Question about E-Machines M5312 Notebook
BIOS improperly read Hard Drive Type
M5300 Series Laptop Need a DOS Based BIOS Flash
Bootmgr v3500 missing
which operating system ??
There are a number of possible causes for BOOTMGR errors, including the most common "BOOTMGR is missing" error message.
The most common reasons for BOOTMGR errors include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors an outdated BIOS and damaged or loose IDE cables
Anothe reason you might see BOOTMGR errors is if your PC is trying to boott from a hard drive or flash drive that is not properly configured to be booted from. In other words, it's trying to boot from a
non-bootable source.
This also would apply to media on an optical drive or floppy drive that you're trying to boot from.
make sure there are no disks in cd floppy usb drives
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your ((MOTHERBOARD TO YOUR HARD DRIVE)) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
if its a flat ribbon 40 pin IDE it will be the fist to fail
make sure all power and data leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty a computer needs
data and power to travel through every working device and to continue its cycle and to have an end so any faulty leads will end up with a computer error
also make sure you have set it boot from you hard drive in BIOS
The solutions is very simply... remove your hard-disk and attached to other PC or laptop as an external hard-disk.
When it is detected, go to my computer, right-click, untick that (stupid) option, immediately you see the message uncompressing and its done. Put your hard-disk back in to your machine its ready..
w7
insert your OS CD
go to DOS window and type in your OS driver (usualy C:/
type in bootrec /FixMbr
then type in bootrec /fixboot
t
hen type in bootrec /rebuildbcd
then type in exit
restart your computer
it will work 100% only if you prompt at the same order
hope
Sep 16, 2012 | Compaq Presario V3500 Series Laptop...
Tip
Creating a bootable flash drive
<p><b>Resolution:</b><br /> <p>The USB Flash Drive must be configured with an active primary MS-DOS partition. It must also contain the boot files. Follow the steps below to create a bootable USB Flash Drive. <br /> <p><b>Requirements:</b><br /> <ul> <li> Motherboard with BIOS that supports USB boot. <li> USB Flash Drive that may be erased. <li> Bootable floppy disk or CD with Fdisk and Format commands. </li></ul> <p><b>Directions:</b><br /> <ol> <li> Plug in the USB Flash Drive. <li> Make the USB drive the only bootable hard drive. <b>Method 1:</b><br />If available, change the BIOS settings for the hard drive sequence, making sure the USB device is at the top of the list above all other hard drives. Not all BIOS Setup Utilities have this option. <b> Method 2:</b><br /> Disable all hard drives in the BIOS. In some BIOS Setup Utilities you can disable the individual hard drives, while in others you will need to disable the controller. <b> Method 3:</b><br /> Unplug all hard drive cables inside the case. If the cables are unplugged the computer cannot detect and boot to the hard drive. <li> Insert the bootable floppy disk or CD into the appropriate drive. <li> Restart the computer to the bootable floppy disk or CD. <li> At the command prompt, type: FDisk. <li> Delete and create a new active primary DOS partition. <li> Use FDisk to delete all partitions from the USB Flash Drive. <ul> <li> In FDisk, press the 3 key to Delete partition or Logical DOS Drive. <li> If there is just one partition on the drive, choose 1 to delete the primary DOS partition. If there are several partitions, the extended and logical partitions must be deleted before the primary partition. <li> After choosing option 1, the screen appears with partition information and a prompt for the partition to delete. Choose which primary DOS partition to delete, and then press ENTER. <li> A prompt appears to enter the volume label of the hard drive. Enter the label exactly as it appears on the top of the screen in the partition information. If the volume label contains gibberish or lowercase letters, the partition will have to be deleted as a non-DOS partition. Try using the option to delete a non-DOS partition in FDISK. After entering the volume label, press ENTER. <li> You are prompted if it should delete the partition. Press Y for Yes, and then press ENTER. <li> The screen changes to show only the total disk space and