Question about Neff Refrigerators
My NEFF Fridge Freezer (K4255SC) is leaking a bad smelling brown oily fluid into the back of the fride compartment that taints the food. What is this and what should I do.
  • 69 Answers
SOURCE: noisy F&P fridge freezer
Most of f&p make this noise its most annoying, but could also be ice buildup on the fan blades, creaking and cracking is normal as the pipes expand and contract is these thin foamwall fridges, not nice fridges, insulation has been compromised to lower cost, they work twice as hard at keeping cool
Posted on Sep 23, 2007
  • 143 Answers
SOURCE: Neff K3990 Fridge Freezer ice maker not working and water leaking out
Sounds like the water hose to the ice maker has come loose. Is it in warranty?
Posted on Jul 23, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: fridge is leaking from freezer to top shelf
This is the drain tube that runs in the back of the freezer on the bottom is pluged. Take a sprayer with some hot water in it and flush out the system. Remove the food so that you dont get any of the stuff on it.
Posted on May 21, 2009
meBNme
  • 334 Answers
SOURCE: I've punctured a hole in the lining of the freezer
It sounds like you have punctured the evaporator coil and it is leaking refridgerant.
That would certainly cause the unit to be low on refridgerant which would cause it to start warming up, and becoming louder. It would also explain the smell.
If the unit is fairly new it *may be worth repairing, You will likely need a new coil.
Expect costs in the 300 to 500 range.
I reccomend getting a secondary place to store the food, and unplugging the unit emediatly if you want to have it repaired.
The reason for that is because the compressor is likely undamaged at this point. but if it runs on empty it will soon fail and then you can double the repair price or more.
Posted on Aug 26, 2009
iwillfixforu
  • 619 Answers
SOURCE: Pooling of water in fridge compartment of my Neff fridge/freezer
The defrost drain is clogged. Defrost drains usually get there clog right behind the back freezer panel. Remove this to get to the defrost drain and remove all built up ice and clear the drain and you should be fine. Hope this helps.
Posted on Feb 04, 2010
The fridge and freezer smell like a dead animal. cleaned the inside with bleach but still smells for weeks. model w10212088
There are two reasons for bad smells. 1. Long time not being used. 2. Lack of cleaning inside compartment.
Solution: Unplug fridge. Keep open fridge door. Dip a dry cloth in soap water and start cleaning each and every compartment. Keep freezer door also open. And then clean with another dry cloth. Keep both doors open for nearly 5 hrs. It will be enable fresh air to **** the smell inside fridge.
After 5 hrs close the fridge and run on empty for one hour. Keep food items after one hour. Please keep all food items closed vessel. Not only it's avoid odor but also be hygienic.
If you use to keep fish items in freezer, clean fridge once in a week.(Spray roo spray in the room when you keep fridge door opened. Don't spray into fridge.)Helpful.
Jan 30, 2011 | Whirlpool Refrigerators
Thick brown liquid at leg of of refrigerator
the thick brown liquid is decomposing moss, from the condensate inside the unit finding a way out.(think of it as the same stuff you get around a shower tray)clean out the fridge using clorine bleach and dry thoroughly....leave the door open for the clorine to gas off otherwise it will taint the food.when the smell has gone then close door and switch on.(some people use milton fluid,but clorine kills all known germs....)
Jul 16, 2010 | Hotpoint FFA60 Bottom Freezer Refrigerator
I know this is strange but here goes. I have a Kenmore Coldspot side by side Refrigerator. This past summer, it was leaking water out the front freezer door. We turned off the water and called a repair...
Turn off the fridge. Remove the freezer bins in the bottom. Defrost the drain line with a hair dryer.It is on the lower back portion of the freezer. Break up the ice on the freezer floor and dispose of it.
Discard any old freezer food. Change out the water supply line with a copper line if you are using a plastic line.
Dec 23, 2009 | Kenmore Refrigerators
Fridge smell
check the pipes at the back of the fridge, it could be that one of the pipes has a crack and is leaking gas or oil. If not check the inside of the fride for a brown oily residue. This indicates a leak. Don't turn the fridge back on becasue if the oil and gas mix then the fridge will no longer be usable. If you find either of these get an engineer to fix the problem.
Oct 25, 2008 | Frigidaire FRS26R4A Side by Side...
There is a smell coming from the back of the fridge freezer,its a funny smell,sometimes you can smell it inside the fridge too, it seems to get stronger when the fridge is cooling more(as its a frost free...
I presume you have a house hold fridge if so you could be smelling a freon leak. It is a repulsive smell and you would notice it more during the cooling cycle. Is there any oily film inside or on the back of the fridge if so that is another sign. If you have a Recreational Vehicle it will smell more like ammonia and have yellow residue
Aug 11, 2008 | Refrigerators
Ice and Refrigerator and Freezer smell like alcohol chemical
I believe that you might have a coolant leak causing the chemical odor. You really should get it checked out by a fridge repair-person because it's not healthy to breathe in the fumes.
May 21, 2008 | Hotpoint HSS25GFP Side by Side...
I am having problems with my samsung fridge model - SR-S2028CSS
does it freeze at all? you may have a problem with the coolent in the back of the fride which if so (depending on the cost of the fride) may be cheaper to replace, also the dial you use for selecting the freeze level could be faulty
Feb 19, 2008 | Refrigerators
BAD SMELL/CONSTANT BEEPING OF ALARM
if you have a gas like oily smell id advise calling a tech get a factory authorized tech as seal systems are most often under extended warrenties and get your food some where cold sorry but that would be my best advice
Dec 31, 2007 | Zanussi ZX99 / 5 Bottom Freezer...
Freezer smell
could be that your freezer is leaking gases some leaks are fixable but if its an internal leak you will have to replace the complete appliance
Aug 15, 2007 | Turbo Air TGM22RV
Refrigerators Logo
Top Neff Refrigerators Experts
John Tripp
John Tripp
richie46
Rabbit Brains
Rabbit Brains
Are you a Neff Refrigerator Expert? Answer questions, earn points and help others
