Question about Vehicle Parts & Accessories
1998 Suburu Forester , I had the headgaskets replaced , now a aftermarket security system wont allow car to run. I just bought the car and was told the system had been disabled. How do I disabel or remove it?
    Sergeant:
  • 206 Answers
Hi
i would open the car1998 Suburu Forester , I had the headgaskets - icon1.png via the key remove the cover under the dash below the steering wheel
there are normally 2 fuses to a car alarm remove the fuse on the red power led that will disable the alarm
but it may also disable the remote central locking
but you will b able to unlock the door with the key a start the car
aries
Posted on Oct 19, 2013
3 Suggested Answers
  • 22 Answers
SOURCE: i want to remove my remote starter
Under the dash you will find the security system its a black box the size of a cigarette pak remove the red fuse and this will ensure the product can no longer drain power.The car should still start if not replace fuse and then contact me and i willl give you the rewiring tip.
Posted on Apr 23, 2009
SOURCE: Aftermarket anti theft system problem
Found the problem - it was not the security system - it was an internally shorted battery. Replaced the battery and the car is fine.
Posted on Oct 13, 2009
I have a subaru forestrr 99 trying to override the system and still wont start is there a definite way that it will start lost remote
Question about 2014 remote start - Subaru Forester Owners Forum
www.subaruforester.org > ... > Interior and Electronics
Apr 23, 2013 - I got the 2014 Forester 2.5i Touring + EyeSight. I have a question about ... There's no way to get EyeSight without remote start. I'd still rather get ... Remote Starter; OEM vs. Aftermarket
Aug 19, 2013
('09-'13) Aftermarket Remote Starter?
Apr 19, 2013
Remote Car Starter
Nov 2, 2009
remote start for 2006 Forester
Dec 11, 2008
More results from www.subaruforester.org
Sep 25, 2015 | Subaru Cars & Trucks
1998 forester awd, running lights will not turn off after car is shut off.
Most Subarus have a switch on the top of the steering column that you usually can't see that allows you to leave your running lights on since most Subarus have the auto off lights. You should just have to switch that and it will be fine.
Oct 05, 2010 | 1998 Subaru Forester
Suburu wont start when engine hot
starter is going also check the relay
Aug 06, 2009 | 1998 Subaru Legacy
I have 2001 suburu forrester..have had 2 problems in the last month(has88,000 miles) 1. leaking valve gaskets..oil everywhere, replaced all for 449.00! 2. in shop now for Cv joint(boot,shaft...
usually the valve cover gaskets are not the cause,the headgsket most of the time are either leaking coolant,oil or both! A Subaru dealer may possibly will be able to identify it properly considering this is a very common problem,usually the drivers side headgasket is the first the first to leak,if this is the case a call to subaru wouldn't hurt they may assist you in the repair, good luck!
Jul 10, 2009 | 2001 Subaru Forester
1998 SUBURU ABS LIGHT TURN ON
THE ABS LIGHT WILL NOT TURN OFF UNTIL THE ABS PROBLEM IS FIXED.THE VEHICLE COMPUTER WILL HAVE A CODE FOR THE ABS PROBLEM.YOUR REGULAR BRAKES WILL WORK FINE BUT U WILL NOT HAVE ABS FUNCTION.ANY GOOD SHOP SHOULD BE ABLE TO FIX
Apr 24, 2009 | 1998 Subaru Forester
Check engine !
please send information of control computer for subaru forester 1997,
Aug 28, 2008 | 1998 Subaru Forester
Vehicle Parts & Accessories Logo
69 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
