F8 error coming and ac not starting - Heating & Cooling
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 53 Answers
This is due to room sensor problem,
Posted on Oct 15, 2013
Voltas ac error code F8, what's the problem & how to solve f8
What is the model of your air conditioner. With out that information i cant help you with your ac repair problem. If you need any other Air Conditioning Repair help. Check us out online.
Jul 25, 2016 | Heating & Cooling
Hey I want to know how to fix my whirlpool frontloader showing error f8 when I turn it on a couple of seconds like no water going through the tube and f8 comes up help please.
Hi Takai
Don't know the Machine or the Code but...
To start a washing machine cycle... the water should start filling the machine.
So...Is the Tap turned on? Can you hear the Water hose Solenoid Click In (to open the water valve)? Is water flowing?
If not... here is where you would start tracing the problem.
(Very similar to your Lawn Sprinkler Solenoid... the only difference is 24v AC vs 110 or 240V AC)
Most washing machine problems occur because of the many mechanically actuated switches and solenoid valves. The Electronics is usually good. When a switch doesn't respond it is picked up by the electronic controller & displayed as an error code on the front.
(CAUTION.... 110 to 240VAC is lethal especially around water)
So.... if you don't have the ability to remove the cover & check for faults you will probably want to call the qualified washing machine repair guy.
Cheers
TJ
Feb 19, 2015 | Whirlpool Washing Machines
F8 error split air conditioner
F8 error isn't registered with my Daikin Airconditioner, though E7 showed up as a 'motor over-current' warning.
It might help if you find out the NAME and the MODEL NUMBER for your air conditioner.
Once you know this, then you can search for it like this...
Name - Model - error codes
E.g. 'Daikin Ft18k error codes'
Oct 06, 2014 | Computers & Internet
Error F8 on a Frigidaire AC model FASE24C6****
Good Afternoon Konrad,
I understand that you are receiving an F8 error code on your Frigidaire air conditioner, model# FASE24C6. I also see that it will work for hours before displaying F8 or sometimes only minutes before displaying the error code. The F8 tells me that there might be a key stuck. I suggest resetting your air conditioner, by unplugging it for 3-5 minutes. Plug your appliance back in and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your air conditioner status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 08, 2014 | Frigidaire Heating & Cooling
F8 display
sensor error , replace sensor by new one , problem get fixed,
Oct 11, 2013 | Heating & Cooling
I have a voltas vertis AC ! It's showing me a F8 error the AC just won't work however the remote is working
please call their help line with this issue as i have not seen that error code before and i suspect it's a bad controller board.
http://www.voltasac.com/index.php?option=com_forms&view=pages&layout=contactus&Itemid=62
their numbers are 1800-425-4555 and 1800-266-4555
good luck.
Oct 14, 2012 | Heating & Cooling
What will i do to my hp mini notebook it has a power but it cannot booth
Perform a Hard Reset Do these actions first to clear all temporary setting before troubleshooting the problem.Disconnect all peripheral devices and remove all USB devices and media cards.Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds to drain residual charge.Reconnect the AC power adapter (do not connect the battery), press the Power button and look for the LEDs to blink or glow, and listen for the sound of a disk drive and fan turning.Perform each recommended corrective action and then attempt to restart the computer.Symptom 1: LED lights do not glow, display is black, no fan or drive sounds are heard, and computer does not startIf LEDs do not glow or blink when AC power adapter is attached and power button is pressed, there is no power available to the notebook Check AC adapter wiring and power connection to the notebook Connect a different AC power adapter and remove battery, then restart notebook.Connect a different battery and disconnect AC power adapter, then restart notebook Symptom 2: LEDs blink or computer beeps but does not start Blinking LEDs or beep tones indicate a hardware failure during the pre-start up testing Count number of blinking LEDs or beeping tones to help with diagnostics testing Symptom 3: LEDs glow, fan noise may be heard briefly, display remains black, and computer fails to startup or boot Usually occurs if a component is installed incorrectly, or there is a device conflict or failure Connect an external monitor to check if the problem is the built-in LCD display or graphics card Remove all CD/DVDs, SD cards, USB devices, peripherals and do a Hard Reset If memory or hard drive components were replaced, reinstall original component Remove memory modules and replace one-at-a-time Remove and reseat hard drive If possible, turn on power, press F10 to enter BIOS mode, and run Memory Test and Hard Drive Test On newer notebooks, turn on power, press Esc to enter UEFI mode, and run Memory Test and Hard Drive Test If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Repair Computer option, or enter Safe Mode and run Memory Diagnostics If all other methods fail , but computer can boot to BIOS, use recovery disk to recover the computer to original condition Symptom 4: Computer may display an error message on a black screen during startup or boot Search www.microsoft.com for terms in error message Search www.hp.com for terms in error message
  • If possible, turn on power, press F10 to enter BIOS mode, do the corrective actions listed under Symptom 3 to run memory and hard drive tests.
  • Symptom 5: Computer displays a blue screen or continually re-starts After an error message is displayed, you can usually bypass the error and continue to run the notebook in Safe mode to install an updated BIOS or driver.
    • Search www.microsoft.com for terms in error message.
    • Search www.hp.com for terms in error message.
    • If possible, turn on power, press F10 to enter BIOS mode, and run diagnostic Memory test and Hard Drive test .
    • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and do one or more of the following:
      • Select Disable automatic restart on system failure to view error message.
      • Run Repair Your Computer .
      • Run Last Known Good Configuration .
      • Select Boot into Safe Mode and then select Run a Microsoft system restore .
      • Select Boot into Safe Mode and then select Uninstall recently installed programs .
      • Select Boot into Safe Mode and then run Windows Update .
    Symptom 6: Computer displays the Windows logo screen and stops responding If no error message displays, turn on power, press F8 to enter Windows Advanced boot options ,and select Disable auto-restart to view error message.
    • If possible, turn on power, press F10 to enter BIOS mode, and select Restore the BIOS defaults (F9) .
    • If possible, turn on power, press F10 to enter BIOS mode, and run Hard Drive Test .
    • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Last Known Good Configuration (Advanced) . .
    • If possible, turn on power, press F8 to enter Windows Advanced Boot Options , and select Boot into Safe Mode and then Uninstall recently installed programs .
    Update Computer After Resolving A Problem When the computer starts into Windows normally, you should install the latest updates and patches to prevent other start-up problems.
    Oct 09, 2011 | HP Mini 1000 Netbook
    F8 error
    F8 on tamashi ac
    Jul 03, 2010 | LG Heating & Cooling
    Wont start up.
    Have you tried booting windows into "Safe Mode"?
    1. Power ON your computer.
    2. After the Acer "splash screen" comes on, press the [F8] a few times (10 times or so, to "catch" the menu)
    3. A menu will appear.
    4. Select "Start Windows in the last known good configuration" (or something very close to that wording).
    5. It may start for you now; and it will start normally from now on without pressing the [F8] key.
    Let us know if thjis worked.
    If not, what was the last thing that was done before it quit working right? Download? Install a program? Remove a program??
    Sep 20, 2009 | Acer Aspire 5315 Notebook
    Heating & Cooling Logo
    21 people viewed this question
    Top Heating & Cooling Experts
    Paul Carew
    Dan Webster
    Dan Webster
    Donni Steen