a line near the bottom that prompts that the primary DOS partition has been deleted. Press the ESC key to return to the main menu. </li></ul> <li> Use FDisk to create a primary partition on the USB Flash Drive. The drive letter will be C:, since all other hard drives were disabled in step 2. <ul> <li> In FDisk, press 1 to Create DOS partition or Logical DOS drive. <li> Press 1 to Create a Primary DOS Partition. <li> The next screen prompts if the maximum hard disk size should be made into one partition. Press the Y key, and then press ENTER. <li> The next screen prompts that the computer will now reboot. Press ENTER to continue. </li></ul> <li> Exit FDisk and restart the computer. <li> Start the computer from the bootable floppy disk or CD with the USB Flash Drive still connected. <li> At the command prompt, run Format by typing the following command: Format c: /s. Press ENTER. <li> At the command prompt, run FDisk by typing following command: Fdisk /mbr. Press ENTER. <li> Restart the computer without the bootable floppy disk or CD, and attempt to boot to the USB Flash Drive. If it works, it should go to a C:\&gt; command prompt. <li> Change the settings made in step 2 back so that the computer operates normally again. </li></ol>
on Mar 14, 2011 | Computers & Internet
Tip
Creating Bootable USB Flash Drive.
Requirements:
  • Motherboard with BIOS that supports USB boot.
  • USB Flash Drive that may be erased.
  • Bootable floppy disk or CD with Fdisk and Format commands.
Directions:
  1. Plug in the USB Flash Drive.
  2. Make the USB drive the only bootable hard drive. Method 1:
    If available, change the BIOS settings for the hard drive sequence, making sure the USB device is at the top of the list above all other hard drives. Not all BIOS Setup Utilities have this option. Method 2:
    Disable all hard drives in the BIOS. In some BIOS Setup Utilities you can disable the individual hard drives, while in others you will need to disable the controller. Method 3:
  3. Insert the bootable floppy disk or CD into the appropriate drive.
  4. Restart the computer to the bootable floppy disk or CD.
  5. At the command prompt, type: FDisk.
  6. Delete and create a new active primary DOS partition.
  7. Use FDisk to delete all partitions from the USB Flash Drive.
    • In FDisk, press the 3 key to Delete partition or Logical DOS Drive.
    • If there is just one partition on the drive, choose 1 to delete the primary DOS partition. If there are several partitions, the extended and logical partitions must be deleted before the primary partition.
    • After choosing option 1, the screen appears with partition information and a prompt for the partition to delete. Choose which primary DOS partition to delete, and then press ENTER.
    • A prompt appears to enter the volume label of the hard drive. Enter the label exactly as it appears on the top of the screen in the partition information. If the volume label contains gibberish or lowercase letters, the partition will have to be deleted as a non-DOS partition. Try using the option to delete a non-DOS partition in FDISK. After entering the volume label, press ENTER.
    • You are prompted if it should delete the partition. Press Y for Yes, and then press ENTER.
    • The screen changes to show only the total disk space and a line near the bottom that prompts that the primary DOS partition has been deleted. Press the ESC key to return to the main menu.
  8. Use FDisk to create a primary partition on the USB Flash Drive. The drive letter will be C:, since all other hard drives were disabled in step 2.
    • In FDisk, press 1 to Create DOS partition or Logical DOS drive.
    • Press 1 to Create a Primary DOS Partition.
    • The next screen prompts if the maximum hard disk size should be made into one partition. Press the Y key, and then press ENTER.
    • The next screen prompts that the computer will now reboot. Press ENTER to continue.
  9. Exit FDisk and restart the computer.
  10. Start the computer from the bootable floppy disk or CD with the USB Flash Drive still connected.
  11. At the command prompt, run Format by typing the following command: Format c: /s. Press ENTER.
  12. At the command prompt, run FDisk by typing following command: Fdisk /mbr. Press ENTER.
  13. Restart the computer without the bootable floppy disk or CD, and attempt to boot to the USB Flash Drive. If it works, it should go to a C:\> command prompt.
