Question about Dryers
Dryer vibrating alot and making alot of noise.
Our dryer (Frigidaire Gallery) seems to be working really hard the last day or two. There is alot of vibration and noise (like a humming sound. The drum is rotating the clothes and the clothes are drying. Please help! Our dryer is only 5 years old.
  • Chigal74 Apr 23, 2009
    The felt inside the door feels fine. We had problems last week with our dryer not drying. So, we pulled it out, took apart the coil from the dryer and the wall and cleaned out the coil and the aluminum connecting to the outside. There was a lot of lint clogging it. We also cleaned the lint trap and used a large lint brush to clean the inside of the lint vent (where the line trap goes down into). Could any of this caused a problem with how the dryer now sounds. Could we have hit something or messed something up when cleaning the dryer vents (and lint trap area) with the large lint brush? The noise and heavy vibration didn't start until after we just did all of the above.
  • 113 Answers
Check the felt around the inside of the door to see if it needs to be replaced
Posted on Apr 23, 2009
Frigidaire gallery dryer making loud thumping noise
IF you have an uneven load this can happen, If the dryer has shifted in position and is no longer LEVEL or the feet have changed their distance leaving a gap or open space. The dryer can also move from vibration and be leaning against a wall or the washer next to it. Check that first, and if none of the above, then the drum may be misaligned. A belt could stretch. The shaft of the drum fits into a connecting part that may be worn and out of round or bearings are worn.
Feb 05, 2018 | Frigidaire Dryers
Run but makes a vibration noise ,leave off awhile noise goes away
Hey Steve, I appreciate your post!
From the information you have provided your Frigidaire dryer runs properly and makes a vibration noise. This could be due to leveling within the dryer and I would suggest checking to make sure the dryer is leveled. You can do that by using a leveling tool, these can be found at a local hardware store. If your dryer is leveled I would recommend having a technician out to make sure the motor or drum are operating properly. I hope this information is helpful to you. -Matt
Jan 12, 2016 | Frigidaire Dryers
How to fix a Frigidaire Gallery Commercial Heavy Duty
Good Morning Friend,
I understand your Frigidaire dryer, model# GLER642A, is making a thumping noise when running, and you want to know how to fix this. Typically, this is not a do it yourself repair, as there are no step by step instruction manuals. I suggest contacting your local authorized technician. They will be able to diagnose your appliance and determine what is causing the thumping noise. Hope this is helpful.
-Best Regards-
WP
Jul 07, 2014 | Frigidaire GLER642A Electric Dryer
Frigidaire electric dryer front load . Bad vibration
Good Afternoon David,
I understand you are receiving a bad motor vibration on your Frigidaire dryer. I see that you replaced the fins on the blower, only to have them break again. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine what is causing the vibration noise, as well as the blower fins to break. Hope this is helpful.
-Best Regards-
WP
Jul 02, 2014 | Frigidaire Electric Dryer
Makes a ticking or clicking noise when dryer is on. How can I fix it? The heat and tumbler still works though.
Hi Lisa, thank you for your post!
Based on the above-listed model number, FEX831CS it shows you have a Frigidaire laundry center. However, you mentioned that it is a gallery series. So do you have a laundry center or a Frigidaire gallery dryer? In order to better address the issue, what is your model number? You can typically locate the serial tag, which lists your model number, on the right or left edge on the inside of the door. How often do you hear the ticking or clicking noise? With this information I can better assist you. Thank you!
Dec 12, 2013 | Frigidaire FEX831CS Top Load Stacked...
FWT445GES1 Washer makes loud banging noises like it's going to explode.
Washer- you need a complete tub and bearring kit. this is a common problem for people who have well water. (also just happens) the rear yoke has become corroded and broken. its a costly repair.
dryer - you would need a new front slider seal. very simple to install.
May 28, 2009 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Dryer making clicking sound, humming and vibrating hard
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up "
Apr 23, 2009 | Frigidaire GLGR331A Gas Dryer
Grinding noise when running
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
gdhjh
Apr 17, 2009 | Frigidaire FSC23F7DSB Stainless Steel Side...
Frigidaire Gallery dryer SMELLED like Burning rubber.
Reach inside and try to turn the drum. If it seems hard to turn then your glide kit (Part#5303937139) may be in need of replacement:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 10, 2009 | Dryers
Vibrating and noise after cleaning
heatman101
ioipuio
Jan 04, 2009 | Frigidaire FDE336RE Dryer
Dryers Logo
304 people viewed this question
Top Dryers Experts
