Question about Taylor 632-33 Ice Cream Maker
My Taylor c713 is on "R Beater Overload", I came into the shop to find it had done this over night.. I emptied the ice cream out of the machine and cleaned it, upon pushing the reset button and trying to start it back up.. it still says "R Beater Overload".... I do not know what to do... I cannot afford a $200.00 bill just for someone to come look at it!!
    New Friend:
  • Taylor Expert
  • 35 Answers
That is most likely the stand by probe. The standby thermistor probe measures the temperature of product, in this case in the freezing cylinder, while the machine is in standby. Usually when the thermistor fails, you come in in the morning to find that the product is liquid and the reset has been tripped. The motor should be nowhere near the overload setting in standby as the product should be liquid. Thermistor probe C712 C713 Barrel Stanbye Probe
Posted on May 24, 2017
  • 492 Answers
Sometimes a call to the manufacturer tech support helps.
Posted on Oct 17, 2013
3 Suggested Answers
  • 107 Answers
SOURCE: beater overload
if your mix level is low ice cream will freeze in cylinder which in turn will over amp the beater and cause it to trip. Check mix pump and make sure all orings are good.If mix isnt leaking out make sure it is pumping in.
Posted on Apr 19, 2012
  • 30 Answers
SOURCE: Is there a trick to removing the shaft that turns
Most likely your alignment is off on the gear box that has the coupling attached to it, you can try to lift the box up alittle after loosening the bolts and just tighten one and recheck until it pulls out freely with no effort
Posted on Sep 05, 2011
That code means the right side hopper thermistor probe has failed. That is the sensor that reads the temperature of product in the mix hopper.
This is the part you need:
If you order it from us, I would be happy to put a technician on the phone to help you install it yourself.
Aug 01, 2017 | Taylor Ice Cream Makers
Why would a Taylor C713 be making darker and icier soft serve than normal?
I generally see this happen when the air to mix ratio is off. This generally happens overnight when the machine is in standby someone forgets to flip the feed tubes so that no more product is drawn into the freezing cylinder.
Your viscosity could also be set too low.
Jul 29, 2017 | Taylor Ice Cream Makers
Taylor ice cream machine model C713-33 no yogurt comes out when the draw handle it pressed. It seems to be flowing backwards. The agitators are turning in the same direction as the working machines
IF your Taylor C713 is pushing the mix back up through the feed tube, the rotation is reversed. That would only happen on a 3 phase machine like yours.
If you've recently unplugged the machine to move it or something, you probably switched the plugs. Try switching them back.
If you need to reverse the rotation:
1. Unplug the machine.
2. Flip the black and white wires on the plug end.
3. Reassemble the plug and plug in the machine. Make sure everything is tight.
Soft Serve Parts C713
Jun 10, 2017 | Taylor Ice Cream Makers
I just replaced the two beater drive motors on my Taylor c713 ice Cream machine now when I power up communication failure comes up
Every time I have seen that, it is just the USB cable on the mother board in the back of the machine.
1. Shut off and disconnect the machine from power
2. Remove the rear panel
3. Remove the electrical panel cover
4. Find the USB cable on the bottom of the board all the way to your right.
Mar 26, 2017 | Taylor Ice Cream Makers
Beater overload on one side
turn the power off and hit the reset buttons about the size of a quarter hole on the back or front panels. turn back on and it should clear if not then you will need to have the beater motor or contactor replaced.
Oct 08, 2014 | Taylor 2008 C713-27 Soft Serve Ice Cream...
I have a Taylor C713 Ice Cream Machine. IT has been working great until a few days ago. We had it in standby overnight and when we came back the next morning, the ice cream in one side was rotten from...
Those are symptoms of the mix refrigeration system being undercharged. You will need a refrigeration technician to add refrigerant.
In Taylor soft serve machines when the left side hopper (standing in front of the machine) is icing up and the right side hopper is not cold enough, the problem is low refrigerant in that system. It takes R134A.
Nov 11, 2013 | Taylor Frozen Yogurt C713 Soft Serve Ice...
Chocolate ice cream has turned a funny color and that side is running loudly
A grey color often indicates the beater bar is grinding on the inside of the barrel. What you may be seeing is metal. Be sure your beater bar is not bent. Visually inspect the inside of the barrel for marks. Wear is not normal. If you see wear and the beater bar is not bent, be sure all plastic bearings and components are installed. Also, it is normal to have some drip and lube in the drip pans, excessive amounts usually indicate problems though. Hope this helps you.
Mar 14, 2013 | Taylor 2008 C713-27 Soft Serve Ice Cream...
Beater overload
Mar 24, 2012 | Taylor 632-33 Ice Cream Maker
Taylor 754-27 runs good until ice cream is made then trips-not able to restart in auto or wash-able to turn beater with hand-not binding - after ice cream becomes liquid able to start again in auto or...
It is possible that your viscosity is set too cold. You should check the temperature of your product to see if it is too cold. Is the Ice Cream hard? It sounds like maybe the beater overload is tripping. Some of the overloads can reset on their own. If you have and know how to use an ammeter, it would be beneficial to check the amp draw of the beater motor to determine if you are exceeding the overload or not. Ice cream is generally good at a temp between 16 and 20 degrees F. Temps vary with product and product brands. I hope this information helps, it is hard to determine exact problem without being there.
Oct 04, 2010 | Taylor 632-33 Ice Cream Maker
I need beater with its blade and a pipe for taylor machine
you can call Rick at Restaurant Parts and More, 1-888-814-1110. Have you model and serial numbers. He can most likely help you.
Apr 14, 2010 | Taylor 632-33 Ice Cream Maker
Ice Cream Makers Logo
1,604 people viewed this question
Top Taylor Ice Cream Makers Experts
Dennis Boxerman
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
Are you a Taylor Ice Cream Maker Expert? Answer questions, earn points and help others
