Question about Snow Joe Tiller Joe - TJ601E - 9 AMP Electric Garden Tiller/Cultivator
The motor runs but the tines no longer turn - Snow Joe Tiller Joe - TJ601E - 9 AMP Electric Garden Tiller/Cultivator
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 43 Answers
Does the drive shaft turn and the tines just spin around it ? if not then on the drive shaft there is a gear box and you need to open that up (without the machine plugged in) and check to see why the gears aren't meshing properly.
Posted on Oct 12, 2013
The starter pull rope pulls hard the engine will not crank
does pulling the start rope turn the engine over . make sure the tine drive is disconnected
if yes , the motor is not seized but the tines could be
if the motor will not fire ( check spark plug for spark it could be the coil or a short to ground in the ignition on/off switch wire
Feb 22, 2016 | Garden
Garden master tiller 5020d
Get behind the tiller as if you are ready to use it. Look down towards the tines. There's a protective cover. Remove it and you will see the belt running vertically between the motor and the tines.
May 08, 2013 | Ardisam 5.5 Hp Rear Tine Rototiller
I have a poulan 850 that runs great. Gears engage and gos forward and back but wile tilling it made a click and the tines no longer engage. It's been suggested that it's a shear or breakaway pin....
Yes, there is a gear and pinion that drive the tines. Either a pin has sheared or teeth have broke off the gears. Either way its internal. You will need to completely disassemble the unit. Before you disassemble the unit locate and record the model and serial number from the chassis and the model, type, and code of the motor, you will need these numbers to purchase replacement parts. Remove the motor, tines, wheels, all shields, handles, etc. Until you are left with just the gearcase. Then you will need to split the gearcase. Lay it on its side on blocks so that it is stable and level. Remove all the fasteners and remove the top side. Take your time it will be hard to seperate the halfs to start with. Once the cases are split you will be able to identify the failed part and replace them. Good luck
Sep 09, 2012 | Garden
Best way to fix the problem
look on the shafts the tines ride on and see if the bolts broke off
Mar 28, 2012 | Garden
Own an older (1990's) American Yard Products model WER500 Weedeater rear tine rotortiller. The engine runs great but when I engage to til, the tines won't turn. The belt is fine and pulleys turn...
Yes, there are shear pins on the tines and on the wheels. Can you check to see if the belt actually moves when the pulleys turn?
May 13, 2011 | Garden
Have a MTD Yard Machine rear tine tiller Model 410 and when I went to use it this year when I put it in gear the tines did not move. I called the MTD tech and he said it sounds like its in the...
It is the shift fork in the transmission. Bad part design and if you plan to take it apart, use sandpaper and really clean the wheel axle and tine axle before you take it apart.
Mar 20, 2011 | Mtd Garden
Unit powers on, but the shredder tines won't run.
If you cant hear the motor running but you hear a click when you insert the paper it sounds like the eyes are ok so its likely the pcb thats defective...give Royal a call at 1-800-524-0799 for parts assistance.
Feb 01, 2009 | Royal 1280MX Shredder
Error code E1 54 on samsung air conditioner split
A Bit of a late reply but E1 54, is indoor fan fault.
Dec 31, 2008 | Heating & Cooling
Snow Joe Tiller Joe - TJ601E - 9 AMP Electric Garden Tiller/Cultivator Logo
187 people viewed this question
Top Snow Joe Garden Experts
Dennis Key
Dennis Key
john h
Are you a Snow Joe Garden Expert? Answer questions, earn points and help others
