Question about Maytag Dishwashers
I have a maytag dishwasher model #mdb7749awb2. The cycle buttons on the left do not light. The options buttons do light. Washer will not start on any cycle. Door switch id good. There is 120 t0 the main board. What else can I check. Want to make sure it is the board before I order. Thanks
4 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: maytag dishwasher shuts off during cycles
thats what it soundslike to me here aoart number which is the entire assy w/both switches included 99002254 retails for about $25
Posted on Nov 05, 2008
  • 338 Answers
SOURCE: Maytag Dishwasher Doesn't Start
on a dishwasher an ohmmeter is almost useless. the best way to check is to look for voltage. at the door switch check for voltage to ground on both sides. if you have 120 on both sides of the switch then follow the wire over to the control board. if you have 120 going into the control board and nothing coming out of the control then you nood to start looking for a broken neutral. however the likelyhood that its the control panel may be a better idea especially if you are hitting buttons and nothing happens. try reseating any ribbon cables
Posted on Nov 25, 2008
Macmarkus
  • 2605 Answers
SOURCE: the dishwaser quit in the middle of a cycle, left
Hello, welcome to FixYa.
I understand by reading your post which indicates it is a Kenmore dishwasher you appear to have a concern with no power to the control, yet it does get power to the machine, however if you could provide the model number I'd be better equipped and most certainly able to help without generalizing.
The one thing I'd suggest is the thermal fuse. You mentioned you replaced the control board, but typically the symptom you've described is associated with a bad thermal fuse.
(part #675813 for the closest model I found to Kenmore 13593...but that's only a partial model so I wouldn't declare it 100% until knowing)
Hopefully you can appreciate there are many variations of dishwashers even within the "Kenmore" brand name machines. I'll watch for your reply and try and help going forward. Thank you.
Regards,
Macmarkus :)
Posted on Aug 23, 2011
Kenmore ultrawash diswaher model 665.1374 cycle and options buttons light up but start button does not light and diswaher does not start. please help
Check that the door is closing all the way and that the latch isn't damaged or bent. It sounds like a door switch issue.
Apr 04, 2015 | Kenmore Dishwashers
Reset button maytag dishwasher
  • 1 Open and close the dooricon1.png of your Maytag dishwasher.
  • 2 Locate the "Rinse" button on the dishwasher control panel. Press and release the button five times in quickicon1.png succession.
  • 3 Press and release the adjacent "Drain/Off" button on the control panel two times; this will deactivate the dishwasher's demo mode and reset your dishwasher.
  • If you need to restart your dishwasher or forgot some dishes and want to open it during a cycle and restart it
  • 1 Press the "Cancel Drain" button on the display. Allow about 2 minutes for the dishwasher to completely drain.
  • 2 Choose a cycle under "Cycles" on the panel.
  • 3 Select an option or options under "Options" on the panel.
  • 4 Push the "Start Resume" button.
  • Oct 24, 2013 | Dishwashers
    Heated dry cycle light on
    see the cause and fix it:God bless you
    Failure Code Condition Check/Repair "L" persists in washer display Lid lock failure Replace switch, linkage, lock solenoid or control board.
    Jul 21, 2012 | Maytag Quiet Series 300pan Dish Rack...
    Don't seem to have any power,cycle and option panel won't light up.
    Check your outlet, cord connections and cord first. If they are all good, you most likely have a bad board. But that is pretty unusual for this model Maytag. My money is on the cord connections to the dishwasher (behind kick panel bottom left).
    Jun 12, 2010 | Maytag 24 in. DWU9902 Built-in Dishwasher
    Maytag Quiet Series dishwasher won't start
    Sounds like you have a bad Control Board
    http://www.partstore.com/Part/Maytag/Maytag/MDB6600AWW/Maytag/Maytag/99003160/New.aspx
    But with the price it cost, you might be better off buying a new dishwasher, preferably a different brand, cause that washer has some bad reviews
    Oct 12, 2009 | Dishwashers
    Water is not coming into my Maytag dishwasher.
    Is the door open or unlatched?Make sure the door is completely closed and latched. On models with a dual-digit display, the control displays "- -" during a cycle if the door is not latched. Check for obstructions (spoons or utensils), that may be interfering with the door operation. A lower dish rack that is installed backward will also cause incomplete door closure. The lights for cycles selected will flash if the door is opened while running a cycle.
    Is there power to the dishwasher?Check your household electrical box to see if a fuse has blown or if the circuit breaker has tripped. If the unit has a plug-in power cord, make sure it is plugged in.
    Does your dishwasher have a rotary timer knob?The cycle selection must match the position of the timer knob. Turn the timer knob to the beginning of the preferred cycle. The timer knob should click when you reach the start of the cycle.
    Is the control lock option activated?
    The indicator light next to the lock graphic will illuminate when the controls are locked. Press and hold the Heated Dry option (button with lock icon) for three seconds and the light should turn off. Instructions are also placed on the label on top of the inner door to unlock the controls.
    Is the delay start option activated?To cancel the delay and cycle, press Start/Cancel twice.
    Is the water shutoff valve turned on?Make sure that the water shutoff valve is turned on.
    Mar 03, 2009 | Maytag 24 in. MDB6600A Jetclean II...
    Maytag dishwasher shuts off during cycles
    Nov 05, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
    Maytag quiet series model #:MDBH950AWB
    The dishwasher lights are all blinking, it starts randomly, like one in every 50 times you press the buttons. I have unplugged it to reset several times. Nothing is working. I'm looking for a solution to blinking lights and it not starting. is there any other way to reset the controls????
    Jan 13, 2008 | Maytag 24 in. MDBH950AWS Built-in...
    Dishwashers Logo
    105 people viewed this question
    Top Maytag Dishwashers Experts
    Mike
    Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
