Question about Briggs & Stratton Garden
Pressure washer will not stay running - Briggs & Stratton Garden
This boy built pressure washer is a great big piece of s----, do yourself a favor and find the nearest trash receptacle and toss it, forget all the other solutions offered this is garbage... Good luck Terry
Posted on Nov 25, 2013
Troybilt pressure washer
Check the oil level. Yours may have an oil sensor switch.
May 26, 2013 | Troy-Bilt 2700 PSI 2.3 GPM Gas Pressure...
Pressure gauge needle stays in max position running or not. otherwise pressure washer operates normally.
Pressure gauge is probably "sprung". Unless it bothers you, ignore it. Even expensive industrial pressure gauges fail regularly - I have seen a truck load worth of them (all brands and types) that read pressure even after being disconnected from pipe or tank, and the gauge on a pressure washer is anything but an expensive one.
May 07, 2010 | General Easy Bolton 4 Gpm3500 Psi ...
I have a problem with my karcher 2500 pressure washer with honda engine it will not start or stay running. I have used starting fluid to start it it starts but won't stay running.
Carb is mostly likely gummed up and should be cleaned. Best option is to dismantle the carb and soak in solvent or equivelant for a couple hours and replace it. Our use Gum Out. Do make sure you have a good spark plug and a strong spark. If you have a fuel filter, then replace it. Check intake filter as well
Aug 05, 2009 | Karcher 2500 PSI Pressure Washer
Washer want stay running. I can pull choke and it
mr fixit, I have pressure but it just want stay running
Jul 11, 2009 | Garden
Pressure Washer Engine will not stay running
My Kracher 2500 pressure washer has no pressure unless I remove the nozzle. If, I remove the nozzle and pump the trigger several times and quickly replace the nozzle it works fine until I release the trigger. Karcher (online) suggested I remove and clean the unloader which I did. It still doesn't work correctly. What another solution?
May 29, 2009 | Garden
It won't stay running
You need to either clean the carb really good (take it apart) or rebuild it or both. Sounds like your needle is gummed up and not letting fuel through.
May 29, 2009 | Honda Pressure Washer PSI 3000
Karcher 2600 psi pressure washer wont stay running
Remove and clean the carburator. Sound line a stuck needle on the float.
Apr 22, 2009 | Karcher 2500 PSI Pressure Washer
Won't run with air filter on
I have a fairly new pressure washer with the same problem and discovered that because it was temporarily stored on its back (rather than upright), oil seeped into the air filter housing. If you look at the air filter it may not look like it has oil on it - especially if the oil is new. Mine runs fine without the air filter, but as soon as I put it in, it does the same as yours. I came across this site since I am looking to order a new filter. Hope this helps.
Jul 09, 2008 | Karcher 2500 PSI Pressure Washer
Garden Logo
51 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
