Question about Fisher and Paykel Washing Machines
My Fisher Paykel washer has a dispenser for bleach and one for fabric softner. Neither works. I have pulled the tray for both. They are both clear and no residue blocking the openings. Any suggesstions.
    Champion:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 242 Answers
Some cycles do not use softener or bleach, make sure you are using a cycle that does.
Posted on Dec 21, 2013
4 Suggested Answers
  • 173 Answers
SOURCE: Bleach and Fabric Softner Dispenser
Hi
This is a result of the siphoning action and is part of the normal operation of the washer. Water
may be removed by removing the dispenser drawer and draining
water into the empty drum or sink.
Outside
• When washing is completed, wipe top and sides of washer with a damp cloth. Turn water
faucets off to prevent pressure build-up in the hoses.
• As needed, clean the cabinet with mild soap and water. Never use harsh, gritty or
abrasive cleansers. If door or console becomes stained, clean with diluted chlorine bleach
[1/2 cup (120 ml) in 1 quart (.95 L) water]. Rinse several times with clear water.
• Remove glue residue from tape or labels with a mixture of warm water and mild detergent.
Or, touch residue with the sticky side of the tape or label.
• Before moving the washer, place a strip of cardboard or thin fiberboard under the front
leveling legs to prevent floor damage.
Cleaning the Dispenser Drawer Area
Detergent and fabric softener may build up in the dispenser drawer. Residue should be removed
once or twice a month.
• Remove the drawer by pulling the drawer out until it stops. (Figure 1)
• Reach back into the left rear corner of the drawer cavity and press down firmly on the lock
tab (left rear portion of the drawer). Pull out the drawer. (Figure 2)
• Remove the insert from the bleach and fabric softener compartments. (Figure 3)
• Rinse the drawer and inserts with hot tap water to remove traces of accumulated powders
and liquids. Large amounts of fabric softener residue may indicate improper dilution or
more frequent cleaning is required.
• To clean the drawer opening, use a small brush to clean the recess. Remove all residue
from the upper and lower parts of the recess. (Figure 4)
• Replace the insert pressing the "X" to lock it in place. Return the dispenser drawer.
Inside
• Remove items from the washer as soon as the cycle ends. Excess wrinkling, color transfer,
and odors may develop in items left in the washer.
• Before cleaning the washer interior, unplug the electrical power cord to avoid electrical
shock hazards.
• Dry around the washer door opening, flexible gasket, and door glass. These areas should
always be clean to ensure a water tight seal.
• When extremely soiled items have been washed, a dirty residue may remain on the drum.
Remove this by wiping the drum with a nonabrasive household cleanser. Rinse thoroughly
with water.
• Periodically, wipe dry the bottom of the flexible gasket to remove lint and other debris.
• The plastic drum vanes may become stained from fabric dye. Clean these parts with a
nonabrasive household cleanser. This prevents dye transfer to future loads.
try this out for more ref check the operations mannual page 7
Posted on Dec 07, 2007
SOURCE: Bleach and Fabric Dispenser not working
Got a Brand new LG ~ WT5001CW toploader today. I did 2 loads of wash. Theres a Bleach Dispenser on the top left side but I didn't use it. In the middle of my 2nd wash I noticed the bleach dispenser was full of water. I thought well maybe after the rinse and the spin it would take the water out. Well when the cycle was complete the Bleach Dispenser was still full of water.
I took the Bleach dispenser out and checked the holes to see if anything was plugged, didn't look like it. Was wondering if anyone knew how to solve this problem or do you think that since I took the bleach dispenser out and put it back it that it might work for my next load ??
Any opinions will be greatly appreciated !! Thanks Much !!
Posted on Sep 24, 2010
ginessasemai
SOURCE: My Ge Adora washer fabric softner dispenser
Dilute the fabric softener, I was told by the repair man that this is a common problem and easy fix.
Posted on Feb 16, 2012
Soap, bleach, softner dispenser not working
Here is a tip that I wrote about what I found out about the fabric softener not dispensing into the washer...
Fridgidaire Washing Machine Fabric Softner not going into washer
heatman101
Dec 28, 2010 | Frigidaire ATF6000ES Front Load Washer
Hi
Outside
Inside
shock hazards.
with water.
Dec 07, 2007 | Frigidaire Affinity ATF7000ES Front Load...
Bleach & Fabric softner tray not working.
Remove the drawer by pushing the tab at the top of the drawer and pull it out and check for an obstruction. They regualarly plug up with gummy fabric softenener. Try washing out with hot water and reinstall
Apr 04, 2010 | Frigidaire GLTF1670A Front Load Washer
Fabric softner compartment won't dispense during wash cycle
Fabric softener is to slow mix with rinse water in the rinse cycle... check the cold water supply line for a clogged screen or a clogged dispenser box cover... hope it helps
Sep 20, 2009 | Frigidaire ATF6000ES Front Load Washer
My HE washer doesn't dispense the fabric softner
Try removing the dispenser cup - and washing the inner cup thoroughly- run a sanitary cycle with whites and chlorine bleach mold and mildew likes to haunt these front loaders - be sure to run a bleach hot water cycle once weekly
Mar 01, 2009 | Kenmore Elite 45986 Front Load Washer
Dispenser tray removal
hi, nikoltheis! i'm not sure if we have exactly the same model, but it should be pretty close. here's what my user's manual says:
Detergent and fabric softner may build up in the dispenser drawer. Residue should be removed once or twice a month
- Remove the drawer by first sliding the safety latch to the right, then pulling the drawer out until it stops.
- Reach back into the left rear corner or the drawer cavity and press down firmly on the lock tab (left rear portion of the drawer). Pull out the drawer.
- Remove the insert from the bleach and fabric softner compartments.
- Rinse the drawer and inserts with hot tap water to remove traces of accumulated powders and liquids. Large amounts of fabric softner residue may indicate improper dilution or that more frequent cleaning is required.
- To clean the drawer opening (the empty area left behind when you remove the drawer) use a small brush to clean the recess. Remove all the residue from the upper and lower parts of the recess. (The picture shows this being done with a tooth brush.)
- Replace the insert pressing "X" to lock it in place. Return the dispenser drawer.
Jan 18, 2009 | Frigidaire GLTF2940ES Front Load Washer
Front Load Does not dispense fabric softner and bleach
under the bottom panel of the washer on the left hand side is a tech sheet that will tell you how to fix this
Mar 05, 2008 | Frigidaire GLTF2940ES Front Load Washer
Water Softner Dispense wont empty - Kenmore Elite Quiet Pak 4 HE3t
I'm sure you heard a small motor running from time to time during a cycle. That moves an "arm" which sends water to the different chambers during a cycle. Fabric softener is dispensed when water goes to that chamber and dilutes the fabric softener. That chamber then empties by a siphoning action.
If you want to narrow down the problem a little to help trouble shoot -- put some wet rags in and run the Rinse and Spin cycle with some fabric softener. If the softener is not dispensed, then you know that the water isn't being sent to that chamber properly.
If you are intrepid enough to take the top off your washer, do that and see if the arm appears to be moving during a normal cycle. Maybe the arm got dislodged or broken during the move.
If water isn't being diverted properly, I think this calls for a real repair person.
Jan 27, 2008 | Kenmore Elite 45986 Front Load Washer
Water in detergent drawer
try cleaning the drawer or it may have a faulty valve.
Nov 07, 2007 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
99 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
