Question about Boating
How do I determin if the silonoid is getting fire or bad?
  • 36 Answers
Can you tell me what engine you have? approx. year, horsepower, inboard or outboard?
Thank you, I will do my best to help you.
Posted on Oct 14, 2013
Accidently crossed jumper cables on my 95 buick lesabre has power but wont click or turn over
does that have a silonoid on the starter or seperate from the starter? either way i would test the silonoid. i usually take a screw driver an touch it post to post on the. make sure to keep your hand on the handle an not on the metal because you might get shocked. usually when a vehicle wont turn over but clicks its the starter but if it doesnt click then its the silonoid. hope this helps.
Jan 05, 2013 | 1995 Buick LeSabre
I have an MTD Rider with 18hp Briggs that stops running after about 20 minutes. Last time it died I turned the key and nothing happened. I have replaced coil, silonoid and key switch still nothing. I...
if you need to jump the solenoid to start it and it shuts down sounds to me that you have a bad safety switch start with the one on the pedal
Apr 29, 2012 | Mtd Garden
1979 lincoln mark v not starting silonoid clicks and nothing else happens. is it the starter?
Not necessarily, it could be a relay or a wiring problem also. A weak battery. First have your battery load tested to determine the overall condition. Then have a starter draw test performed. That will tell you what you need to know. I hope this helps.
Sep 28, 2011 | 1979 Lincoln Mark V
I have a 2006 polaris sportsman 500 ho. that will not start with the ignition/start button, the pull start gets it going first pull< i have lights and display and the battery is new {3months old} and...
starter silonoid has bad connection or has gone out completly. check connection of ignition switch
harness connection may be able to jump across silonoid post to make crank if so bad silonoid
Aug 28, 2011 | Polaris ATV
Wont turn over
check the conections of the wires at the starter and silonoid disconect battery first as to not short anything out by bumping the engine wich is grounded if all conections are good then the bendex in the silonoid is not engaging all the way to operate the starter or the broshes in the starter ar woren out eather way just replace the starter a new one comes with the silonoid on it and they are only about 45-65 bucks at schucks and have a 1 year warranty. i dont recomend just replacing the silonoid on the starter cause adventuly you will have to replace the starter any ways. or if you are on a budget then u can remove the silonoid from the starter and sand the bendex in the silonoid with some fine grit sand paper and use air to blow any debres out of it and reinstall silonoid and it will get u by for a short time.
Aug 01, 2009 | 1998 Dodge Caravan
My 2002 dodge neon wont start all of the sudden, it makes a cliking sound, but it wont turn over I tried giving it a jump but that did not help
it is your starter silonoid not getting enought power lok at the wires and make sure they are tight if not it could be your silonoid in genral
Jun 06, 2009 | 1997 Dodge Neon
Shifter cable
check the transmission oil hot and with engine running in park
if ok you may have a bad transmission have it checked by a transmission shop sounds like bad silonoids inside
Feb 03, 2009 | 1987 Honda Accord
Silonoid clicking but won't turn over
have no solution but exact same problem on a 97 Grand am.... i'll be watching if there are any good solutions!!!!!!!!!!
Jan 12, 2009 | 1989 Jeep Wrangler
Boating Logo
47 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