  14. Change the settings made in step 2 back so that the computer operates normally again.
on Mar 31, 2010 | Computers & Internet
My Fujitsu AMILO M3438G will not startup. I,ve changed the cmos battery but it still says that the bios is wrong. I've tried pressing the F2 key but then the monitor displays a "wait" page...
The lines on the screen point to a failing graphics chip, faulty VGA lead or more probably, the screen itself beginning to fail.
The bios problem is most likely due to a damaged bios chip, this is usually caused by attempting to upgrade the bios by flashing and the flash process going wrong, resulting in a series of instructions on the bios chip being incorrect. Changing the Cmos battery will have no effect.
You need to reflash the bios with a stable version, this can be done via floppy drive or USB stick, but you will need to obtain a usb floppy drive (I THINK the bios on the laptop supports this). On the floppy drive, you will need to install a windows 98 type boot disc
http://www.bootdisk.com/
and obtain the bios and flash file for this laptop
http://ts.fujitsu.com/support/downloads.html ( dos version)
On another computer, copy both to separate floppies, boot to the floppy drive, let it load the OS then swap floppies and load the bios flash from floppy
I believe that you can also get the ISO (cd image) which, as long as the laptop can read the cd drive, will be a better option.
If you cannot even get the bios to recognise the floppy or cd, then the problem will need a replacement bios chip installing to sort it out
Jul 18, 2011 | Fujitsu Siemens AMILO Pro V2000 Notebook
Reset bios without running hard disk first
2 options:
  1. create a bootable cd with the bios rom file, and a dos based flash utility (included with bios download). Boot to cd and flash.
  2. Connect a usb floppy drive and create bootable floppy. Copy rom file and flash utility to floppy, boot to floppy and flash......option 2 may be easier if you are not familiar with creating bootable cd's.......Let me know if this helps or not.
Jul 31, 2009 | Acer Aspire 5610-4648 Notebook
Tip
FLASHING BIOS - THE PROCEDURE
BIOS Update Procedure
All latest Motherboards today,ensure that upgrades are easily obtained by incorporating the system BIOS in a FLASH Memory component. With
FLASH BIOS, there is no need to replace an EPROM component. Once downloaded, the upgrade utility fits on a floppy disc allowing the user to save, verify and update the system BIOS. A hard drive or a network drive can also be used to run the newer upgrade utilities. However, memory managers can not be installed while upgrading.
Most pre-Pentium motherboards do not have a Flash BIOS. The following instructions therefore do not apply to these boards. If your motherboard does not have a Flash BIOS (EEPROM) you will need to use an EPROM programmer to re-program the BIOS chip. See your dealer for more information about
this.
Please read the following instructions in full before starting a Flash BIOS upgrade:
A. Create a Bootable Floppy (in DOS)
•With a non-formatted disk, type the following:
format a:/s
•If using a formatted disk, type:
sys a:
This procedure will ensure a clean boot when you
are flashing the new BIOS.
B. Download the BIOS file
•Download the correct BIOS file by clicking on
the file name of the BIOS file you wish to download.
•Save the BIOS file and the Flash Utility file in the boot disk you have created. Unzip the BIOS file and the flash utility file. If you don't have an "unzip" utility, download the WinZip from www.winzip.com or www.pkware.com. Most CD ROMs found in computer magazines, have a shareware version of WinZip on them.
•You should have extracted two files:
Flash BIOS utility eg: flash7265.exe (for example)
BIOS eg: 6152J900.bin (example)
Use the latest flash utility available unless otherwise specified (either on the BIOS update page or in the archive file). This information is usually provided.
C. Upgrade the System BIOS
During boot up, write down the old BIOS version because you will need to use it for the BIOS backup file name.Place the bootable floppy disk containing the BIOS file and the Flash Utility in drive a, and reboot the system in MS-DOS, preferably Version 6.22
•At the A:> prompt, type the corresponding Flash
BIOS utility and the BIOS file with its extension.
