Question about Tablets & eReaders
I downloaded a song I want to use as ringtone. How do I set it as ringtone?
Reset zte maxx
Master reset from settings menu
A master reset restores the original factory settings and may delete your personal data on the internal storage, such as downloads, ringtones, images, apps, contacts, and Visual Voicemail. It does not delete data stored on the SIM card or SD card.
  1. From any Home screen, tap the All apps icon.
  2. Tap Settings.
  3. Scroll to the 'PERSONAL' heading, then tap Backup & reset.
  4. Tap Factory data reset.
  5. Tap Reset phone.
  6. If your phone is password protected, you'll be prompted to enter your Pattern, PIN, or Password.
  7. Tap Erase everything.
Master reset with hardware keys
If the device menus are frozen or unresponsive, you can master reset using hardware keys.
  1. Back up data on the internal memory.
  2. With the device turned off, press and hold the Volume Up and Power buttons until the ZTE logo screen appears, then release.
    Press the Volume down button to highlight wipe data/factory reset.
  3. Press the Power button to select.
  4. Press the Volume down button repeatedly until Yes -- delete all user data is highlighted.
  5. Press the Power button to select.
  6. Wait as the device resets.
Nov 28, 2016 | Tablets & eReaders
Tip
How to Remove Songs from iPad in 3 Ways
Part 1. Delete Individual Songs from iPad
Step 1. Launch the Music app on your iPad.
Step 2. Tap "Songs" on the bottom to see all of the music on the device. Choose the individual track you want to delete and slide your finger to the left across the songs.
Step 3. Tap on the red "Delete" button to remove music from your iPad.
Part 2. Delete All Songs from iPad
Step 1. Go to the iPad's homepage and tap on "Settings" icon.
Step 2. Tap "General" > Select "Usage" > Choose "Music." The iPad will display how much space is taken up by music on your device.
Step 3. Tap "Edit" button on the top-right > Tap the red icon next to All Music > Tap on "Delete" to remove all songs from iPad.
Part 3. Delete Selected Songs from iPad with AnyTrans
AnyTrans is an all-around iOS files manager that made to transfer and manage all your iPhone, iPad, and iPod content, such as, music, videos, photos, contacts, notes, messages, apps, etc. You can freely add or delete songs from your iPad with AnyTrans.
Step 1. Download and install AnyTrans on your computer. Run it, and connect your iPad to computer.
Step 2. On the homepage of AnyTrans > Click "Audio" > Select "Music".
Step 3. Highlight the songs you want to delete and click the trash icon on the top-right of this window to delete the unwanted songs.
Resource from: How to Delete Music from iPad
How to Delete Music from iPad in Three Ways
on Feb 11, 2015 | Apple iPad Tablets & eReaders
Can't download songs all of a sudden. Says check file configuration and I have no idea what that means. Help please!
means the file wher your songs used to down load to has been deleted or moved if you like i could fix for you free of charge just let me know
Jan 28, 2014 | Apple iPad (16 GB) WiFi Tablet PC
Google play
I'm an artist and have 20 songs on my album: ALL ABOUT LOVE by Sylvia. I downloaded a few songs for my friends and when I go to my album I can only listen to those songs I downloaded. But when other people go on, they can download every song, is that correct? Thank youl,
Jan 01, 2014 | Tablets & eReaders
How To Unmute Sound
tablet setting icon gear shape has sound display option from ringtones to touch sound.And volumes,increase bar section on volume to maximum to enable sound in case it was disable.
May 09, 2013 | Acer Iconia Tab A200-10g16u XE.H8QPN.001...
After music download, Asus Trans only selects some songs to export to music files. Why
Some of the songs may be in the wrong format for the tablet. Check the file extensions on them to see if they are all the same.
May 23, 2012 | ASUS Transformer Tf300t Tablet Keyboard...
Master reset htc phone
Hard or master reset
A hard reset restores the original factory settings and may erase all downloaded content, including ringtones, images, programs, and contacts stored in the internal memory. To perform a hard reset, follow these steps:
  1. Back up all necessary data by copying any files you want to save from your phone to your computer.
  2. From the Start screen, swipe left.
  3. Tap Settings.
  4. Tap about.
  5. Tap reset your phone.
  6. Tap yes.
Hard or master reset using hardware buttons
If the phone is locked, frozen, or unresponsive, you can hard reset it using the hardware keys instead of the menu. A hard reset restores the original factory settings and may erase all downloaded content, including ringtones, images, programs, and contacts stored in the internal memory. To perform a hard reset using hardware keys, follow these steps:
  2. With the phone turned off, press and hold the Volume Up and Volume Down keys.
  3. While still pressing the Volume keys, quickly press the Power/Lock key.
  4. When the device displays 'This operation will delete all your personal data, and reset all settings to manufacturer default. Press Vol Down to restore manufacturer default, or press other keys to cancel.', release the Volume keys.
  5. Press the Volume Down key to reset the device.
Dec 08, 2011 | HTC HD Windows Phone 7
How do i download songs from itunes to my mp3 player
iTunes song have DRM protection, you have to remove DRM from iTunes and convert M4a to MP3.
Mar 31, 2011 | Archos 28 Internet Tablet
My phone samsung champ c3303.i have problem i install song in membry card but should not see & open in my file.
hi if you cannot locate this song in your file or will not play ,more than likely you have downloaded a virus i would recomend you delete this file goodluck
Mar 21, 2011 | Dell Tablets & eReaders
Tablets & eReaders Logo
13 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
