Question about Plumbing
Air compresser hard to start - Plumbing
  • 3,368 Answers
Yep most are unless they do not have back pressure. What are you asking, you need to give more information.
Posted on Jun 17, 2014
2001 Yamaha TTR90 hard to start cold
My guess would be that you have dried out seals/gaskets taking away from the overall compression. This will either get better with use as everything lubes up or you will have to replace all that are leaking.
Mar 18, 2014 | Motorcycles
Wont start
1. Fuel pump control circuit
2. Spark plugs
3. Ignition system
4. Injectors
5. Mass air flow meter
6. Throttle control system
7. Air induction system
8. Engine compression
9. Engine oil viscosity.
Dec 28, 2013 | 1997 Hyundai Elantra
My son laid down his ttr 125 pritty hard we picked it up and it started up eazy but when we turned it off and tryed to start it again it has no compression does it have a compression release I can't...
Valve is stuck or not seating. Listen when you crank it and see if you hear air moving out of the intake and exhaust. The exhaust is a little tricky because it should let air out just not during compression. There is no unloader.
Apr 24, 2013 | Motorcycles
Fan error
Compressed air can cause the formation of very high static voltages which can cause semiconductors to fail instantly. I learned this the hard way. . .
Feb 22, 2012 | IBM ThinkPad T43 Notebook
Compresser on my 2 ton condenser unit not coming on condenser fan running but not the compresser. I already replaced the capacitor but did not fix the problem.
Check the wires going to the compressor terminals making sure there is no damage to them or to the compressor terminals..Install a hard startbobicehouse_2.jpg
Jul 03, 2011 | Ruud Matching Split Air Conditioner
Loss compression hard starting
try taking out the plug and put a little (3 or 4 drops) of oil drectly into the cylinder. this should increase the compression. If it does then the problem might be to much gas getting in at the start cycle. the excess gas rinses the oil off the rings that lowers the compression and makes it hard to start. if the added oil does not help increase compression then you will need to mechanically determine why you are losing compression. does it run alright once it starts? if it does then you probably don't have a mechanical problem. If you are getting to much gas when you start try a new air filter.
May 01, 2011 | kawasaki KLX 125 Motorcycles
Loss of power, wont go over 40 mph, and takes a while getting there...
Check the "Basics" first. Clean Air Filter, Check the Spark Plug. When you kick it over, Is there resistance on the kick starter which means it has compression. Is it hard to start? When the motor gets tired, It will lose compression and be hard to start. I would start on the Air Filter and spark plug. Also, Does it have fresh gas in it?
Aug 10, 2010 | 2003 Yamaha YZ 125
2005 crf100f extremely hard to start when cold. A
If the bike has been in storage for any length of time, more than a year or so, the carburetor is plugged up and needs to disassembled and cleaned. If that's not the case do a compression check. You need to see at least 140 psi of compression for it to start reliably. If the compression is low, adjust the valve tappet clearances (tight valves will cause low compression).
Other than that, make sure the choke is functioning properly and that there are no air leaks between the carburetor and the engine.
Dec 04, 2009 | 2005 Honda CRF 100 F
2002 trailblazer. the air all of the sudden started blowing HOT air! also when air is turned on the rpms drop dramaticaly and have even stalled the engine a few times! what gives?
Do you have standard environmental controls or are they of the digital type for one? As far as the RPM's dropping hard, you can have a dry compresser. try a can of " R134 with oil " sounds to me that if all this just started happening with the HOT air and the engine rpm's dropping. you may heve a leak in the system, and if you continue to run it you can cause sever damage to the compresser.
Jul 17, 2009 | 2003 Chevrolet TrailBlazer
Plumbing Logo
24 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