For example:
flash625 615j900.bin
•From the Flash Memory Writer menu, select "Y" to
"Do you want to save BIOS?" if you want to save (back up) your current BIOS (strongly recommended), then type the name of your current BIOS and its extension after FILE NAME TO SAVE:
eg: a:\613J900.bin
Alternatively select "N" if you don't want to save your current BIOS. Beware, though, that you won't be able to recover from a possible failure.
•Select "Y" to "Are you sure to program?"
•Wait until it displays "Message: Power Off or
Reset the system"
Once the BIOS has been successfully loaded, remove the floppy disk and reboot the system. If you write to BIOS but cannot complete theprocedure, do not switch off, because the computer will not be able to boo, and you will not be given another chance to flash. In this case leave your system on until you resolve the problem (flashing BIOS with old file is a possible solution, provided you've made a backup before)
Make sure the new BIOS version has been loaded properly by taking note of the BIOS identifier as the system is rebooting.
For AMI BIOS
Once the BIOS has been successfully loaded, remove the floppy disk and reboot the system holding the "END" key prior to power on until you enter CMOS setup. If you do not do this the first time booting up after upgrading the BIOS, the system will hang.
BIOS Update Tips
Note:
1.Make sure never to turn off or reset your computer during the flash process. This will corrupt the BIOS data. We also recommend that you make a copy of your current BIOS on the bootable floppy so you can reflash it if you need to.
(This option is not available when flashing an AMI BIOS).
2. If you have problems installing your new BIOS please check the following:
Have you done a clean boot?
In other words, did you follow the above procedure for making a bootable floppy? This ensures that when booting from "A" there are no device drivers on the diskette. Failing to do a clean boot is the most common cause for getting a "Memory Insufficient" error message when attempting to flash a
BIOS.If you have not used a bootable floppy, insure a clean boot either
a) pressing F5 during bootup
b) by removing all device drivers on the CONFIG.SYS including the HIMEM.SYS. Do this by
using the EDIT command.
Have you booted up under DOS?
Booting in Windows is another common cause for getting a "Memory Insufficient" error message when attempting to flash a BIOS. Make sure to boot up to DOS with a minimum set of drivers.
Important:
Booting in DOS does not mean selecting "Restart computer in MS-DOS Mode" from Windows98/95 shutdown menu or going to Prompt mode in WindowsNT, but rather following the above
procedure (format a: /s and rebooting from a:\).Have you entered the full file name of the flash utility and the BIOS plus its extension?
Do not forget that often you will need to add a drive letter (a:\) before flashing the BIOS.
Example: when asked for file name of new BIOS file which is on your floppy disk, in case you're working from c:\ your will need to type
a:\615j900.bin, rather than 615j900.bin only.
on Dec 30, 2009 | Computers & Internet
Tip
BIOS Update Procedure...
All latest Motherboards today, 486/ pentium/ Pentium Pro etc., ensure that upgrades are easily obtained by incorporating the system BIOS in a FLASH Memory component. With FLASH BIOS, there is no need to replace an EPROM BIOS, there is no need to replace an EPROM component. Once downloaded, the upgrade utility fits on a floppy disc allowing the user to save, verify and update the system BIOS. A hard drive or a network drive can also be used to run the newer upgrade utilities. However, memory managers can not be installed while upgrading.
Most pre-Pentium motherboards do not have a Flash BIOS. The following instructions therefore do not apply to these boards. If your motherboard does not have a Flash BIOS (EEPROM) you will need to use an EPROM programmer to re-program the BIOS chip. See your dealer for more information about this.
* With a non-formatted disk, type the following:
format a:/s
*If using a formatted disk, type:
sys a:
This procedure will ensure a clean boot when you are flashing the New BIOS.
