my fujitsu siemens amilo notebook screen black.
Check num lock key of laptop press num lock if numlock key is on and off when you press it then dispaly working fine only issue with screen resolution .
For that when you power up the computer press F8 key then enter in enable vga mode.
Then go to start menu ->control panel->display->settings.
Change screen resolution to 1024*768 then apply and ok.
But if num lock is constant when you press numlock key then you need to refix RAM memory.Open back cover of laptop then refix RAM memory.
Then check if still same issue then pull cmos cell from motherboard then check again if still same then try with another RAM .
When you power up the computer press F1 or F2 or "del" key if you are able to see bios screen then you not need to open back cover of laptop only make sure SATA is disabled and your harddrive is detected in bios.
Let me know if you need further assistance.
Thanks for using FixYa.
Posted on Dec 19, 2009
Turn off snooze function
I'm a bit confused by your terminology, "snooze" function? We are talking about a Fujitsu Siemens LifeBook A Series Laptop, Correct? If your referring to the Sleep or Hibernate settings, Open the Control Panel, select Power Options, you didn't post your OS, so here's a Win 7 solution, set to High Performance, select Change Plan settings, under Plugged in, set Display time and set Sleep to Never, select Change Advanced power settings, go through the settings one by one set to your preference. Sleep and Hibernate to Never.
Apr 25, 2013 | Fujitsu Siemens LifeBook A Series Laptop...
Fujitsu lifebook s6520 is not comes ON when i press the power button the lifebook comes ON its all LEDs & processor fan sound is listened but then just NUMLOCK led starts blinking after that blinking...
Is the monitor working. If have not checked it try connect it to an external screen. If the screen is okay, try and remove memory (RAM) and after ten seconds you place it backup and start the computer and check.
Dec 06, 2012 | Fujitsu LifeBook S6520 Notebook
My laptop screen is black and caps lock and scroll key are flashing
That is a security configuration on HP Laptops, depending on the way they blink is the problem your machine has.
Here is the web page where this info is posted, in case you need more info, hope this helps you to determain.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01443366&lc=en&dlc=en&cc=uk&lang=en&rule=26781&product=3816592
This document pertains to HP Notebook PCs with the HP Unified Extensible Firmware Interface (UEFI) beginning in late-2008. On startup, you may see a blank screen. If the diagnostic utilities detect a specific problem with hardware components, the fan turns on, but the screen remains blank. To help identify the cause of the problem, various LED lights on the keyboard blink a series of codes. The diagnostic utilities use the LEDs near the Num Lock or Caps Lock keys to blink a series of error codes. At the end of the series the blinking stops. The pattern of blinks will occur any time you attempt to start the computer until the error is resolved. Battery power LED blinks The Battery power LED indicates the condition of the power supply. When starting the computer, or when the computer is in operation, use the chart to identify the power condition. Battery Power LED Component Tested Error Condition Battery power LED off, and Caps Lock/Num Lock off Battery or AC Adapter AC adapter not connected or failure
Battery low charge or failure Battery power LED blinking Battery Insufficient charge on the battery When new computer is used for first time, the white LED light for the AC power connector blinks. Battery is still in "Shipping Mode", the light continues to blink even when AC power is connected.
To resolve, turn off notebook, connect AC power and allow battery to charge for at least 30 minutes, then start computer. LEDs near Caps Lock and Number Lock keys blink when starting notebook The LED lights near the Caps Lock and Num Lock keys will blink if an error is detected during the start up process. The LEDs will blink a number of times in a sequence and then stop. The number of blinks in the sequence indicates what component caused an error when it was being tested during start up. If the LEDs stop blinking and the computer does not start, you can press the power button again to repeat the tests. Count the number of blinks, and use the chart to identify the error condition. Knowing the number of blinks is helpful when you contact an HP support agent for technical help. Caps Lock/Num Lock LED Component Tested Error Condition LEDs blink 1 time CPU CPU not functional LEDs blink 2 times BIOS BIOS corruption failure LEDs blink 3 times Memory Module error not functional LEDs blink 4 times Graphics Graphics controller not functional LEDs blink 5 times System board General system board failure LEDs blink 6 times BIOS BIOS authentication failure
Dec 01, 2011 | HP Computers & Internet
The capslock and the numlock leds r flashing continously. the screen is blank
How many blinks between pauses if there are pauses? Look at this chart.
Number of Blinks or Beeps Location of Blinking LEDs Component Being Checked Error Condition Continuous glow Battery power LED Battery The AC adapter is attached and the battery is charging, but does not yet have sufficient charge to power the notebook. 1 Caps Lock/Num Lock CPU CPU not functional 2 Caps Lock/Num Lock BIOS BIOS corruption failure 3 Caps Lock/Num Lock Memory Module error not functional 4 Caps Lock/Num Lock Graphics Graphics controller not functional 5 Caps Lock/Num Lock System board General system board failure 6 Caps Lock/Num Lock BIOS BIOS authentication failure Continuous blink AC power adapter LED Power adapter Insufficient power
Jun 30, 2011 | Compaq Presario Notebook
Laptop Not booting up, Scroll Lock indicator blinking
Your user guide might provide a mean to interpret the meaning of the blinking Scroll Lock Indicator...
May 09, 2010 | Fujitsu Siemens LifeBook® S7110 PC...
3 others indicators start blinking !
Dear friend,
Just follow the instruction.
1. After press power button for turn on press F8 key.
2. You will find few option there. Just select these mention option " Last know good Configuration ...." use by your up/down arrow on your keyboard.
3. Press enter there.
4. your will see the system asking you for which OS you want to use. If you have only one OS then just press ENTER there or select the OS and enter.
Then just wait and watch what's is going. If the same problem then contact me again here in Fixya i will give you another way to solve the problem. Thanks.
Feb 03, 2010 | Fujitsu Siemens LifeBook S7020D Notebook
My fujitsu siemens amilo notebook screen black.
Dec 19, 2009 | Fujitsu Siemens Computers & Internet
Indicator LED blinking, no display on Fujitsu Siemens L19W-2
I've got the same situation. I think it is old enought to break. I just can't turn on the light behind the screen.
Jun 15, 2009 | Fujitsu Siemens Business Line E18-1 18.1"...
Can't find the caps lock key on my siemens notebook
it is always at the left of "A", i think it is not marked
Dec 08, 2008 | Fujitsu Siemens AMILO Pro V2010 Notebook
I live in London E8 2NH and got a problem with the keyboard on my laptop Fujitsu-Siemens Amilo Pro V 2040. I strungle find a local service/repair shop.
install keybord driver properly.
if u have keybord hardware pro.then u must have to go shop.
also check tab.num lock shift caps lock not jamming.
all key check .
Oct 11, 2008 | Fujitsu Siemens Computers & Internet
Computers & Internet Logo
189 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
