Question about Garden
Weedeater featherlite tx200
My boot trimmers oil smoke from the exhaust and would like to know which is the mixture of oil and gasoline
  • 3 Answers
SOURCE: what is the gas & oil mixture for ryobi 26cc 22in hedge trimmer
If it is a 2 stroke engine, a 50:1 ratio should work. That's 50 parts gas to 1 part oil.
Posted on Dec 14, 2008
  • 398 Answers
SOURCE: Craftsman gas hedge trimmer
yes the throttle isnt giving enough gas. there should be two screws side by side somewere near the trigger next to the cable that moves when you pull the trigger. play around withthose screw a few hours youll get it.
Posted on Feb 26, 2009
slohry
  • 87 Answers
SOURCE: How to adjust mix on WEEDEATER FEATHERLITE PLUS
Red=High speed and White = Low speed
Clockwise closes needle, Counter clockwise opens needle. Set both needle to 1 1/2 turns open, then fine tune from there.
Posted on Apr 10, 2009
  • 246 Answers
SOURCE: Poulan 17'' Gas Weedeater keeps dying!
Hello su2yak2:
From your Description it Sounds like the Exhaust Port or Muffler is Restricted with Carbon Deposits, the Carburetor Metering Pump Actuator Gap is Incorrect.
>>The Following is a Basic Instruction File for Doing a Diagnostic on the Engine for this Problem. Any Input is Appreciated.
>>**Remove the Muffler and Make Sure the Exhaust Port is Clear.
>>If it is, then Try to Start the engine with the Muffler Off.
>>If it Starts and Runs Properly, then Clean the Spark Arrestor Screen in the Muffler or Replace the Muffler if Required.
Is the Fuel Line from the Fuel Filter Staying Full of Fuel?
The Carburetor Metering Jet Actuator is Set so the Pump Diaphram Dowl is Just Touching the Actuator Arm. These Components are Located Under the Cover with 4 Small Screws Holdong it to the Carburetor Body.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
SOURCE: Proper gasoline and oil mix ratio.
My echo uses 50-1 ration. Home Depot sells the small containers for Echo Leaf Blowers that you mix with one gallon of gas.
Posted on May 26, 2009
POULAN 25CC NOT STARTING AND BEFORE THIS HAPPEND IT WAS OVER HEATING
overheating on a 2 stroke is usually caused by lack of oil mixture. try draining all the fuel and re mixing the ratioo to a 40 to 1 ratio. if no smoke then richen the mixture till it slightly smokes. i.e. 50:1 ratio
Aug 30, 2012 | Poulan WeedEater Hedge Trimmer 25cc Engine
Does the 28cc and 25cc weedeater use the same oil and gas mixture
Yes they will use the same mixture, it doesn't matter on the size of the engine. I would recommend using a 50:1 ratio. That equals out to 2.6 oz of oil per gallon of gasoline. Hope this helps, Daniel.
Oct 26, 2011 | Husqvarna 28cc Gas Line Trimmer
I have a weed eater featherlite gas trimmer serial #98058N701741-3 how much oil do you mix with the gas? Oil and gas goes in to one plastic bottle.
Hi salston139
Use a 50 to One mixture for your weedeater...(1 pint of 2 cycle oil to 6 gallons of gasoline)
Free Answer...Please rate me
May 30, 2011 | Garden
What is the gas and oil mixture for featherlite weedeater
Most older units are 40:1...that is 3.2 ounces of oil to 1 gallon of gas...Newer ones may even go as lean as 50:1 but its always better to have too much oil, then not enough. I use synthetic 2-stroke oil and also add "Stabil" to the mix.
Jul 17, 2010 | Garden
I need to know what the mixture of oil and gas is for my weedeater
One ounce of oil per quart or four ounces per gallon of gasoline. Hope this helped and best wishes.
Aug 23, 2009 | Garden
Gas/oil mix
Most trimmers are using a 50:1 mix. 2.6oz/gal or 6.4oz/2.5gal. A 4oz/Gal is a 32:1 mix which way too oily and you will have problems of excessive smoke, oil leaking out muffler, carbon buildup causing sticking piston ring or a clogged spark arrestor.
Aug 14, 2009 | Homelite Mighty Lite Lawn Trimmer
Whats the mixture of oil/gas for a homelite weedeater
3.2 oz of 2 cycle oil to 1 gallon of regular gasoline, 40:1 ratio.
Jul 13, 2009 | Homelite Consumer Products 4.0 Amp, 13 In....
Homelite weedeater smokes
Yes, you have too much oil in the gas.
Jim
Jun 16, 2009 | Homelite Consumer Products 4.0 Amp, 13 In....
Echo trimmer won't start, gasoline flows out of exhaust
look at choke and air filter. ensure choke is operating and clean air filter.
May 24, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
Garden Logo
42 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