* Download the correct BIOS file by clicking on the file name of the BIOS file you wish to download.
* Save the BIOS file and the Flash Utility file in the boot disk you have created. Unzip the BIOS file and the flash utility file. If you don't have an "unzip" utility, download the Winzip for windows shareware/ evaluation copy for that one time use from _www.winzip.com or _www.pkware.com. Most CD Roms found in computer magazines, have a shareware version of winzip on them.
* You should have extracted two files:
Use the latest flash utility available unless otherwise specified (either on the BIOS update page or in the archive file. This information is usually provided.
C. Upgrade the System BIOS,
Place the bootab le floppy disk containing the BIOS file and the flash utility in drive a, and reboot the system in MS-DOS, preferably version 6.22.
* At the A:> prompt, type the corresponding Flash BIOS utility and the BIOS file with its extension.
For example:
* From the Flash Memory Writer menu, select "Y" to "Do you want to save BIOS?" If you want to save (back up) your current BIOS (strong recommended), then type the name of your current BIOS and its extension after FILE NAME TO SAVE: eg: a:\613J900.bin
* Select "Y" to "Are you sure to program?"
* Wait until it displays "Message: Power Off or Reset the system"
Once he BIOS has been succesfully loaded, remove the floppy disk and reboot the system. If you write to BIOS but cannot complete the procedure, do not switch off, because the computer will not able to boo, and you will not be given another chance to flash. in this case leave your system on until you resolve the problem (flashing BIOS with old file is a possible solution, provided you've made a backup before)
For AMI BIOS
Once the BIOS has been successfully leaded, remove the floppy disk and reboot the system holding the "END" key prior to power on until you enter CMOS setup. If you do not do this the first time booting up after upgrading the BIOS, the system will hang.
BIOS Update Tips
Note:
1. Make sure never to turn off or reset your computer during the flash process. This will corrupt the BIOS data. We also recommend that you make a copy of your current BIOS on the bootable floppy so you can reflash it if you need to. (This option is not available when flashing an AMI BIOS).
In other words, did you the above procedure for making a bootable floppy? This ensures that when booting from "A" there are no device drivers on the diskette. Failing to do a clean boot is the most common cause for getting a "Memory Insufficient" error message when attempting to flash a BIOS.
If you have not used a bootable floppy, insure a clean boot either by
b) by removing all device drivers on the CONFIG.SYS including the HIMEM.SYS. Do this by using the EDIT command.
Booting in windows is another common cause for getting a "Memory Insufficient" error message when attempting to flash a BIOS. Make sure to boot up to DOS with a minimum set of drivers.
Important: Booting in DOS does not mean selecting "Restart computer in MS-DOS Mode" from Windows98/95 shutdown menu or going to Prompt mode in WindowsNT, but rather following the abovr procedure (format a: /s and rebooting from a:\).
Have you entered the full file name of the flash utility and the BIOS plus its extension? Do not forget that often you will need to add a drive letter (a:\) before flashing the BIOS. Example: when asked for file name of new BIOS file which is on your floppy disk, in case you're working from c:\ your will need to type a:\615j900.bin, rather tham 615j900.bin only.
on Dec 26, 2009 | Computers & Internet
Floppy drive spins then gets stuck
This sound like fun. To get to the bios the common practice is to hold down the [Delete] key as soon as you turn it on. If it constantly boots to doss, that is likely the operating system. To explore what else is there, at the dos prompt, type in "dir" and press [Enter]. You should get a list of folders and files. If the dos prompt is A:> then you may have only a floppy drive. To check for a hard drive, type "C:" at the dos prompt. If it says not available, then you have only floppy. If the dos prompt changes to 'C:>" the you have a hard drive.
As far as dismantleing it is concerned, remove any screws in the bottom. Press you finger against any labes on the bottom and feel aroud for hidden screws. The plastic case also snaps together. Tying to unsnap it usually snaps pieces off. That is as far as i can help you right now. Need nore, ask away but supply enough info so I can image it in MY mind.
