Question about Lakewood Dryers
Fan won't run - Lakewood Dryers
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 43 Answers
Try another outlet. Or if your electrically knowledgeable then pull back housing and verify that your connections are still made. If neither of these are the problem then your electric motor is bad whether its a shorted winding or the resin has worn down and is allowing arcing. If your electric motor is bad then your better off just buying another fan.
Posted on Oct 12, 2013
Why my A/C condenser fan won t stop running, dodge ram 2008
To clarify, the compressor and fan will run in defrost mode. The compressor and fan runs to dry out the air blowing onto the windshield.
Now if the condenser fan runs in "heat" you may have a problem with the fan relay or the main controller.
Sep 25, 2014 | 2008 Dodge Ram Pickup 1500
My fan won t stop running at boot. Acer t160.
JIMMY,CHECK ALL ELECTRICAL WIRING.IF IT LOOKS OKEY YOU CAN HAVE A BAD PSU.
Jul 11, 2013 | Acer Computers & Internet
Ac fan not running, but compressor runs on and off
switch/ fuse possible if it has one, if not one of the wire going to the motor was severed, or the start up capacitor of the motor if it also has one.
Jun 04, 2013 | Frigidaire FAX054P7A Wall/Window Air...
Remote wont work for fan.
http://www.ehow.com/how_6104129_instructions-hampton-bay-fan-remote.html You may need to reprogram the remote
May 15, 2013 | Televison & Video
It freezes but won't stop
as long as the compressor is running on your freezer the longer the fan runs has to too cool the compressor . . .thermostat problem
Jan 11, 2013 | Boating
Fan won't stay running and temperature sensor flashes
Sounds like the fan needs replacement. A faulty fan will shut the set down and the tem light will falsh in most cases.
Oct 27, 2012 | Televison & Video
Koolatron mosquito trap fan won't run.Power to the machine but the fan won't run
I have been experiencing the same issue, and I solved my problem by cleaing the mosquito guts off the side of the fan body and blades with a wet toothbrush. I unplugged the unit and brought the entire head into the laundry room wash tub. remove the screened cup and then you can access the fan from the bottom. It would make life easier if you cut the plastic framing off, but you can reach in with a small toothbrush if you have some patience.
Jun 11, 2011 | Garden
Radiato fan won stop running on a 1993 audi 90 s
I assume from your description that the fan will run until the battery is dead?
Sounds like your fan control relay (underhood, large fuse panel/box) or fan control switch is stuck. Both very simple to replace.
Fan control relay
Fan control switch
I hope this helps
May 06, 2010 | 1993 Audi 90
Fan won,t run on 2000 Ford Contour
fan motor may be bad. also could be a sensor. you can jump the fan motor off of the battery to see if it works.
Jan 06, 2009 | 2000 Ford Contour
Dryers Logo
142 people viewed this question
Top Lakewood Dryers Experts
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Lakewood Dryer Expert? Answer questions, earn points and help others
