Question about Frigidaire ATF6000ES Front Load Washer
Frigidaire front load washer model LTF2940FEO. As
Frigidaire front load washer model LTF2940FEO. As it is filling and while washing water runs out of the bottom machine.
  • 3 Answers
If water on floor at base of machine,most likely the pump is leaking or the pump hose connections for drain pump need attention either replacement or clamp could just have woked itself loose.
Posted on Oct 10, 2012
  • 240 Answers
Remove lower kick panel and check for leak at door boot and drain pump.
Posted on Apr 29, 2009
Frigidaire front load washer does not fill.
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Aug 04, 2011 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
My Frigidaire front load washing machine feels warm/hot even when I chose the cold wash cycle. My clothes are even hot at the end of the cold cycle.
its the hot water fill velve leaking,,,,your getting a small amount of hot water as well as the cold water when it fills up the washer,,, change the water velve
Jun 08, 2010 | Frigidaire ATF6000ES Front Load Washer
Error code E70 on my Frigidaire front loading washer model LTF2940FEO
The hot and cold water hoses were connected wrong to the washer.
Dec 22, 2009 | Frigidaire Washing Machines
My front load washer does not seem to fill enough
At least on our GE front loader it is ok. That's why they are so easy on water.
Aug 17, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Front Load washer Model FWT645RHS1 wont fill with Water
The drain hose might be too low. Make sure the drain hose is at least three feet above the floor.
May 31, 2009 | Frigidaire Washing Machines
Little water in Frigidaire front load washer
If the machine does not fill properly, it is usually because of a defective water level switch. This is also the cause for smelly clothes.
See also : It's underfilling
You can find replacement parts here.
or here Find Parts .
Dec 12, 2008 | Frigidaire ATF6000ES Front Load Washer
Washer fills with water but will not agitate to wash the clothes.
REPL/ PUMP GRINDING NOISE IS BROKEN IMPEELER INSIDE PUMP SHOULD FIX PROBLEM
Nov 30, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Frigidaire washer
hi mom,
could it be that these newer models now a days uses less water to wash clothes?
that is what they are boasting about.
energy efficient washing machines..less water more cleaning. ( at least that's what they say) specially on front loading types. not like the top loading where it uses a lot of water.
please check your owner's manual, it may be stated in there regarding water level of the new washer.
tnx 4 using fixya,
drcool
Sep 26, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Front Load Washer
You need to replace the Motor controller speed asm part number 134149220 they are about 165.00. very easy part to replace you have to remove the back panel and the control board is on the bottom left side two scews and two plugs.
Dec 18, 2007 | Washing Machines
Frigidaire ATF6000ES Front Load Washer Logo
594 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