May 31, 2009 | Apple Laptop Floppy Drive (661-1651)...
Post problem
You could try a program like EZ-Flash to flash the bios without using a dos disk. Gigabyte should have some type of program on their website that would do the flashing without makeing a disk as most new computers do not have a floppy drive nor does Windows XP/Vista use dos. Hope this helps.
Dec 18, 2008 | Gigabyte GA-K8VT800 Motherboard
All latest Motherboards today, 486/ Pentium / Pentium Pro etc.,ensure that upgrades are easily obtained by incorporating the system BIOS in a FLASH Memory component. With FLASH BIOS, there is no need to replace an EPROM component. Once downloaded, the upgrade utility fits on a floppy disc allowing the user to save, verify and update the system BIOS. A hard drive or a network drive can also be used to run the newer upgrade utilities. However, memory managers can not be installed while upgrading.
Please read the following instructions in full before starting a Flash BIOS upgrade: A. Create a Bootable Floppy (in DOS)
format a:/s
sys a:
This procedure will ensure a clean boot when you are flashing the new BIOS.
•Download the correct BIOS file by clicking on the file name of the BIOS file you wish to download.
•Save the BIOS file and the Flash Utility file in the boot disk you have created. Unzip the BIOS file and the flash utility file. If you don't have an "unzip" utility, download the WinZip for Windows 95 shareware/ evaluation copy for that one time use from _www.winzip.com or _www.pkware.com. Most CD ROMs found in computer magazines, have a shareware version of WinZip on them.
•At the A:> prompt, type the corresponding Flash BIOS utility and the BIOS file with its extension.
For example:
•From the Flash Memory Writer menu, select "Y" to "Do you want to save BIOS?" if you want to save (back up) your current BIOS (strongly recommended), then type the name of your current BIOS and its extension after FILE NAME TO SAVE: eg: a:13J900.bin
•Wait until it displays "Message: Power Off or Reset the system"
Once the BIOS has been successfully loaded, remove the floppy disk and reboot the system. If you write to BIOS but cannot complete the procedure, do not switch off, because the computer will not be able to boo, and you will not be given another chance to flash. In this case leave your system on until you resolve the problem (flashing BIOS with old file is a possible solution, provided you've made a backup before)
For AMI BIOS Once the BIOS has been successfully loaded, remove the floppy disk and reboot the system holding the "END" key prior to power on until you enter CMOS setup. If you do not do this the first time booting up after upgrading the BIOS, the system will hang.
BIOS Update Tips note: 1.Make sure never to turn off or reset your computer during the flash process. This will corrupt the BIOS data. We also recommend that you make a copy of your current BIOS on the bootable floppy so you can reflash it if you need to. (This option is not available when flashing an AMI BIOS).
Have you done a clean boot? In other words, did you follow the above procedure for making a bootable floppy? This ensures that when booting from "A" there are no device drivers on the diskette. Failing to do a clean boot is the most common cause for getting a "Memory Insufficient" error message when attempting to flash a BIOS.
Have you booted up under DOS? Booting in Windows is another common cause for getting a "Memory Insufficient" error message when attempting to flash a BIOS. Make sure to boot up to DOS with a minimum set of drivers. Important: Booting in DOS does not mean selecting "Restart computer in MS-DOS Mode" from Windows98/95 shutdown menu or going to Prompt mode in WindowsNT, but rather following the above procedure (format a: /s and rebooting from a:).
Have you entered the full file name of the flash utility and the BIOS plus its extension? Do not forget that often you will need to add a drive letter (a:) before flashing the BIOS. Example: when asked for file name of new BIOS file which is on your floppy disk, in case you're working from c: your will need to type a:15j900.bin, rather than 615j900.bin only.
Oct 19, 2008 | Computers & Internet
E-Machines M5312 Notebook Logo
117 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
