Question about Honeywell CT87B ROUND HEATING&COOLING MECHANICAL THERMOSTAT - WHITE Heater
Replace the thermostat - Honeywell CT87B ROUND HEATING&COOLING MECHANICAL THERMOSTAT - WHITE Heater
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 83 Answers
Ok did that help
Posted on Oct 20, 2013
How do I replace thermostat?
    1. Maintenance and How-to: Thermostat Replacement ...
      https://www.youtube.com/watch?v=RIC6Z4D6Q3E
    Feedback
  1. How to Replace Your Vehicle's Thermostat - For Dummies
    www.dummies.com/how.../how-to-replace-your-vehicles-thermostat.htm...
    Just be sure that you do this when your engine is completely cooled. Locate yourthermostat if you haven't already done so. Place a bucket under where you're going to be working. Remove the clamp. Pull off the hose. Remove the bolts that hold thethermostat housing in place and lift out the old thermostat.
    How to replace a car thermostat ' How a Car Works
Dec 12, 2015 | Cars & Trucks
Thermostat needs replaced
To replace a thermostat, you will need at least: 1. A new thermostat 2. Screwdriver 2. Needle-nosed pliers. Depending on the thermostat and location in your home, you may need more. Make sure the new thermostat you are using to replace the old one with is compatible to your 110-volt housing circuitry. Always turn off the electrical power to the home thermostat at the power panel or circuit breaker box.--------------------------------------------------------------------------
carbrain c168 scanner
Dec 01, 2012 | 1996 Pontiac Grand Am
Need to know how to replace the thermostat on a 1996 buick century wagon 3.1 6 cylinder engine
Trace the upper radiator hose to the mounting area on the intake manifold. Loosen the hose clamp on the manifold end of the hose and remove the hose. Pull the thermostat out of the intake manifold.
For more help and troubleshooting go through the help links below:---
Click the link below:-----
THERMOSTAT REMOVAL PROCEDURE/LOCATION DETAILS
Where is Thermostat Located on Saturn
http://technoanswers.blogspot.com/2012/11/where-is-thermostat-located-on-saturn.html
2004 Dodge Intrepid: How to replace Thermostat?
http://schematicsdiagram.blogspot.in/2012/06/2004-dodge-intrepid-how-to-replace.html
How to Replace Thermostat on Audi A4?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-thermostat-on-audi-a4.html
How to replace Thermostat on Acura Car models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-thermostat-on-acura-car.html
Where is thermostat located on 2006 dodge magnum 3.5L?//
http://repairhelpcenter.blogspot.com/2011/10/where-is-thermostat-located-on-2006.html
Thermostat on AUDI 1.9 TDI?
http://repairhelpcenter.blogspot.com/2011/10/thermostat-on-audi-19-tdi.html
How to replace Radiator on Audi and VW car models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-radiator-on-audi-and-vw.html
How to Replace a Thermostat.
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-thermostat.html
How to locate Thermostat on Any car model?
http://schematicsdiagram.blogspot.com/2011/12/how-to-locate-thermostat-on-any-car.html
Where is thermostat on Audi A6?
http://technoanswers.blogspot.com/2011/12/where-is-thermostat-on-audi-a6.html
How to replace thermostat on 1992 Buick century?
http://technoanswers.blogspot.com/2011/12/how-to-replace-thermostat-on-1992-buick.html
Replacing thermostat on 1999 Mercury Cougar?
http://technoanswers.blogspot.com/2011/12/replacing-thermostat-on-1999-mercury.html
Thermostat Replacement on Toyota Corolla?
http://technoanswers.blogspot.com/2011/12/thermostat-replacement-on-toyota.html
Where is thermostat located on 2005 Dodge neon?
http://schematicsdiagram.blogspot.in/2012/02/where-is-thermostat-located-on-2005.html
These will help.
Thanks.
Nov 28, 2012 | Buick Century Cars & Trucks
Just replaced both elements to my reliance electric heater..heats fine but after 1 shower i have to reset red button and repeat process daily Whats up? thanks
Replace thermostats.
One of the thermostats is sticking causing overheating that trips ECO reset located on upper thermostat. There is no good way to test thermostats since testing means turning the temperature setting which temporarily unsticks bad thermostat so it looks like it works ok, so replace both thermostats.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
Sep 17, 2012 | RELIANCE ELECTRIC WATER HEATER
Its not very hard to replace thermostat.You can replace the thermostat.Follow the radiator hose that connects to intake manifold.That part connects to thermostat housing.For details regarding thermostat replacing,click this link below:--- http://howtobyme.blogspot.com/2011/10/how-to-replace-thermostat-on-2004.html -=--------------- This will help.Thanks.Helpmech.
Sep 30, 2011 | 2004 Chevrolet Cavalier
How do you replace a thermostat on a 1994 pontiac grand am 4 cyl
i own a 1989 ford laser gl and it over heated and bubbling.There is no water in the oil already checked . Could it be the thermostat or a gasket.
Oct 11, 2010 | 1994 Pontiac Grand Am
The thermostat is located behind the thermostat housing on which the ECT is installed.It is attached to the lower radiator hose. Remove the lower radiator hose and the housing attached to it you would get the thermostat.To replace the thermostat, you must remove the air cleaner box, remove the thermostat housing cover, replace the thermostat with a new gasket, clean off any old gasket material, reinstall the housing cover and air box, and then fill and bleed the cooling system.
Thank you !!
Jul 07, 2010 | 2004 Hyundai Elantra
How difficult to replace 1995 Toyota Corolla radiator/thermostat
You can replace the radiator yourself, but why do you need to? The thermostat is on the engine. Follow the large hose that goes to the engine block....not the water pump. The thermostat is under that or sits on the top of the engine....looking for a pic for you!
Mar 14, 2009 | 2005 Toyota Corolla
Heating & Cooling Logo
18 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
